I just bought a Kingston SD/512-S 512 MB memory card. It went into the camera with no problems and records pictures properly, but it only pops out about 1/8" - 1/4" or so. I can't pull it out and I don't want to force it.
The 16 meg Canon card that came with the camera appears to be much thinner than the Kingston.
Kingston's web site says that this card is compatible with my A520.
Does anyone know what brand SD card will REALLY work? Any suggestions? How can I remove the Kingston card?
There are only two types of SD cards. MiniSD and SD. No matter what brand of SD card you buy they are all the same size and compatibility and same thing goes for the MiniSD cards no matter what brand MiniSD card you buy they are all the same size and compatibility. It is the wonders of standardization, anyone that uses the SD or MiniSD name they must produce all their cards to certain specs.
I know you did not buy a SD card and try to put it into a MiniSD slot, that is impossible (unless you used a hammer). The card just got stuck, or maybe you put the card in the wrong slot? My camera's ION battery looks close to my SD card. Anyway your going to have to remove it and you are going to have to use force if needed. I would use needle nose pliers (just don't squeeze THAT hard) use just enough force to pull it out and try not to wiggle it out.
Check if there is anything in the way. It could be a simple grain of sand. A corner of the sticker could also be the problem, maybe a corner of it got loose and was caught in something.
it was dropped with lens fully extended. lens is retracted and not exactly straight when turned on...
(More)
it was dropped with lens fully extended. lens is retracted and not exactly straight when turned on it tries to boot up but then shuts back down. the lens does not move is there a reasonable cure or is the lens out of track if not is it too costly to bother with repair
Batteries need charging message very often, even, with new fully charged or new non rechargeable...
(More)
Batteries need charging message very often, even, with new fully charged or new non rechargeable batteries, the camera can be put in the review pictures mode with no problem but when putting in camera mode the camera will go off or show change batteries message, or if I zoom the camera will shut off, it seems if I put batteries that are new (tested shows full scale in green) the camera will either shut down or show change batteries message. This is hit or miss, sometimes it will work for awhile with batteries that are not fully charged. The manual says use alkaline batteries. Does this really make a difference? I think there is something wrong with this camera. The camera is several years old, purchased new. When first given as a present this camera has always been tough on batteries. That is the reason I went with rechargeable AA batteries but the problem has been getting progressively worse even when using new non rechargeable batteries,
Re. Canon PowerShot A520. Lens is stuck about 97% open. The camera will not power on. The problem...
(More)
Re. Canon PowerShot A520. Lens is stuck about 97% open. The camera will not power on. The problem happened suddenly with no warning. The camera is kapoot!
LCD display shows up so light that if there is any light where I take a picture I can't see it in...
(More)
LCD display shows up so light that if there is any light where I take a picture I can't see it in screen, and I have to look through the view finder. What to do?
The camera will not turn on even with fresh batteries. Is there any combination of buttons i can...
(More)
The camera will not turn on even with fresh batteries. Is there any combination of buttons i can press to reset it somehow?
