Question about Toshiba Satellite A25-S207 Notebook
Flickering and Shaky Screen
First time this has happened. Cure?
Kiss of Death?
  • Anonymous Nov 25, 2008
    My Toshiba Satellite A25-S207 LCD flickering and shaky which is very annoying. Can i fix that problem?
The LCD backlight is burning out or the LCD inverter board that controls it is going bad. Backlights are cheap. Must take apart LCD screen assembly. Inverter is a bit more expensive. Definitely fixable.
Posted on Aug 30, 2008
Blank or shaky screen
Display Configuration A flickering screen may be caused by the computer detecting incorrect display settings as it starts or returns from sleep. It can also come from changes to the screen resolution settings caused by a new program or update installation. Verify screen resolution before assuming the issue is hardware related. Faulty Inverter Next to the display screen behind the plastic screen bezel is a small component called the inverter, which supplies power to the screen backlight. The flickering indicates the power is not reaching the backlight. To fix the issue, replace the inverter. Faulty Connectors The wires and cables traveling from the display around the hinges and into the motherboard tend to wear at the hinge area. Over time, the opening and closing of the screen causes this wear. The solution is to disassemble the plastic casing of the laptop, reorganize the cables so they have no interference from hinges, or replace the cables and connectors with new ones made specifically for the computer make and model experiencing the issue.
Feb 02, 2013 | HP Pavilion dv6000z Notebook
Have blue screen error and then it just shuts off, cant get into nothing..
HP is bad for motherboard problems, sub out the ram one at a time, this may cure the problem, remove the hard drive and reseat back into place, sometimes this works, it is possible window files have become corrupted causing blue screen of death.
Mar 06, 2012 | HP Pavilion dv1000 Notebook
Blue screen while gaming
Based on the error code, this issue has to dowith an external Hard drive working at high stress levels. Are you trying to run the games from a secondary HD? If so, try removing them and installing them on the primary HD.
Jan 04, 2012 | Lenovo IdeaPad Y450 Notebook
While using my toshiba laptop the computer screen went black
How old is it ?
I had one that was about 3 years old. Did the same thing - It was the kiss of death.
Took it to the computer shop to fix, would have cost more to fix it than buyiong a new one.
Hope that's not the case with yours - good luck
Feb 13, 2011 | Toshiba Computers & Internet
Firefox keeps crashing on me and I am getting the kiss of death blue screen.
There can be two issues: 1. Virus (Use AVG free) 2.. Corrupt registry ( Use reginout) I am sure it will help you.
Sep 11, 2010 | Mozilla Firefox
Friend's Laptop Screen has become too dark to work with
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 24, 2009 | Toshiba Satellite U205-S5002 Notebook
Blue screen of death
Update the Operating system.
Update the Iphone too
Should cure the problem.
Richard.
Apr 20, 2009 | Acer Aspire 3680 Laptop
Anyone know why the picture would shake slightly
Does this tv have hdmi input and if so does the problem exist there?
If so I suspect the av input board could have a problem.
Mar 03, 2009 | RCA HD52W58 52" TV
Line on screen
Afraid this is the kiss of death for these sets as a genaeral rule if you sudnely loose a compleate section anywhere from 1 inch up to 3 inches it may be a board that drives the panel, but if it is only one line it usaly is the panel
Feb 07, 2008 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Toshiba Satellite A25-S207 Notebook Logo
149 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
