Steam iron does not produce steam to iron. Connecting pipe from tank to iron is hot to suggest steam is in pipe but fails to deliver. Hope you can help
More complete answer...
If you are having steam problems then the cartridge needs changing.
I phoned them (0161 652 1211) and they do sell the cartridge for £5.99 including delivery but are out of stock for a couple of weeks. You have to send them a cheque or postal orders. Good luck.
Send Cheque for £5.99 for each cartridge with note of model etc.
Pulse Home Products Ltd.
Middleton Road
Royton
Oldham
OL2 5LN
I have the same problem. I have bought a new cartridge and a new water container because the new cartridge is a different shape from the old one and my iron still doesn't work. I rang Jarden, from where I purchased the items and was told if this doesn't work there is nothing else they can do.
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber .
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle.
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
I have the same problem with my steam generator iron, didn't know if it needed a new filter, but can't find one anywhere???
How do you take it off standby
