Question about Toshiba Satellite A25-S207 Notebook
Got up to a flickering and shaky screen this morning.
Anyone online that can tell me whats going on with this Toshiba?
  • 2 more comments
  • Dave Aug 24, 2008
    The shaky screen began first and now there seems to be some dimming or loss of brightness to the screen. The Laptop is not overheated and is not making any unconventional or unusual noises.
  • Dave Aug 24, 2008
    Have I said enough? You have not said anything but "elaborate".
  • Dave Aug 24, 2008
    Thank you for your suggestions; I have taken so long in answering because of time spent to directly attach laptop to an extra monitor and read then print your answers. The Flickering is gone when viewing through the CRT screen. I will test the video card next prior to attempting to repair the LCD on the Laptop.
    Your advice has been very helpful. Many thanks. I will report back later with further feedback.
    Again, Thanks!
  • Dave Aug 27, 2008
    It was excellent advice. Thank you.
  • 435 Answers
Can you please elaborate your question?
Posted on Aug 24, 2008
  • 1 more comment
  • Narmada Anand
    Narmada Anand Aug 24, 2008
    )Many times in toshiba laptops the lcd cable comes loose on the back. Try tapping the back of the lcd in the upper middle area and see if the screen comes back. Or apply slight pressure in that area. If that doesnt make the screen come back 90% probability
    1_fix) that cable can still be loose on the back of the lcd and pressing or tapping the back wont signal that its the problem. Removing the 4 to 6 screw around the outside of the lcd (border) which are hidden behind little pieces of rubber(spacers) Remove upper half of the border by unsnapping it from the inside one small section at a time. Once removed the back half of the frame, or the houseing part of the lcd will lean back, leaving the lcd standing straight up on its hinges. Now reseat the cable on the back of the lcd. Its the only cable that connects in the back of the lcd. Its about 1inch wide. Once connected tightly in place, put some tape on the connection to make it secure 90% probability and before putting everything back together, Turn on the laptop and test it out. If the same problem remains, try tapping the lcd cable in certain spots. If the flickering stops from you flicking the cable it needs to be replaced. 30% probability
    Putting laptop back togather, the top half of the frame will snap back in place and little rubber pieces will stick back in.
    2)try pushing a pen in the hole that trips the backlight sensor.(what makes the screen go into hibernation with the lid is closed.) If there isnt a hole or button thats pressed, its done by magnet and you would have to get the manual to find out where the magnet is. Usually on the right side of the keyboard cover. It may be that the button is worn and going off and coming back on really quick. 30% probability
    2_fix)Rapidly stick something in the whole to get that part unstuck or you would have to take the laptop apart and replace the small part
    3)It also could be the other end of the lcd cable that plugs into the motherboard. Remove the keyboard cover and reseat the cable. Rare...
    4) Now is the screen flickering and loosing video or is the screen loosing back light? Once the screen flickers black, can you still see the image and its just really dark? If this is the case it can be one of three things.
    4a)your inverter is going out 90% probability ($60.00 fix)
    4b)your lcd is going out 10% probability ($600+ fix)
    4c)Your lid cover sensor is wearing out (#2 on this list)
    5) it is possible that your video card is dieing. In this case you would have to get a new motherboard
    5a) to test if the video card is dieing on the Motherboard, plug the laptop up to external video ex_a computer monitor or svideo connection. If the video is fine on the external display, your video card is not at fault.
  • Narmada Anand
    Did you try the steps mentioned above?
  • Narmada Anand
    Narmada Anand Aug 27, 2008
    Would appreciate if you would rate this solution.
    Regards
Friend's Laptop Screen has become too dark to work with
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 24, 2009 | Toshiba Satellite U205-S5002 Notebook
Screen is flickering on my all in one Sony vaio desktop
Hello
I have seen this problem before. It was solved by updating the graphics drivers. To do this go to the Sony website and download the latest driver. Once downloaded follow the instructions to install and once you restart your system it should be fixed
Apr 18, 2009 | Computers & Internet
TOSHIBA LAPTOP BLACK SCREEN-EXTERNAL MONITOR WORKS FINE.
First check the obvious stuff then we can go from there..laptops can go into projector mode which will cause the LCD screen not to come on. You may have pushed the FN key by mistake. So try pressing FN +4 through FN + 6 and see if it comes back on..keep me updated.
Apr 09, 2009 | Toshiba Satellite M35X-S161 Notebook
Shaky picture on my toshiba 50h12
Your ICc may have damaged if display is flickering.
Jan 22, 2009 | Toshiba 50H81 50" Rear Projection...
Toshiba 50A60
Your best bet, and the cheapist, is to go on craigs list, an look for the same size tv, doesnt matter what brand, get one that doesnt work, probabily can find one free, or verry cheep, then just swop out the screen
Jan 08, 2009 | Toshiba 50A60 50" Rear Projection...
Flickering and Shaky Screen
The LCD backlight is burning out or the LCD inverter board that controls it is going bad. Backlights are cheap. Must take apart LCD screen assembly. Inverter is a bit more expensive. Definitely fixable.
Aug 24, 2008 | Toshiba Satellite A25-S207 Notebook
I have a Toshiba Satellite P100 laptop which I bought in New Zealand. I think the model comes from the USA. Part of my screen is flickering. It runs vertically from the top to the bottom of the screen and...
Good morning, Kevin!
Sounds like an LCD problem. You can verify this by hooking up an external monitor. The external monitor will probably show a good display.
After verification of the problem,you may want to try to replug the LCD cable at both ends, just to see if that corrects the situation.
If that resolves things, all is well and good. If not, you may need a replacement LCD.
If the external monitor shows the same display, you may have a motherboard problem.
Hope this information is of some help.
Ron-
May 09, 2008 | Computers & Internet
Screen flickers
If you are using your comuter with batteries and have your screen in low brightness may be the tube is damaged and the low brightness is giving you probles. Try setting the screen brigther and see how it goes.
You can also try to locate the FL-inverter board. It is a single PCB and should be just below the TFT.
Disconnect and reconnect the incoming and outgoing connectors a few times. But please be very careful not to damage the cables or connectors.
Nov 09, 2007 | Toshiba Satellite A105 Notebook
Shaky image on bottom of screen.
my guess is a capacitor is going or you convergence is going
you could send it into ptscorp.com
Oct 30, 2007 | JVC AV-48WP74 48" Rear Projection...
Flickering tv screen when playing playstation games.
I don't think it's a configuration problem at all. I do think that the set is not adjusting to the correct format. Most Stores have 30 day return policy. If it's over 30 days then they may not take it back. If you bought it online, then, the return may be difficult. If the return is not possible, then, contact Toshiba online and find a local Toshiba authorized servicer in your area. Hope this helps.
Mar 18, 2007 | Toshiba 15VL33B 15 in. LCD Television
Toshiba Satellite A25-S207 Notebook Logo
61 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
