Question about Whirlpool GS460 Gas Kitchen Range
Whirlpool Super Capacity 465 Stove
Oenn won,t ignite everytime I push bake E1 and F1 appear.
  • 639 Answers
Hi bigdawg,
Happy to help you!
for this problemI would advise you on this occasion to call service.
These guys are good!
A&E factory service does most brands warranty services.
They are open 7days/24hours nation wide.
call tonight! 1-800-905-9505
I am happy to assist you!
Neil
PS. Before you leave this site please leave a "Problem Solved" rating for me on fixya.com
Posted on Aug 25, 2008
Whirlpool super capacity 465
You may have several things going on f1 e4 is a control board issue with the touch panel plug in into the control board disconnect and reconnect if this problem presist will need a control board and touch pad for the oven not staying lit there is a new oven igniter kit 8190618 unfortunately no good diagnostics for this problem good luck
Feb 18, 2014 | Ovens
Whirlpool Super Capacity 465 oven won't turn on
My Whirlpool Super Capacity 465 oven
Mar 15, 2010 | Ovens
Have Whirlppol stove ''Super Capacity 465'' with E1 & F1 alarm. What Does This Mean?
your pcb maybe shot. try dusting it and spraying it with a switch cleaner before replacing it
Feb 15, 2010 | Kitchen Ranges
I have a whirlpool super capacity 465 electric range. i get error codes that beep and flash e1 and f1?
F1-E1 - EEPROM Checksum Error - Disconnect power for at least 30 seconds and then reconnect.
Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Nov 25, 2009 | Whirlpool GS460 Gas Kitchen Range
Whirlpool oven timed bake feature dosn't work.
Oct 25, 2009 | Whirlpool RBS275PD Electric Single Oven
Have Whirlpool Electric Range super capacity 465 with accubake system. Turn off power to stove to clean oven and back of stove. Finished cleaning and turned power back on and get this beeping sound every...
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$%^TF
Sep 24, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
After a power outage oven will no longer work
Apr 02, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
PF on Whirlpool super capacity 465 electric Stove Model RF366PXGW2
PF = Power Failure. Sounds like you have a bad electrical connection. With your breaker off, check that the connections from the cord to the range are all good and tight. Next, check the receptacle where the cord plugs in. Remove the cover and check the connections there as well. Examine the power cord also. There could even be a poor connection at the breaker box (at the circuit breaker or the neutral buss bar) but not as likely, as your problem appeared when you moved your range.
Oct 19, 2008 | Whirlpool RF378LXKS Electric Kitchen Range
Whirlpool 465 large capacity electric ceramic top oven failure
How much time I need to set to do the oven self cleaning ?
I have electric Whirpool oven 465 automatic
Oct 18, 2008 | Maytag MES5870A Electric Kitchen Range
Whirlpool Accubake oven super capacity series 465
Press and hold the Broil button for 5 seconds. You will see the c change to f. THen change the temp to what you need.
Dec 21, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool GS460 Gas Kitchen Range Logo
257 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
