Question about RCA D52W19 52" Rear Projection Television
RFA D52W19 need some help/advice
I was given this TV for free. The previous owner stated it needs a total lamp replacement. Here is what it does.
When initally pluged in the green led in the power button flashed 3 times. When pressed same thing 3 flashes, no picture or sound.
I've read here that it could be the flyback transformer? Procedure for replacement of this part.
Also how hard and dangerous is it to replace the lamps? Procedure to replace them.
I have the TV torn down and am ready to procede but would like some guidence or advice. My only other option would be to salvage out the components and trash the rest.
  • bigmatt762 Dec 28, 2008
    My tv does the same thing. After tearing it apart I found out that the green tube had separatated like a light bulb broken from the socket. Iwas told the part was $240 abd $400in labour. So I would't mind fixing it myself if I could get a manual.
  • RCA Master
  • 8,617 Answers
3 blinks is the flyback not the picture tubes. You need flyback number 259296 you can get a replacement at the following link with free installation instructions on how to replace the flyback step by step. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Aug 25, 2008
The tv comes on but no sound or picture
Your rear projection lamp is defective you need to reset the program when your replace the lamp because you already reach the hrs use of the projector. Or the connector on the lamp lose.
Sep 24, 2011 | RCA D52W19 52" Rear Projection Television
Samsung DLP TV time, temp and lamp lights blinking... won't turn
Les,
I'm not a TV repair guy but my owners manual states that when all three LED's or lights on the front of the TV are flashing, that the lamp needs to be replaced. Might want to look into this. Good luck!
Greg
Aug 30, 2009 | Samsung DLP HL-P5663W 56" TV
Need circuit board
You might be able to get some help from the owner of the RCA name;   Thompson Consumer Electronics
Mar 01, 2009 | RCA D52W19 52" Rear Projection Television
Tv not turning on
replace the flyback you need flyback # 259296 you can get the flyback at the following link with free installation instructions.
Feb 27, 2009 | RCA D52W19 52" Rear Projection Television
Green lamp goes out within minutes of turning on tv
Check CRT board the Video IC on it can be bad so you do not have to replace Tube be Very carefull when you remove CRT board from Neck of Green Tube so you do not Breck it. Check all 3 tubes make sure none of them are leaking out coolent fluid.
Jan 01, 2009 | RCA D52W19 52" Rear Projection Television
RCA D52W19 only Blue lamp firing
Shorted Blue picture tube or video ic on blue CRT board.
Sep 01, 2008 | RCA D52W19 52" Rear Projection Television
Replacement Lamp
If your model is the D52W19 you dont have a lamp you have three CRTs ( picture tubes) instead. What is the symptom? I have a good source for RCA parts. Please respond to this same post and if D52W19 isnt your correct model number please post that as well and I will assist you with your set.
Aug 04, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W19
thtas the error code which means the flyback needs replacement. Its a inexspensive easy repair you can get a new replacement flyback at the following link for less than 50 dollars which includes shipping and free tech support to help you install it. You need Flyback 259296. Here's the link.
Jun 26, 2008 | RCA D52W19 52" Rear Projection Television
Mistubishi tv vertical hold not working
you can go to this link and one of thier tecs can help you out just leave them an e-mail with your model number and they kow how to do the bypass
Apr 10, 2008 | RCA D52W19 52" Rear Projection Television
Panasonic pt-50lc13 shutting off
i'm on my 3rd bulb in 5 yrs. i hate this tv. this time my bulb light didn't come on. instead the power light flashed green fast then went to red flashing after. i took out the bulb and it's blown!
Nov 19, 2007 | Panasonic PT-50LC13 50" Rear Projection...
RCA D52W19 52" Rear Projection Television Logo
147 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
