Question about Toshiba 62HM95 62" HDTV
Toshiba 62hm95 BUS line,. what is a BUS line and how do I fix it?
My toshiba big screen is broke, I replaced the bulb and now the light blinks red in 1 second intervales in groups of four. The manual says it is the BUS line, what is a BUS line and how do I fix it?
  • amjr2003 Nov 18, 2008
    i haven't change my lamp yet but it looks fine to me,i got a green steady light and a red flashing light ...is it the lamp or what?
  • allmansfan Nov 20, 2008
    Well I got it fixed it was a balllis (sp?) But they dont just sell that part I had to get a whole new big parts for $750 and andother $300 in labor and diagnostics. Heard from the tech this tv has had lots of problems, which makes me feel so good that I spent $3000 on a television and have already replaced the loightbuld twice @ $200/bulb and now $1000 in repairs. I will never buy another toshiba
    Problem Solver:
  • 61 Answers
Allmansfan your problem could be a cable that needs to be reseated if you take back off first unplug it there is a DVI cable with screws unscrew it pul the cable off and blow it out with some air reseat the cable put it back together and yo should be good to go
amjr2003 take the lamp out and look at it you will be able to tell if it is bad blown,discoloration,bulges in the globe etc. if not you may have a lamp door switch that need s to be aligned look at it there is a screw work the switch around where it lines up with the post
Posted on Nov 19, 2008
I have a rear projection Toshiba model 62hm95. I have a rear projection Toshiba model 62hm95. I have a rear projection Toshiba model 62h
There is no bulb to replace on a rear projection set. It uses 3 separate picture tunes 1 red 1 Blu and 1 green coupled to magnification lenses that focus onto the mirror which the directs the image thru the screen. Access is usually by removing the trim ring and screen from the front. Access from the back only gains access to the circuit boards. Be very careful as each tube has its own high voltage transformer which can have from 50000 to 150000 volts.
Oct 07, 2016 | Toshiba 62HM95 62" DLP HDTV
My Toshiba 62HM95 62 in. HDTV DLP TV won't turn on...the green and red lights under the power button remain on and the red light flashes. How do I fix this?
Most likely, you need to replace your DLP bulb. The one that comes with your TV will last a few years max. The replacements seem to only last about a year. D:
Dec 08, 2010 | Toshiba 62HM95 62" DLP HDTV
Hi: My Toshiba starting showing the symptoms (as it has in the past) that it needed a new bulb. The red light comes on, is steady, but then the green light comes on and flickers. I have now put in 2 new...
I think that you have a problem with your ballast board this is the power source to the lamp if for any reason it starts to wear out or weak it will not be able to turn on your lamp check this link out it is about Toshiba lawsuit
http://www.avrev.com/home-theater-rear-projection-hdtvs/dlp-rear-projection-hdtvs/toshiba-ordered-to-pay-out-in-dlp-lamp-lawsuit.html
Sep 21, 2010 | Toshiba 62HM95 62" DLP HDTV
I put in a new light engine and a new bulb and no picture
U check the ballast?Replaced it might solved ur problems.
Apr 04, 2010 | Toshiba 62HM95 62" HDTV
My 62hmx95 tv power dont go on light just blinks i
hi , ther is a lock out switch which prevents the tv from operating IF the LAMP cover door is NOT in it proper secured place... Check this..MAke sure when replacing the lamp, the main power cord is unpluggged..
Mar 20, 2010 | Toshiba 62HM95 62" HDTV
Lamp went out & replaced it but no picture. Sound comes on!!!
you have a safty switch open most likely on the door you took off to replace lamp
Feb 03, 2010 | Toshiba 62HM95 62" DLP HDTV
Toshiba 52hm95 will not come on , red light blinks
It is the Light assembly engine. Happened to me It is $700 to fix and the wanartee on the new part is 3 mos
Aug 13, 2009 | Toshiba 52HM95 52" HDTV Projection...
Re: Want to buy bad light engine Toshiba 62HM95/62HMX95
Greg,
I had the light engine on my Toshiba 52HM95 fail. Sent it to a company Tri State Modules for repair. Got it back as good as new for $249.00. Goto tristatemodule.com. I hope this helps.
Aug 11, 2008 | Toshiba 62HM95 62" HDTV
White flash picture problems.
It may be your light engine.
Dec 30, 2007 | Toshiba 62HM95 62" HDTV
Toshiba 62HM95 62" HDTV Logo
208 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
