Question about Maytag MLE2000 Front Load Stacked Washer / Dryer
Water wont drain all the way
My maytag neptune stackable washer and dryer will not drain all the water
  • konakai Jan 20, 2009
    wont drain all water out then wont spin tries but goes slow then changes directions and tries again wont spin fast
  • jmichau Mar 11, 2009
    I have the same problem and am trying to get it fixed. You can find good info here:http://www.applianceguru.com/
    Search for the model name and number of you appliance. Good luck!
    I have a 2001 Maytag Neptune MLE2000AYW stacked W/D that won't spin. I've removed the washer control board an inspected it for burned resistors, none. Replaced the wax motor in the door locking system, no help. Not sure what to try next, but I'm gonna keep at it.
I have the same problem and am trying to get it fixed. You can find good info here: http://www.applianceguru.com/
Posted on Mar 11, 2009
I have a maytag neptune washer/dryer stackable. Moved hooked it up dryer works great but washer wont turn on???
Make sure you have power to the outlet, I have seen where a 110 outlet was working on either the top half and not the bottom
Jan 30, 2015 | Maytag Washing Machines
The water in my stackable washer and dryer wont drain
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 19, 2010 | Maytag LSE7806A Top Load Stacked...
Stackable Neptune Front Loader Washer Leak.
check that the door seals correctly on the rubber boot, check the boot for holes or rips, check the drain hose, tub to pump hose and pump.
Jul 08, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Neptune stackable -water left below the drum after cycle complete
Some water yes. a lot of water no.As long as the water stays below the wash tub you should be OK.
You might want to pull your water pump off and check for a restriction.
Mar 23, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune stackable washer dryer stopping
Maybe a water fill problem ,washer will stop if no or not enough water enters the tub in a given time
Dec 04, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
Neptune stackable washer...
You put the detergent directly on top of the clothes.
Jul 31, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Maytag front lead stackable
That is correct. Take the screws out of the console up top. look for a burn mark on your circuit board. If it's on R11, replaced your door lock wax motor as well at the board.
Jun 04, 2008 | Maytag Neptune MAH5500B Front Load Washer
Water problem with stackable Maytag Neptune
You have to make sure your self if water is getting through the hoses first.Remove the hot& cold hoses on the back of unit.Make sure there isn't a clog in side of the water valve screens ,if so clean them.Still not filling?Possibly a blown fuse.
Feb 09, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Maytag MLE2000 Front Load Stacked Washer / Dryer Logo
385 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
