Question about Compaq dc7100 Small Form Factor (PJ361UA) PC Desktop
Dc7100 sff power supply
Im looking for a bigger power supply,ive bought a x1300 ati pro card but it has a 350w rating and my psu unit is only 250w i found a psu unit thats close but its still only 340w
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 3 (2600.xpsp.080413-2111)
Language: English (Regional Setting: English)
System Manufacturer: Hewlett-Packard
System Model: HP Compaq dc7100 SFF(DX878AV)
BIOS: Default System BIOS
Processor: Intel(R) Pentium(R) 4 CPU 3.00GHz (2 CPUs)
Memory: 1016MB RAM
Page File: 635MB used, 1808MB available
DxDiag Version: 5.03.2600.5512 32bit Unicode
DxDiag Notes
P/N: 349774-001 -340w
  • 1 more comment
  • Anonymous Oct 05, 2008
    motherboard seems to have smaller than normal atx adapter and 6 pin pci power.  I'd even be willing to put into an different case
  • Team Evil Nov 29, 2008
    I have the same problem it is a proprietary connector. thinking out loud, mounting in new box and using another "normal " supply to power the peripherals ?
  • Anonymous May 03, 2009
    I am told that the DC7100 "CMT" and MT use a standard micro atx motherboard. The others in the dc7100 and 6100 series use a custom board. So I am going to try a 24 pin 500 watt atx/micro atx power supply. I already know that I will have to fabricate a mount, but it should be worth it.
    Problem Solver:
  • 18 Answers
Part number :
349987-001 Switching power supply (340W) - 100-240VAC input, 45-66Hz
Posted on Aug 27, 2009
I want to upgrade my psu from 250w to 500w(around) the problem is my pc model was "HP Compaq 6000 Pro SFF PC (Intel Core 2 Duo E7500 2.93GHz 2GB RAM)". it was a small form factor pc (my psu has a step...
I'm not sure exactly what your supply looks like, but if you go to google images and type in "500 watt small form factor power supply"
you will see quite a few options. you can click on the correct image to see a ling to the web site.
Sep 30, 2013 | HP Computers & Internet
I have an ATI radeon X1300 Low Profile 256mg PCIe graphic card for my Dell Optplex 620 (SFF) computer. I'm wondering about the power draw. The computer has only a 240 watt power supply. Will this tax...
Your computer should be able to handle the graphics card with no problem.
The only issue that comes up is how many hard drives or CD Rom drives are attached to the system.
If everything is stock out-of-the-box, you are OK.
I hope that this helps.
Mar 05, 2011 | ATI RADEON X1300 Pro 256MB PCIE Graphic...
Ati 9600se problems
I suspect that you are using too small a power supply. The display card uses a lot of power, to achieve the display rates. Try a heavier duty power supply
Oct 21, 2009 | ATI RADEON® 9600 SE, AGP Video Card
Hp compaq d530 400 watt power supply
You will not find a power supply for this case. Why would you want to upgrade such an old computer? Get yourself a new one with amply power for your needs. If you are one that upgrades regularly, get a standard case with standard components that can be upgraded without the hassle of replacing proprietary form-factor compnents.
Aug 02, 2009 | HP Compaq d530 SFF PC Desktop
What power supply is in the et1161-07? I am looking to upgrade the graphics card to a nvidia 9500, 9600, or 9800. They all require different wattages.
The power unit in question is a 250W supply unit. Nvidia series 9800 cards require 580W, the 9600 series require 300 - 400W, and 9500 series require 350W. All of these will require a new power unit. Antec is a more than adequate. Any computer shop should have a 600W unit for $100.00.
Jul 13, 2009 | eMachines Computers & Internet
Bought this card to replace the other one on the fritz
I believe this card has a DVI jack and a VGA jack. Depending on the card the default may be either jack, most of the time it's the DVI and you'll need to use the adapter that came with the card.
Mar 30, 2009 | ATI RADEON X1300 PRO, (256 MB) AGP Graphic...
Problem installing ATI Radeon X1300 256mb in Dell Optiplex GX260
Hi edward,
I'm looking at the specs of your dell and of the video adapter.
It appears the Power Supply in your dell may to under powered for the video card.
According to dell's website the largest psu that ships with that unit is 250 watts while the radeon x1300 needs a minimum of 250 watts to run and assuming you have the 250 watt version you need to take into consideration that the psu is also powering your CPU, memory,fans,hard drive/s and other components on in your system so 250watts just isn't enough.
You may want to contact dell and see if there is a larger psu that you can purchase. I would recommend one at least in the 400 watt range.
I hope you get it straightened out I certainly know how frustrating it can be to not be able to use new hardware.
Let me know how it works out.
Mar 16, 2009 | Computers & Internet
Graphics driver for x1300 pro agp
Yes it will definetly works;-) go pro go ati:D
Jan 05, 2009 | ATI RADEON X1300 PRO, (256 MB) AGP Graphic...
ATI x1650 Pro Stops!?
For this card they recomment at leat a power supply rating of 450 watts. If you have lower than this then I would suggest upgrading the power supply. A 550 watt psu is reasonably priced and should give you plenty of power for future use. Hope this helps.
Oct 17, 2008 | ATI RADEON X1650 Graphic Card
the card you have is a PCI express 16X your board is for PCI express 8X. I think some cards can run at a slower speed but I believe you have the wrong card for your board
Jul 29, 2008 | ATI RADEON X1650 Graphic Card
Compaq dc7100 Small Form Factor (PJ361UA) PC Desktop Logo
2,252 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
