Exacta DELUXE XACTA SAW 3HP, 1Ph, 50? Rip Logo
Posted on Jul 02, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
On/off switch just buzzes when I push start. I can't find a reset button on the JET XACTA SAW DELUXE 3HP,1PH, 50" RIP table saw. It's getting electricity- plugged in and continuity of electricity is present from switch to motor. Does the motor have a reset button or is there some problem with the on/off switch?
Anonymous
Level 3:
  • Master 2,176 Answers
  • Posted on Jul 03, 2011
Anonymous
Master
Level 3:
Answers
2176
Questions
6
Helped
1310688
Points
5445
I am thinking that you have a problem with the capacitator (if it has one) or the starter windings/switch in the motor itself. If the switch buzzes you are getting electricity to the motor but it isn't rotating and that is where I would start to look. Before this happened did the saw make any unusual sounds or have any problems??? Also unplug tool and look for any obstructions that might have stopped the blade.
Jet table saw 3hp, low torque! New saw, correct electrical hook up, but not much power at the blade, so yes it runs but no torque! mag switch in test position, does it need to be in auto???
I am not sure what model you have but they have this saw in two models one is 230 volt only the other is 230/460 volt.
But that is not a 220 volt circuit. 220 volt is single phase where the 230/460 is a 3 phase circuit.
Look on your motor and see what the power requirement is.
if you have a different machine then the one I am looking at I would switch over to the auto function.
May 10, 2017 • Jet Saws
We have a Problem with a "JTM-4VS, 9" x 49" Table, R-8 Taper, 3HP, 3Ph, 230/460V" milling machine. We will need for the variable speed head assembly the part no. 114 which is figured in...
draw bar ...you can buy them from enco or msc for about $20-$30. Give them a call and tell them the machine you have...mention you have variable speed.
The table saw shutdown where is the restart button
Usually the reset for table saw is on the motor itself
Crawl under the table and check it out & check your motor name plate (use a digital camera to photograph the name plate so you can see it large on your computer and have a record of that information)
Look for oil caps at the bearing ends of motor, to see if your motor can be oiled using 3-in-1 oil
If your saw is shutting down, you may not have enough electricity for the motor
Look at motor name plate for volts amps or watts.
Now figure how much electricity your saw need using the formula Volts x Amps = Watts
Next, look at the circuit breaker and size wire
15Amp breaker = 1440+watts
You can figure the breaker load using V X A = W
Next look at your wire going to table saw
14 gauge wire for 15 amp breaker
12 gauge wire for 20 amp breaker
10 gauge wire for 30 amp breaker
You might benefit by running bigger wire to the saw. And adding some oil in the oil caps.
I oiled my table saw and then ran a dedicated 30Amp wire to it, and it runs real good for a 25-year-old craftsman.
TABLE SAW MODEL JTAS-10-1 SERIAL # 9031109
my table saw jet model jtas-10-1 serial # 9031109 stock # 708510
Jet saw Manual for a JTAS-10/12
Jet's Manual site is here. There are a number of manuals for Jet table saws there. I believe the exact manual you want is here though.
If this helped, please vote. Thanks!
Saw kicked out on overload,reset buttion will not reset
did it trip your outlet breaker? check breaker with volt ohm meter. hope the motor didn't go to ground.
1helpful
I own a Jet Left Tilt Cabinet Saw Mdl 708663PK. The on-off switch seems to stick and does not always start the saw. The saw runs normally when it starts. When it does not start, the on switch depresses and...
I took the front cover off of the switch and noticed the portion of the switch the off button contacts was fully depressed and would not slide back to its proper position. I lubed (silicone) the slide portion of the off switch and cycled it manually to free it up and distribute the lubrication.
On/off switch
The contacts in the switch are burnt, replace them.
2answers
Blade size
There are two common blades: Eight-Inch Table Saws are a good choice for crafts and other applications associated with thinner stock.Ten-Inch Table Saws provide the extra cutting depth needed for angled cuts in thicker stock.
Top Exacta Tools & Hardware - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an Exacta Tool and Hardware - Other Expert? Answer questions, earn points and help others
