Question about Garmin GPS 152 GPS Receiver
Garmin GPS 152
After a couple of minutes my GPS 152 screen shuts off and a line runs horizontal across screen with no other display
  • 1 more comment
  • captjbc Sep 25, 2008
    shuts off after couple minutes,i remove power cord from back of unit reinsert it works a few more minutes, after 10 or 12 times it finally stays on,dont know if i should get it fixed or replace it.
  • Kokomo36 Sep 27, 2008
    Same issue... I connected a spare unit and the same thing happened... Leads me to believe it's in the wiring harness. I'm only connecting power so that narrows it down. I have a sharp bend which may be an issue... I'll keep trying...
  • Anonymous Mar 23, 2014
    the screen does not display the menu
I had this problem and I contacted Garmin. It is due to the WAAS. You can do one of two things: 1) Purchase thier over priced cables so you can attach the unit to your PC and downlowd the updates, or 2) Turn it on, hit menu, disable WAAS. Now it works.
Jim
Posted on Mar 26, 2009
Try updating the software. The new WAAS signal causes some Garmin units to "go stupid" if the unit has old software.
Posted on Jan 14, 2009
I had the same problem so I replaced my 152 with a spare unit. It did the same thing. This led to believe it was the cable. I removed a few kinks and a bend at the unit; and it seems to be fine. Seems too simple and the bends were not that severe, but it is working (for now).
Posted on Oct 07, 2008
I have 5 white dotted lines running horizontally across my nuvi1490lmt. Does anybody know why this would be?
Yes, this is caused by a defective LCD display, There is nothing that you can do to make them go away. It is caused by a defective transistor in the LCD display logic that is either stuck on or off. The transistor controls a single horizontal line across the screen. The only way to fix this problem is to replace the display.
http://www.sharc.net/gps_LCD_repair.htm
Oct 26, 2013 | Garmin nuvi 1490T GPS Receiver
I need a Manuel for Garmin 1350
You can download manual (PDF) at
www.manualslib.com
And enter your device info Hope this helps
Nov 03, 2017 | Garmin Nuvi 1350LMT
Two horizontal white lines on top of display and one yellow line vertical trough display
Any lines on the screen that are not supposed to be there is an indication of a defective LCD display.
Jul 15, 2012 | Garmin nuvi 1450 GPS Receiver
My 3 year old Garmin Etrex Vista just started displaying horizontal lines across the entire display. Any suggestions?
Try updating the unit's software via the Garmin.com website. This may fix it as there was a satellite launched which was causing problems with some Garmin units.
Sep 25, 2009 | Garmin eTrex Vista GPS Receiver
Garmin Edge 305 will power off in a min or 2 riding in afternoon
This is a generic problem with the 205 and the 305 go to MTBGurublog and look up 305 problems there is a blog that shows how to open and fix it
Jul 07, 2009 | Garmin Edge 305 GPS Receiver
Garmin GPS-V freezes up
The update from Garmin seems to have cured the problem!! All I did was the reload.
Thanks velomaster!
I've had my Garmin GPS V for almost four years and loved it ... until the dreaded "black line" showed up. I considered replacing the unit but couldn't find anything that would give me the features the GPS V gave me (elevation, ground speed, grade change) and I didn't need a color screen display as an alternative. I'd even bid on a few replacement units on ebay. I was just about ready to bite the bullet, send it in to Garmin and swallow the $125 rebuilt charge when I ran across this thread. After the update it hasn't locked up and as a bonus I have more detail than I had before!
http://www8.garmin.com/products/webupdater/
If you have a GPS V you really do need to do this.
Mar 17, 2008 | GPS
Display problem
Have you tried resetting the unit? It sounds like you may have a problem that Garmin needs to address. I would try to reset it first, then make sure you have the latest firmware loaded on the unit. If you still have the problem, it may have to be sent to Garmin for repair.
Feb 07, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin GPS 152 GPS Receiver Logo
289 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
