Question about Maytag Kitchen Ranges
Paint peeling off around stove top burners. model#MGR6775BDS Serial # 13115412Lp Less than 1 yeart old have not cooked acid or sugary items.
  • 639 Answers
You are under full Warranty for one year!
Do not procrastinate this matter!
Call whirlpool and demand a replacement!!!!!!!!!!!!!
Tell them this unit is defectively painted!
I am happy to assist you!
Neil
PS. Before you leave this site please leave a "Problem Solved" rating for me on fixya.com
Posted on Aug 25, 2008
Paint flaking on wood burner
even the best high temp paints don't last for ever
also if you didn't clean the surface well it harder to stick
there not much you can do, depending on the stove type you have it may be something you just have to live with, some stoves get hotter than the paint can handle but even the best high temp paints will peel and blister in time, one small it is sand and clean surface and use a very thin coat, this is one time more is NOT BETTER...less is better and will last longer
Mar 10, 2014 | Garden
Broiler element went out, got a new one after installing new broiler element the electronc timer didn't work on the oven or broiler, the burners on the top worked. Ordered new electronic timer, it came...
This part you are referring to is called an overlay, on some models you have to purchase it separate from the control. If the oven has some use the sticker will not just peel off and work on another control just like you are finding out.
http://www.appliancerepairlesson.com/
Overlay
Mar 01, 2011 | Kitchen Ranges
Gas range won't ignite. We had PGE and come over
This sounds like a failed burner igniter, also called a spark module. These are pretty easy to replace since the module itself is located at the back of the stove under an access panel. The price is around 40 to 60 dollars. Lately it seems that these newer stoves have weaker spark modules. I see dead modules on models less than 2 years old, where it used to be more like 5 or more years on the older ones.
Mar 24, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Broke glass on electric genn-air
Please do not use the stove if the element is viable because of broken glass, this could become a danger to yourself.
Look at the cost of a new stove, you should be able to get one for
around 400.00. One of my customers had a glass top with 4 burners,
they had the same thing happen, the cost to replace the top was
1,200.00. So I would assume that you can get a new stove with 4
burners less then it would cost to replace the part on a stove you don't like. Maybe there is a LOWES around you to look at stoves,
they seem to be everywhere,like death and taxes.
As for putting a 4 burner top on a stove that has 2 with grill, I don't think it can be done without the extra cost of adding the parts to run the other 2 burners, so like I said in the long run,it just might be cheaper to but a new stove. It should not be a big deal to remove the exhaust from the grill part of the stove.
I looked at the model# you put down,and it does not have a grill,
from what I see, there are 4 burners and a downdraft vent in between the 4 burners, there are 6 models with this part # and none have a grill,only the downdraft vent.
If the model# is right, the cost would be around 300.00 for the glass, and then the cost of having it replaced. So I would say over
400.00, In which case for the same amount you could have a new one, but you must weigh the difference for yourself and see what you think is the best way to go.
If you have any more questions,please post back and everyone is more than willing to help you. I hope I have helped a little.
Mar 24, 2009 | Jenn-Air JED8430 Electric Cooktop
Paint on stove top is coming off.
with smaller spots you can use appliance touch up paint and it should hold paint down and keep spots from getting bigger. Depending on how old the range is your landlord might be able to order a new top. I would voice my concern to the landlord and see what they might be willing to do to appease your concerns.
Jan 16, 2009 | Sears 61301 Gas Kitchen Range
Replacement Parts For Vintage Magic Chef stove
You probably have a 1940's model of Magic Chef. Check for the model number under the lid of the cook top on the upper right hand side of the stove. It should have the model number and the serial number, too. You will need both. The Old Applicance Club run by Jack Santoro is the place to go along with a site called "Antique gas stoves"in Georgia. Good luck with the world of vintage stoves.
Sep 23, 2008 | Kitchen Ranges
Model Number JE2160SF03 Serial Number: DL 901299M Our microwave oven's floor is peeling off horridly. We can see the metal beneath the white surface. We have lived here for two years, and it was a brand...
This is usually due to spills, inadequate ventilation, or cooking on the stove top without having the hood / vent fan on.
It really should be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
Aug 13, 2008 | GE Microwave Ovens
Replacing a glass cook top
I have the replacement cook top that you need (part #WB56T10165). I work for a GE Appliance distributor and will sell you the part for WAY less than list price. The item is an unopened, genuine GE replacement part.
Let me know if you're interested.
Jan 09, 2008 | Ovens
Kitchen Ranges Logo
308 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
