Question about Fossil Watches
FOSSEL WATCH HAVING PROBLEMS GETTING MY FOSSEL SNAP BACK CASE PUT BACK ON. ( COLLIGATE FOSSEL WATCH) THANKS RON
  • tme2rl Aug 25, 2008
    thanks for your help!!
    ron
  • 111 Answers
Press the center of case back to expond the case back side
Posted on Aug 25, 2008
Can't get the back on
Set the watch face down on a soft cloth and place the case back on the watch. Line the small indent up on the case back with the indent in the side of the watch, and push down on the case back with both thumbs with even pressure. The cover should snap back into place.
Nov 11, 2013 | Kenneth Cole Watches
Guess watch how to take back off to change battery
You must first determine if the watch has a screw down back or snap off back.The top picture is a scre down back and the bottom is a snap off. If it is a screw down back you will need a watch case back opener to open. If is is a snap off you need to look around the back and find the little notch. you can then take something like a butter knife insert the edge between the case back and the case and snap the back off.
Apr 02, 2012 | Seiko Watches
How to open the back
Determine the type of case back on the watch. Set the watch face down on a soft surface and look at the back. If it has slots, it is defined as a screw-back case. If it is smooth, it is defined as a snap-back case.
To open a screw-back watch, use the metal blade of a standard screwdriver to turn the slots counterclockwise. A case-back wrench, which can be purchased at watch-repair stores, can also be used. Set the metal tips of the wrench into the back's slots and turn it counterclockwise to open.
For a snap back case, place the metal blade of a standard screwdriver in the indent between the watch and the case. Gently apply pressure to lift the case up and off of the watch.
Close the case back by setting it back onto the watch. For snap-back cases, line up the indent on the side of the watch and press gently on the case back to close. For screw-back cases, use the screwdriver blade or case-back wrench to turn the slots clockwise, thereby closing the case shut.
Feb 06, 2011 | Bulova Watch
How do you open the back of a movado watch
It could require several tools.
If it is a screw down back you will need a case-back opener (sold at Harbor Freight for $2.99). It is adjustable to fit most case backs. Make sure the wrench fits the notches on the back and rotate counter-clockwise
If it is a snap on case use a knife type case back opener.
Look for a small indention on the case-back that allows you to snap the back off. (some watches have the indention, some do not)
You need to be very careful not to scratch the back
You may need a case-back press to put the snap case back on. Some you can snap on with your fingers other will require the press.
Aug 01, 2010 | Watches
The back cover for my watch popped off when I dropped it. How do I get it to "snap" back on?
I used to work with jewelry. !!BEWARE!!
This method is for face crystals that are completely FLAT! Any convex crystal will shatter without proper tools!!!
Any method of putting the watch cover back with the watch remotely near water/moisture is a mistake. The watch will rust sooner or later.
So if you don't want to pay a jeweler five dollars to put it back on, this is what I did to my sister's watch cover when I could not snap it back.
I took my cushy 1/4 inch mousepad to a vise. You may not have a vise. If you don't, stop reading now and take the watch to a jeweler --one who replaces batteries.
Inside the vise jaws, I used a 5 inch square piece of wood, then my cushy mousepad, then the watch facing the pad, then the back in the right place for restoring.
!!!!NOTE: Not having the back in the right place will smash the stem and damage can/will result!!!
To push the back on, I picked a 12 point socket out of my socket set that was the same DIAMETER as the watch back and placed it CENTERED behind the back.
Recapping, inside vise:
  • small board
  • cushy mousepad (to avoid scarring and crystal breakage
  • watch crystal facing mousepad
  • watch back in correct position
  • ratchet socket the same diameter as watch back centered behind cover
Slowly I positioned all these items with minimal pressure. Then when I was sure that I was ready (and prepared to hear the crystal break) I put as little pressure closing the vise that I could. The I heard a snap, and to my relief, it was the back going in!
I DO NOT RECOMMEND THAT YOU DO WHAT I DID. People with broken watch crystals become very IRATE when "all it needed was a battery"!
A screw clamp would also give adequate pressure. Any unsupported direct pressure over the crystal will shatter it!
Hope this helped.
Good luck!!!!
Jul 27, 2009 | Timex Expedition 40141 Wristwatch
Can't put (back) back on my timex indiglo
  • small board
Hope this helped.
Good luck!!!!
Jan 11, 2009 | Timex 27191 Wristwatch
Technomarine watch battery replacement
If you plan on doing this yourself, find a nice heavy pair of needle nose pliers and put the ends in the knotches on the casing back. Have them as far apart from each other as you can and turn counter-clockwise. If you still have problems opening, put the watch in a vise with the lugs in the teeth of the vise. DO NOT tighten too hard or you will snap the lugs. It dosn't have to be tight , just enough to hold the watch while you turn the back. If you still have problems please let me know and we will find another way of doing this.Good luck!!
Sep 27, 2008 | TechnoMarine Apnea 35mm Watch - Silver...
I've replaced the battery on my Skagen watch but am having trouble snapping the back on -- any ideas would be greatly appreaciated. Thanks
O.K this is a tough one, because a watch maker has a press to do this. I don't know if your watch has a round crystal or if the crystal is domed. If it is round and flat, lay the watch down with the crystal side face down. Lay it on a flat scratch-proof item. Take a wooden handle that has a domed end to it. Take the back and lay it on the watch case, making sure that the knotch on the back is aliegned with the setting crown. Take the wooden tool and using the domed end put a little pressure on the endge watch case near the edge, and slowley go around the back, it should snap into place. If it's a domed or square crystal, that's a little harder and all I can think of is finding a round concaved something that fits aroung the edge of the casing NOT hitting the crystal ,and do the same thing as with the flat crystal ( go around the edge putting a little pressure on the back) For a square crystal
Jul 07, 2008 | Skagen Watches
Bulova 96R19 ladies diamond chronograph
Watch shops use a press to put backs on. Some will snap on using your thumbs, other need the press to apply more force.
Mar 19, 2008 | Bulova 96R19 Wrist Watch
Dead battery
take it to a qualifed watchmaker or send it to fossel.This watch is water resitant and MUST be tested to insure that it remain that way.
May 11, 2007 | Fossil AM 3688 Wrist Watch
Watches Logo
220 people viewed this question
Top Fossil Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you a Fossil Watch Expert? Answer questions, earn points and help others
