Question about Amana NAV5800A Top Load Washer
AGITATOR I just bought a used amana washer nav5800aww> seems to work fine, except part of the agitator floats up during the wash and does not turn or any thing. There does not seem to be any screws to hold it on. It just slides over a shaft. What is missing?
  • 1 more comment
  • belindajohns Sep 06, 2008
    Oh I think that was not explaining my problem correctly.
    The agitator is in place and attached fine. It is the auger that slips over the agitator shaft that is not secure.
  • belindajohns Feb 23, 2009
    Thanks, I will try that
  • Anonymous Apr 03, 2009
    I have a maytag washer. My agitator works properly but the outside sheath slips off and floats during washing. how can I fix this
I bought an nav5800aww used and had the same issue. Mine was due to the coupler that attaches the auger to the agitator being worn out. I fixed it by removing the auger by pulling it up off the agitator, and putting four small screws through the tabs so that the points of the screws were pointing out. When I replaced the auger, the screws held it in place. That fix lasted about a year, but the plastic eventually got torn up enough that it doesn't work any more. You can find a replacement part online pretty easily
Posted on Feb 15, 2009
  • 30 Answers
You are missing the coupling that holds the agitator to the shaft.
Posted on Sep 03, 2008
Nav5800aww
The motor sounds like it is overloading and kicking out. Most likely cause: binding brake pads.
Sep 13, 2013 | Amana NAV5800A Top Load Washer
Amana nav5805aww washing machine won't spin
You will need to replace the thrust bearing kit. Here is the part to order.
It comes with the instructions and is an easy fix.
Oct 30, 2012 | Amana NAV5805A Top Load Washer
Amana nav5800aww water on floor after spin cycle
Sounds very similar to having something such as a sock or small article of clothing that is too large to be sucked down the drain hose into the pump. So what happens is it hangs around between the inner and outer drums and sometimes gets itself lodged over the drum drain hole, and can allow water to be centrifically flung over the top of the drum. Most times when the spin cycle stops, the article of clothing will dislodge and float around inside the drum only to do it again later....
If you can remove the top of the machine, you can usually see the gap between the two drums and use a piece of coathanger wire with a small hook on the end and "go fishing in the area between the two drums and close to the drain hole location... bet you'll find something in there... Let me know how it goes... and if I can help .. ken
May 10, 2009 | Amana NAV5800A Top Load Washer
Please Amana Washer agitates without water in but spins it out when water in
IF that's what is happening go to the pressure switch , the water level switch, give it a tap . this should solve the problem thanks the appliance doc. please rate my answer thanks.
Oct 09, 2008 | Washing Machines
NAV5800a top loader washer
The inside of your agitator became worn, and possible strip out the spline that allows the agitator to properly grip the shaft. The loud noise mustly occurs during the spin cycle. If you hear this loud noise your load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it.
Sep 02, 2008 | Amana NAV5800A Top Load Washer
Washer make a clicking noise
Zoobs, you could have something stuck under the agitator. The agitator will pull straight off. Grip it on each side and pull up hard, but don't hit yourself in the face. If that don't work, try slipping a belt under it and pull. Check for something caught under it. Another possibility could be the nylon suspension rod socket supports in the back. They will make a noise during agitation if they are dry. Put a little 3 in 1 oil to quite them down. Take the front panel off and check the pulley and belt, see if anything is out of whack. I also often find the motor support hitting the bottom panel during agitation making noise. Take the front panel off and observe during agitation. See if the support is striking the bottom. If so, just bend the bottom panel down. Catriver..post back.
Nov 30, 2006 | GE WHSE5240D ENERGY STAR Super Plus 3.2...
Amana NAV5800A Top Load Washer Logo
342 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Mike
Gerry Harvey
Gerry Harvey
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
