Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
GE Side by side runs constantly.
Our GE 25.2 frost free side by side, Model TFT25 JR, about 8 years old, for the past couple of years has been puddling water on the floor in the left front corner under the freezer door. There is also a build up of ice on the floor of the freezer. In addition, the motor never quits running. I'm sure the 2 are related what do you diagnose as the problem and is it something I can fix myself?
Fred
drfredgu3@gmail.com New GE side by side, was running great until the freezer door was ajar overnite. It is a little iced up inside and won't quit running now. What can I do? thanks.. cpc
  • Wrenchy Sep 04, 2008
    runs constantly, won't quit running. we replaced the thermostat but that didn't fix it.
That's not my question there.......... I sent the one about the freezer door being cracked over nite and it won't quit running now. Do I need to defrost it as well? Thanks
Posted on Aug 24, 2008
  • GE Master
  • 5,568 Answers
The timer that controls the defrost cycle/function, may have failed and there may be no defrosting occurring. If icing of the coils due to the missing defrost cycle, there may not be enugh circulation left to keep the thermostat happy.
Try defrosting it manually (I know, it's a pain - aren't we spoiled?) and see if the compressor then cycles for a few days before it starts running continuously again.
And for Dr. Fred, the above suggestion about trying manually defrosting applies to your problem too.
The exposure to overnight moisture (ice accumulation) may have interfered with the automatic cycle.
  • Steve Allison
    Steve Allison Aug 24, 2008
    Add-on comment; check under the unit, behind the lower grill to see if there is a drip-pan that is overflowing.
Refrigerator side not cooling. The freezer works fine. Its age is over ten years old. Model GE TFX22R.
Is there any frost build up on the freezer panel? If not, this could be a damper door issue. Check to see if air is coming from the damper, this is the vent inside the back left-corner of the fresh food side, assuming the evap fan is running. If you feel nothing, it more than likely is your damper door.
If you have frost build up, we're talking about a defrost issue then. Let me know!
Mar 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile Arctic Side x Side Refrigerator PSC23MGNA
if you were able to do the test... check the compressor unit, also the do check on the electrical relay of the ref.
Jul 01, 2008 | GE Profile CustomStyle PSC23MGSWW 36" 22.7...
I have a GE side by side refrigerator Model # GSH22JFTE CC that I purchased 8-25-2009. It ran almost constantly for the first several weeks (I was told that was the way it was supposed to do) In Oct. it...
hey i beleive u have a full one year warranty through ge ... so go online or call ge service geappliances.com set up a service apppointmont tell them its not cooling or sometin or whutnot lol or its making odd noises,, they will come out under waraannty and check it out .. hope this helps
Jan 27, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Side by Side Heating Up and Frost on Panel in Freezer
sounds like your defrost heater termanator switch,or defrost timer is bad-mike
Jan 22, 2010 | Refrigerators
Frost buildup inside freezer door at ice dispenser
you are still not getting a seal on that flap. It sounds as if it may be warped. THe reason the frost and ice is building up is due to the flap not sealing there isn't any other reson for your problem. Good luck on your repairs
Dave
Oct 06, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Food and water freezes but ice cream is soft
Check the door gasket seal.
Open the door for a few seconds and then close.
Immediately open the door again, and, if sealing properly, it should take more pulling force to open the door.
Mar 30, 2009 | Refrigerators
I replaced the water filter for my GE GSH25JSTA SS side by side fridge and now the unit is no longer dispensing water
I have had the same problem with the same model several times in the past. It also happens to me within a few days of replacing the water filter.
In my case, I believe the water line in the freezer door has become frozen. I usually let the freezer thaw for a couple of hours, and my water works again.
I have had constant problems with this model. I would recommend trying to sell your fridge now while it's still running, before the real headaches begin (mine has died 2x in the past six months, and I have not even had it for 2.5 years yet). No more GE's in my house.
Mar 22, 2009 | GE Refrigerators
Frost gathering in freezer, icemaker dispenser freezes over
well check to see if door seal is split if it is get new one!! need to see photo of the frozon over dispenser- found before that when ice not bein used alot the odd time you will have to take out the ice in the bucket crack it up and put back in try this???
Feb 03, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
EASY FIX!!! The drain is clogged up. All you have to do is take the back wall to the freezer off (lower section in freezer) And you will see another layer of frozen ice at the bottom (behind back wall). Get you a hair dryer and start melting. After a few minutes u will start to see a drain whole(size of a nickle in middle) concentrate you efforts on the drain hole. Now get some wire or something and stick down in hole, then pull out over and over till finally it drains all the build up water around the hole! GOODLUCK!!!
Dec 17, 2007 | GE GSH25JFR Side by Side Refrigerator
Ge after replace fan still fan not working
Something to check for. Is the top of the refrigerator door lower than the freezer door? If so the ref. light may not be turning off all the time. Pull bottom panel off to expose hinges. The ref hinge should have an adjuster. Adjust door up to be level with freezer.
Aug 03, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
194 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
