Question about HP Pavilion zd8000 Notebook
Can't Turn Computer On
My computer won't turn on. When I plug it in, the blue light in front comes on showing that it's getting power, but that's all that it will do.
  • Tinieblas Aug 24, 2008
    I tried that and it didn't work...
    What actually happened, if it helps in finding a solution is that it stopped charging at all, and eventually turned off. I noticed that the AC Adapter light wasn't on, so I figured that it must have died. I bought a new one, which appears to be working and like I said, with the new one the blue (battery charging) light is on, but I still get no response from the computer.
  • 31 Answers
I understand that your Notebook is not turning on.
That's unfortunate.
However, try to perform the following steps.
= Power Drain =
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter and Battery.
5. Turn on the Notebook power.
If the issue persists, I am afraid that you need to repair your Notebook.
Thanks
Posted on Aug 24, 2008
  • Hello
    To isolate the issue please perform battery health check and try to charge the battery using any other AC adapter.
    Here are the steps to perform Battery health check.
    Click start and select All programs and select Help and Support.
    Then select HP Troubleshooting Tools and select Battery health check. Please make sure that the AC adapter is connected to the Notebook.
    If the test result is Pass. Then Clean the battery connectors with the soft cloth and reconnect it.
    Best of Luck.
    Thanks
Dell latitude won't charge
The internal battery may need replacement, especially if you have had this Notebook for several years
Mar 22, 2013 | Dell Latitude D600 Notebook
Notebook won't turn on
my nb500 netbook wont turn on i slamed it shut now wont turn on
Apr 23, 2012 | Toshiba NB500-12X
Two red light are blinking and show general error
Hi. My epson T50 printer is flashing together two orange lights showing general error, have reset ink pad with software but still the same problem. Any ideas would be great. Thanks Jim
Mar 13, 2012 | Epson T50 InkJet Printer
I bought a new charger for my laptop as my charger broke, and the little blue light comes on but the laptop won't turn on. I have the right charger, but it still won't turn on. The power light...
The first thing to do is check that the charger is putting out the correct voltage, which should be ~18 volt. Then try to start it without the battery.
If your voltage is OK and the battery out makes no difference, then I would suspect that you have a motherboard problem that must be fixed. If the computer starts up if you wiggle the DC plug where it goes into the computer, then it's the DC jack that is looks and must be re-soldered.
Sep 11, 2011 | Compaq Presario CQ60-220US PC Laptop
Black Screen!
perform power drain. take out the battery and unplug the power adapter. press and hold the power button for 30 secs. put the battery back in and plug in the power adapter then turn on the computer.
May 03, 2010 | Computers & Internet
I shut down my computer at night. When I come back the next morning the computer is off and the monitor is in standby with an orange power light (so far so good). When I turn the computer on, the monitor...
that blue light show and error or faulty problem internally or there a problem with in the connection or computer but first check the makers website or manual for troubleshooting.
Dec 13, 2009 | LG L1932TQ LCD Monitor
My computer screen wont turn on the power is on
Sounds like either the ram may be bad or the video card is bad.Plug in an external monitor and see if it shows.If it does that will eliminate the video card being bad.If it does'nt show, the video card is most likely bad.A bad ram stick can cause it also.You could make sure the display is plugged in securely on the motherboard too.Good luck!
Aug 17, 2009 | HP Compaq nx6110 PC Laptop
The on off button on front doesn?t turn the unit off and on
Same here, your light went out if you put a VERY bright light on you'll be able to see something on the screen if you plug it up to your computer, if you are getting a new one go dell its worth it becase they last and are durable.
Jul 03, 2009 | Gateway FPD2275W LCD Monitor
HP vs19e Computer turns on Monitor stays Black. blue light blinks
Same here- I understand that the capacitors are bad and need to be replaced. I am going to undertake it myself. Radio Shack sells them.
Apr 08, 2009 | HP vs19 19" LCD Monitor
Computer does not turn on
No power or computer does not turn on. Additional information to why you may be recieving now power from the computer and/or why the computer is not turnning on.
Getting into Windows Safe Mode To get into Windows 98 / ME safe mode, as the computer is booting press and ... safe mode as the computer is booting into Windows, turn off your computer.
POST troubleshooting steps. Turn on the computer and see if it beeps normally. If the computer has never ... If you're able to get the computer to boot with one or more of the sticks.
Good Luck, Please dont for get to Vote/Thank You.
Dec 22, 2007 | IBM ThinkPad T40 2373 Notebook
HP Pavilion zd8000 Notebook Logo
131 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
