Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
Dishwasher er error code - Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
  • 1 more comment
  • beverlys Dec 25, 2008
    Regarding Fridgidaire dishwasher, mode FDB4315LFCO...I have had this problem about a year ago....error code and will not reset. Called costumer service who directed me to a repair specialist who had to take the machine to the shop, replace the computer board and cost me over $300. Now I have the same problem again......if I have to replace the computer board every year I think it is best to trash this piece of you know what and take a chance on buying a new dishwasher manufactured by a different company...I have had this dishwasher less than 2 years.
  • samjones451 Jan 10, 2009
    I have Frigidaire FDB4513 dishwasher with the same Er code. Through some searching on the web I found this manual which seems to be on the dealer side of the Frigidaire site:
    http://www.frigidaire.com/tip/servicecd/...
    It describes that the ER code means the membrane switch is at fault, actually it detects that one of the membrane switches has been in an 'on' or depressed state for more than one minute. This seems to corelate with the fact that one or two days ago I started to have trouble selecting which cycle/program options to use.
  • steve allan Feb 22, 2009
    we have got the kenwood kdw8st2a dishwaher only had for14 mouthes
    and now geting e4onthe display will not work keep away from this make going to have to by a new dishwasher now
    steve from peterbourgh
I have a similar problem with my Frigidaire FDB4050LHS1. My Owner's Manual says to contact the Customer Care Center if the display shows "Er", "uF", or "CE". When I called them, Maria didn't have a clue what the codes meant - all she could do was give me phone numbers to authorized service centers in my area.
I managed to get ahold of a "SERVICE DATASHEET" P/N: 154718601. The error code "ER/ER" means there is a "switch failure"; "ER/CE" denotes a "Configuration Error"; "ER/uo" means "Vent will not close"; and "ER/UF" means "Fan not running".
The schematic only labels three switches - labeled "USER INTERFACE SWITCH", "DOOR SWITCH", and "FLOAT SWITCH". There is also a switch in the pump motor assembly. If either the door or user interface switch is faulty, then you probably won't be able to do anything other than call a repair service - unless you know how to replace these switches yourself.
If the float switch is causing the error, you might be able to run the "Water/Service Test". From "PF" (denoting a Power Failure) or idle mode (with no lights on whatsoever), press and hold the "DRY/AIRDRY" and "START/CANCEL" buttons at the same time for 3 seconds. This will start an 8-stage test that runs for about 7 and 1/2 minutes. The display will show which step the test is in until it shows an error code. Step 1 tests the water valve, which is where the float switch is located. If that switch is bad, you will likely see "Uo" displayed within the first minute of the test.
Posted on Nov 21, 2008
My fr dishwasher LEDB400f is flashing Er S cleaning , Itried switching off power for more then 20 min but no help .
Posted on Aug 28, 2010
I was also seeing the "ER" and "uo" error codes with my Frigidaire FDB4315LFC0 dishwasher. These and other posts led me to check the vent located on the upper-right top of the interior, where the nut holding the fan was loose. I removed the top rack, tightened the nut, replaced the rack, and restarted the wash cycle with success! If this doesn't work you might check this link: http://www.applianceserviceblog.com/blog/2009/12/frigidaire-dishwasher-with-blinking-uo-error/#respond.
Posted on Jan 04, 2010
Model # FDB4315LFCO Frigidaire Stainless Steel Dishwasher
Posted on Nov 18, 2008
I have a Frigidaire FDB4513 dishwasher with the same Er code. Through some searching on the web I found this manual which seems to be on the dealer side of the Frigidaire site:
http://www.frigidaire.com/tip/servicecd/Content/Dishwashers/5995477345_Direct%20Feed%20Dishwashers%20SM.pdf
Posted on Jan 10, 2009
Worst dishwasher I have ever owned. Replace the vent everyyear what a piece of garbage
Posted on Dec 21, 2011
I opened the door of the dishwasher and found two switches connected to the back of the handle that you can take out and replace, probably a buck ea. I just kind of pushed the little white plastic knob that closes the circuit and it is back at work. No need to replace the whole circuit board! Hope this helps you guys also. Good luck
I have a Frigidaire dishwasher model: PLD2885RFCO
Were can fine the digital readout code for this model
the code look like it could be a > R A or a backwolds
7 - A.
Posted on Mar 22, 2011
  • 594 Answers
What is the model number of your dishwasher?
Posted on Aug 24, 2008
3 Suggested Answers
SOURCE: Frigidaire PLD4375RFC Dishwasher error "ER s" any
error message says ou-what does that mean?
Posted on Apr 23, 2011
  • 93 Answers
SOURCE: I have this code error
That will be a main control board. Also if you have a touch pad replace that also. If its more than three years do not repair but replace.
Posted on Jul 24, 2008
What does code Uo mean on the dishwaher
It is a Vent problem. The vent aids drying at the end of the cycle.
Frigidaire Diswasher ER UO Error code [FIXED] - Appliance Repair ...
forum.partsdr.com > Forum > Appliance Repair Help > Dishwasher Repair
May 25, 2012 - 20 posts - ‎3 authors
The ER UO error code means "Vent Open". On the top back right corner of the dishwasher tub, there is a vent and fan that opens to help dry the ...
