Question about Amana Refrigerators
I need to move my refrigerator, and to get it through the kitchen door I have to remove the frig and freezer doors from my Amana refrigerator (model # ARB2214CW) and then put them back on. Can you send me instructions how to do so? The doors need to be off on Tuesday August 26th so there is some urgency to this request. Thanks Kate
  • 594 Answers
You will need to remove the freezer door first.
1.you will need to reach the top of the fridge. there is a cover there that will need to be removed. there might be a screw in the middle of it. if not than it just pops off.
2.you will need to remove those screws that hold that bracket on. after this you will be able to remove the freezer door. just open it and lift up the door will come off.
3.the bracket that the freezer came off of in the middle of the fridge you will need to remove these screws. After you have removed these screws the fridge door will come off. just open the door and lift up.
if you need to remove the lower bracket at the bottom of the fridge than you will need to remove the plastic cover and take the screws out of the bracket and the bracket will come off.
please do not forget to rate and comment about your experience today.
Posted on Aug 24, 2008
Need schematic Amana frig SQD25VW-P1314202WW
Hello Ron Carlson
Page 6 of 6...
Pretty straight forward refrigerator!
Although I agree with the first answer you got from Todd Marr...a lot of available volunteers here have been around a lot of blocks...
Can call out the Whirlpool & Frigidaire units you share parts with... and how to very cheaply you can
test various parts to bring you to your very quick victory...
I'm just saying, ice-maker, defrost issues, warm refrigerator side... Fast frost build-up... puddles?
If you'll pardon the pun ...
FROST FREE REFIGERATOR/FREEZERS are pretty cool...!
Amana SCD25TBW Technical Information Wiring Diagram
Apr 06, 2016 | Amana Refrigerators
Freezer door opens when fridge door closes
if you are worried that the freezer is empty....fill it with plastic bottles of water...remember tho,don't fill the bottles completely as frozen water expands.
Jul 20, 2010 | Amana ATB1832AR Top Freezer Refrigerator
We have a roper frig that we use for vaccine storage, the freezer does not stay cold enought for their storage; if we adjust to freezer temp for vaccines then refrigerator is too cold for storage
Good day,
Usually caused by the machine in a cool area or room, along with the machine not getting enough door action, both freezer and fresh food.
Domestic refrigerators are designed to be used as just that. Domestic refrigerators.
Normal kitchen temperatures, followed by minimum of 7 freezer door openings per day spread over 14 hours as well as 22 to 26 fresh food door openings over the same period of time.
In other words, it's not getting enough activity daily. Common problem in doctor offices.
The best model for that type of application in the past was the Amana bottom freezer model. where the primary control was located in the freezer, nailing the freezer temp, and the top controlled by a pneumatic damper controlling the fresh food section, but I do not know if their current model still uses that system.
One option,space permitting is a small chest type freezer added to what you have.
Mar 15, 2010 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Our model HRF08W frig never cooled properly (although
Yes, there is a fan that moves cold air from the freezer compartment to the refrigerator. If this does not turn, the refrigerator compartment will not receive adequate cooling.
If the fan is turning, you should be able to hear it. It is likely located behind an access door in the freezer compartment. This door is likely held in place with screws. Remove the screws, open the door, and see if the fan is turning. If not, you will need to replace the fan motor.
Oct 14, 2009 | Refrigerators
I have a Maytag Model MFF2557HEW French Door Frig. The Evaporation motor is out, where do I install the new one? Under it, behind it or inside?
Hi, The evaporator fan motor is located behind the inside rear panel of the freezer section. Remove the screws in the panel and the panel should lift out.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 05, 2009 | Amana AFD2535DES French Door Refrigerator
Leaking by freezer door in bottom
your drain line is clogged remove back wall and trow hot water in hole please unplug unit
Apr 05, 2009 | Kenmore 57029 Side by Side Refrigerator
Amana afd2535deb Frig- freezer works fine but frig doesn't cool
If the compressor didn't come on the freezer wouldn't work at all. The problem is in the inside fan on the fridge side.
Nov 09, 2017 | Amana SCRATCH&DENT 25 Cu. Ft. French Doors...
Frig not cold but freezer is ice maker not making much ice either
Is your fan blowing in the freezer? Frost on the back wall of the freezer usually indicates a defrost problem... defrost themostate, heaters, take back panel off and check evap for frost build up and if your fan in working.
Aug 28, 2007 | Amana AFD2535DES French Door Refrigerator
Refrigerators Logo
160 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
