Question about Philips DVDR3450H DVD Recorder/HDD Recorder
DVD Recorder I have a Philips DVD 3460H Player/Recorder. When I try to dub from the hard drive to the disk it starts recording then immediately freezes up the whole machine. I have to unplug it from the mains to get it to work again.
  • 8,596 Answers
Double check the firmware from philips website, but most likely that hard drive has an internal problem
Posted on Sep 04, 2008
TEAC DVD HDD recorder model DV-R250HD
You do that with the burning software,,, in settings.
Sep 05, 2013 | Teac Computers & Internet
I have a Magnavox ZV427MG9. I follow all directions in manual for dubbing VHS home movies to DVD but when I try to play the DVD back there's nothing on them.What am I doing wrong?
Depending on the procedure you may be pressing the record button instead of the D.Dubbing or Dubbing button. When recording from VHS to DVD you must first, load the blank DVD and VHS home movies, then play the VHS movies, then PAUSE the VHS movie when you want to START recording... then the only the you have to do is pressing the D.Dubbing button or the Dubbing button. If your VHS tapes starts to play after the Dubbing button is pressed you have been successful in Dubbing.
Aug 13, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Problem dubbing from HDD to DVD+R (LG RH7823W)
Received no proposed solution, Is this the service I can expect from fixya,com?
Jun 16, 2009 | LG DBRH197H DVD Player/HDD Recorder
Dubbed DVDs will not play
You have to use the Magnavox dual to finalize the discs, and then they should be able to play on other players. I don't have a manual for that exact recorder, but in general you would go to the Settings Menu of the DVD player --> go to Disc Edit --> and then select Finalize - the exact pathway might be a bit different on that particular recorder. Once you have finalized one of your discs, try it on another DVD player and see if it works. Good luck!
-Tha Mp3 Doctor
Feb 15, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Dubbing from DVD to HDD
When you insert the dvd are you in dvd mode or hdd mode I think you have to be in hdd mode then go to settings insert dvd that you want to dub wait then it should become not greyed out, I had a similar problem when i tried to burn a dvd from hdd I had to be in hdd mode to dub I hope this helps let me know
Jan 23, 2009 | Philips DVDR3575H/37
Dubbing vcr to dvd-
its the copy protection system doing this. if you have another dvd player or vcr, you can hook that up to a time base corrector box and run the output out of that to the dvd recorder, allows recording from any source.
Oct 04, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
DVDR 3460H - problem ejecting disk
1) Turn it upside down.
2) Turn it on
3) Press eject button & use screwdriver with special slot
Similar example
http://www.ryan.com.br/prod_dvp642_ejection.htm
Mar 23, 2008 | Philips DVDR3450H DVD Recorder/HDD...
Dubbing to DVD not working
make sure the DVD is formated.
Feb 01, 2008 | JVC SR-DVM70 DVD Recorder
DVD RW stucked - stall the whole system.
Hi, I found this site today cos I had a similar problem. To cut a long story short I found a slot on the bottom of the machine, below the disc tray, that has a white lever in it. After removing the power source I moved the lever to the side and the tray opened manually so I could remove the disc. It seems It was a duff DVDR as other discs now work fine. Good luck !
Oct 15, 2007 | Philips DVDR3440H DVD Recorder/HDD...
Philips DVDR3450H DVD Recorder/HDD Recorder Logo
252 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