Frigidaire Dishwasher Error Codes - What To Check - How To Reset ...
https://removeandreplace.com/.../frigidaire-dishwasher-error-codes-what-to-check-ho... Feb 18, 2016 - The error code will display where the usual numbers are on the display screen. .... Do you have an error code on your Frigidaire dishwasher and need ..... Can you tell me what do you mean by "knockout plug has been removed"? ... Frigidaire dishwasher manual says UO error code is vent assembly error.
Diagnose UO Error Code - Dishwasher - YouTube
? 3:15
https://www.youtube.com/watch?v=pvJTiTd35vI
Dec 22, 2016 - Uploaded by Byrd Appliance Specialists
Byrd Appliance Specialists 3825 Gilbert Dr., Ste. 342 Shreveport, LA 71104 www.byrdas.com 318-459-8745 ...
My Samsung washing machine is showing a UE code during a spin ...
www.samsung.com/uk/support/skp/faq/1025292 Jul 5, 2016 - Your appliance will display a UE code when it has detected an unbalanced load and has stopped the ... If the door remains locked and the machine is displaying UE error, please run a drain program. ... What does this mean?
LG Help Library: Error Codes - Dishwasher ' LG U.S.A
www.lg.com > Home > Support > Product Help > Help Library May 10, 2017 - An error code on the display of the dishwasher can usually be resolved by performing a few simple troubleshooting steps.
LG Help Library: UE Error Code - Top Load Washer ' LG U.S.A
www.lg.com > Home > Support > Product Help > Help Library Sep 1, 2017 - After 3 attempts to balance, the uE will change to UE, meaning the unit was unable to rebalance the load and requires assistance. To determine ... What does code UE mean on the dishwasher Google Search
Oct 31, 2017 | Dishwashers
Frigidaire dishwasher reads Er clean
http://www.appliancerepairlesson.com/2012/12/15/frigidaire-dishwasher-error-code-er-keypad-code
It could be thinking you are pressing a button for too long.
Try the above link answer for reset.
Or unfortunately it can be a shorted keypad.
Dec 01, 2015 | Frigidaire Dishwashers
How do I find out the error codes?
Good Afternoon Delia Collins, thank you for your post!
Based off the information you have provided your Frigidaire dishwasher is flashing an "ER" error code on the panel. Typically, the "ER" stands for an error code sometimes to help clear out a false error code you can perform a reset on your dishwasher. In order to do that you would need to disconnect power from your dishwasher for approximately ten minutes.
If you continue to experience an issue with the error code I would recommend contacting a technician for proper repairs. The technician will be able to properly diagnosis your dishwasher and this will help you to avoid any unnecessary part purchases. Hopefully this is helpful. -Matt
Nov 05, 2014 | Frigidaire Dishwashers
Have a Frigidaire Gallery dishwasher that is flashing ER
Good Morning Jimpat Holmes, thank you for your inquiry!
I understand that you are having an error code "ER" displayed on the panel of your Frigidaire dishwasher. Normally, "ER" stands for error code and that can be a miscommunication within the board. I would perform a reset on your dishwasher and you can do that by disconnecting power from your dishwasher for ten minutes. If you continue to receive an error code you could be experiencing an issue within the control panel or faulty wiring harness. I hope this information is helpful. -Matt
Oct 30, 2014 | Dishwashers
I get an Er code 5 on our Dishwasher and it keep restarting in the rinse mode
Thank you for your post, friend!
I see you are having trouble with your Frigidaire dishwasher and you are receiving error code "5". However, it appears "5" is an invalid error code. May I have you model number please? Typically you can locate your serial tag on the inside wall on the left hand side. With this information I can better assist you with pinpointing the issue.
In the meantime, let's attempt resetting your dishwasher. You can do this by unplugging it or flipping the household circuit breaker to the off position for roughly ten minutes. This usually clears false error codes. -Matt
Sep 18, 2014 | Frigidaire Dishwashers
Need manual
Good Morning Steve - I am happy to assist you, however according to my database I'm not showing that Frigidaire has an error code FR for a dishwasher or for any product for that matter. Could the error code possibly be an ER, PF, FL or RF?
· Typically error code ER indicates that the main control board has detected a stuck key or a key pressed for more than one minute.
· Generally error code PF means that the dishwasher has experienced a power failure and you should be able to resume the cycle.
· Error code FL is advising you that the water valve is in the open position.
· RF indicates that the rinse aid reed switch in dispenser is open and needs to refill the rinse aid.
Let's try resetting the unit by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait approximately ten minutes and then turn on the dishwasher. If issue persists, then I would personally contact a professional to accurately diagnose the washer to determine the root cause to reduce the risk of unnecessary parts.
I hope these troubleshooting tips help you in some small way.
Jun 25, 2013 | Frigidaire Professional Series 24 in....
Electrolux dishwasher DF code after an er 01 code. how to fix at home
Hello Shirley - Typically error code ER01 indicates that a water leak is detected under the tub. Unit will possibly need a hydraulic kit. Try unplugging the unit or flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit back on. Could the error code DF possibly be PF? If so, PF means power failure and you should be able to start a cycle. If the error code continues to display on dishwasher then I suggest contacting a professional to accurately diagnose and repair it.
Sep 30, 2012 | Electrolux EIDW6305GB 24 in. Built-in...
Frigidaire gallery FGHD2433kw1 error washing clean drying ER s ...
The ER error code means the touchpad is defective..sometimes that can be just a loose ribbon cable connection to control board. or if that seems tight the touchpad which is part of the console should be replaced
Aug 23, 2011 | Frigidaire FGHD2433K 24 in Builtin...
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
11,253 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
