Question about La Marzocco Linea Group 1 Espresso Machine
Plugs for Linea Model La Marrazco Expresso
We have two power cords attached to the machine. One(the smaller cord) is without a plug end. Is this for 110 or 220? How do we purchase another plug end?
Cheryl_front@msn.com
505-892-1700
  • 60 Answers
The smaller cord goes to the external pump. DO NOT put a cord cap on this and plug it into the wall, you will cause significant damage to the machine and the wall.
You should have a large oblong shaped pump with wires coming out of it that is separate from the machine. You need it to run the machine. If you need a pump, let me know.
Kelley
Posted on Aug 25, 2008
How do I attatch the power nozzel to the e series rainbow vaccuum? it seems there is cord attatched to the nozzel : I can't figure out where this plugs in??>?
One of your hoses also has a cord that goes the length of the hose. Up at the handle end the cord goes to your handle. At the end that plugs into the unit, the cord plugs into the unit just under the hose hole. You should also have a hose with no cord that is used with the bare floor brush and other attachments.
Feb 10, 2015 | Rainbow Vacuums
How do you connect your nintendo 64 to your tv
You need two cables. One has a very large, thick end that fits into the back of the N64. That is the power cord, you just plug that one into the wall. The other cord is a little trickier. It has a smaller end that plugs into the back of the N64 to the side of the power plug. On the other end of that cord, you have composite cables. (The red, white, and yellow plugs). Just find the matching color plugs on the back of your TV, set it to the correct input, and you're all set! I hope this helps!
Apr 11, 2011 | Nintendo Video Game Consoles & Games
I need to replace power supply. where the cord
Greetings from GoVacuum.com,
Unfortunately there is no fuse on a Kirby Generation model. In my 10 years of repairing Kirby's as well as other vacuums I will tell you that 9 times out of 10, when a Kirby Generation doesn't turn on, it's the cord that needs to be replaced. This is by far the most common problem that we see on Kirby repairs.
The Kirby motor is very well built, and usually has a life of 30+ years (G3 is about 12-15 years now). The only other problem it could be on the Kirby would be carbon brushes, or the switch assembly.
I would first try testing the power cord, I think this will solve the problem for you. To test a cord on a Kirby Generation (all Generation models are the same machines, just different colors) first follow where the cord goes into the Kirby at the bottom. To access this cover easier, first remove the "boot" at the bottom of the outer bag. This is the plastic part at the bottom of the outer bag that connects onto the Kirby. You will see that there is a plastic cover over the cord. You will need to remove the screw that holds this cover on.
Now after you have removed the cover, pull the plug out of the machine. Once you have the cord disconnected from the machine, you can now test it to see if there is a short somewhere in the cord. You will need to purchase an inexpensive continuity tester from Home Depot, Radio Shack or most other electronic stores. This will tell you if there is power running through the cord, or if the cord is bad. With the continuity tester, plug the cord into the wall outlet, then put the positive, and negative testing rods into the female end of the cord that plugs into the machine. You will then be able to tell if the cord has continuity going through it. The tester will indicate if there's continuity or not.
The picture here shows that the cord is good. If your tester does not light up, or indicate that there is continuity, you'll simply just need to purchase a new cord. As I stated earlier, this is the most common reason that a Kirby won't turn on.
If however your cord tests OK, this indicates that the machine either needs a new motor (or carbon brushes in the motor) or it needs a new switch.
Chris Jones
Mar 07, 2010 | Kirby Generation 3 Bagged Upright Vacuum
La Marzocco Expresso g3 how do you reouble
Check the thermostat on the top of the back boiler, if the red pin is up then, make sure that there is water in the boiler then push in pin and turn machine on. Now comes the exciting part we have to find out why the boiler overheated, is it because the elements are damaged or the pressure stat is not working properly.
Nov 05, 2009 | La Marzocco Linea Group 1 Espresso Machine
Can't find plug for power cord
On the back left end. Identified as item 4 below: c8d8f7d.jpg
Aug 26, 2009 | Lexmark X2500 All-In-One Printer
I need a replacement power cord
Found one here:
http://acebargains.stores.yahoo.net/acpoadforwel.html
and ebay looks to have a few as well:
http://cgi.ebay.com/AC-power-adapter-Westinghouse-LCM-17V2-sl--LCD-monitor_W0QQitemZ360118562836QQcmdZViewItem
Hope this helps. You are right this far from a typical power supply cord. Most just need to the cord with a 3 hole female end that plugs straight in the monitor.
Mar 02, 2009 | Westinghouse Computers & Internet
Cord to plug in
On a 120 volt plug, the smaller plug is black, power. The larger side is white, neutral. The center round plug is green, ground. Make sure your ac is not 220, the plugs are in line above the neutral. On 220 both are power.
Aug 05, 2008 | Goldstar M1003R Air Conditioner
Ethernet cords
The cord that plugs into the DSL filter is a phone line and the other end plugs into your DSL modem. Also, every other jack that has a phone or fax or answering machine or caller id box has a DSL filter as well, in between the jack and the device.
May 01, 2008 | Kensington Portable Ethernet Cord (33052)
La Marzocco Linea Group 1 Espresso Machine Logo
119 people viewed this question
Top La Marzocco Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Goldsmith
Jim Goldsmith
Are you a La Marzocco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
