Question about Kenmore 46123 Stainless Steel Electric Kitchen Range
Kenmore oven model # 3114548692 or 3114548892
This oven cooks about 25 degrees F. higher than it should. Need to know how to calabrate this oven so we can use it more confidently.
  • 639 Answers
Hi debocc54
Happy to help you!!
I would advise you on this occasion to call service.
Needs new part!
These guys are good!
A&E factory service does most brands warranty services.
They are open 7days/24hours nation wide.
call tonight! 1-800-905-9505
I am happy to assist you!
Neil
PS. Before you leave this site please leave a "Problem Solved" rating for me on fixya.com
Posted on Aug 25, 2008
Nuwave doesn't get up to 350 degrees
NuWave Oven Reviews - Is it a Scam or Legit? - HighYa
www.highya.com/nuwave-oven-reviews
Getting started with the NuWave Oven is simple and easy. ... Also, because it doesn'trequire any preheating or venting, it won't heat up your ... with "HI" being the maximum, which roughly translates to about 350 degrees in a standard oven.
Moist, Juicy and Flavorful Boneless Skinless Chicken Brxxxts
busy-at-home.com > In the Kitchen > Recipes > Grilling
Rating: 4.4 - ‎5 votes - ‎25 min
Feb 25, 2015 - Quick and easy dinner doesn't get simpler than this! ... I started out making lunch fixins' and ended up making a beautiful meat entree that you (or ... Using a fork, I place the chicken brxxxts in theNuWave oven on the 4-inch rack, laying ... is defaulted to this, unless you change it. high power is 350 degrees.
Nuwave Oven - Nu-Wave oven is junk! Review 139470 Apr ...
nuwave-oven.pissedconsumer.com/nu-wave-oven-is-junk-20090413147...
Apr 13, 2009 - I bought the Nu-Wave oven-pro on sale before Easter to cook a fresh 8lb turkey brxxst. ... Gave up, put it in regular oven for 30 minutes to get it to 170 degrees.... For Frozen Chicken Brxxst I Set My Unit to 350? and Cook 13 Minutes .... The people who say it doesn't cook chicken, etc., need to check to make ...
All comments on Can I Bake in the NuWave Oven - YouTube
https://www.youtube.com/all_comments?v=_GBGgD9gFts
(400 degrees) I took it out of the pan by flipping it over on a plate and the whole botto
Feb 08, 2016 | As Seen On TV NuWave Pro Infrared Oven...
Wife washed off temp guide for oven It's a belling model l cook center
I don't know if this will help but on my oven the temp starts at 200F and go's up by 25 degrees each quarter inch
Nov 18, 2012 | Ovens
What temp for turkey done ?
Always use an oven bag is used to promote even cooking.
Microwave on MEDIUM (50% power) for 7 to 9 minutes per pound rotating dish every 15 minutes. Not recommended for turkey over 12 pounds
Use an instant-read thermometer after cooking. Turkey is done when thermometer reads 180 degrees to 185 degrees F for whole turkey or 170 degrees to 175 degrees F for turkey breast. Insert thermometer through **** in oven bag into inner thigh for whole turkey or into thickest part of breast for turkey breast.
For easy slicing, let stand 10 minutes after removing from microwave oven. To open, carefully cut or **** top of oven bag. NOTE Microwave directions were tested in 600 to 700-watt microwaves. Higher or lower wattage ovens may need adjustment in cooking times.
Nov 21, 2010 | Microwave Ovens
Oven tempature is 10 to 15 degrees lower than set temp.Can this be adjusted? This is a electric oven. GE Profile Model VZ295971J.
all ovens very sometimes 10-25 degrees +/- depending on the brand..nothing you can, do set the temp a little higher if you know its off.
Jan 17, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
I have an otis spunkmeyer oven and would like to adjust the tempurature. Does anyone know how to do it
I have just received a spunkmeyer oven. when I checked the temp, it was 250 degrees. I wanted it higher. I unscrewed the front screws around the front door , inside there is a small sloted screw I turned it as far as it woud goto the right. put it back together and tried it. The tempreture rose to 325 degrees. Short of that one would need to change the temp thingy inside to get it hotter.
Dec 28, 2009 | Farberware T490C 1500 Watts Toaster Oven...
Kenmore elite range oven problems
hi. thanks for the question . i would replace the igniter in oven .thanks the appliance doc
Sep 26, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
I have a built-in GE electric convection-regular oven. Model JT915W0F8WW. I don't understand when I push the convection baking do I change the baking time? Isn't it suppose to bake faster than the...
As a genaral rule of thumb.. Most recipes can be adjusted for convection oven use by decreasing the temperature by 25 degrees F and decreasing cooking time about 25%. Dishes with cooking times over 45 minutes, and that might dry out too much (like lasagna, or meatloaf) you should cover for the first half of the cooking time, and then remove the cover.
Aug 31, 2008 | GE Kitchen Ranges
Oven temperature fluctuating
Glowworm, Im assuming your model is a 790.78802500. If your husband is handy with a meter have him ohm out the sensor. It should show around 1091 ohms at 75 degrees or room temp. The preheat is programed so that the manufacturer can get the energy effecient label on the range and what ever perks they get from it. It actually should take around another 10 to 15 minutes to reach the set temp after it shows preheated. You can calibrate the oven by setting bake to 550 degrees. Then press and hold the bake pad again for 15 seconds or until a single beep is heard. Now you can adust temps up or down in 5 degree increments up to 35 degrees by using the slew keys. It will show in the display. Once you have the calibration done, press stop/clear. Catriver...post back
Nov 01, 2006 | Kenmore 78802 / 78804 / 78809 Gas Kitchen...
Kenmore 46123 Stainless Steel Electric Kitchen Range Logo
50 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
