Whirlpool LSR7233E does not fill agitates right away
I have a Whirlpool Supreme 7 cycle 2 speed washer. At the beginning of the wash cycle the machine starts to agitate right away but does not fill with water. If memory serves, the cycle used to wait for the tub to fill before agitating.
Filling the machine manually with cold water will cause the washer to agitate and then stop, then agitate some more, etc. I can hear clicking noises ... sounds like some sort of solenoid going on and off. After a minute the washer will stop with a low buzzing noise. Letting the machine sit for 30 minutes allows the scenario to repeat.
Manually advancing the program to spin/rinse causes he machine to empty the water in the tub and enter the spin cycle. No rinse water is used but the machine does spin, emptying the water, then shuts off.
Any ideas how to fix
  • 1 more comment
  • Richard Burke Aug 24, 2008
    Verified the following at the pressure switch: 120V to purple and pink, no voltage to purple and tan while at the "fill" stage of the cycle.
    The hot and cold water lines into the washer have good pressure and the screens are clear.
  • Richard Burke Aug 25, 2008
    Using an ohm meter with power disconnected shows purple to tan is a
    closed circuit with no pressure. Purple to pink is an open circuit.
    Blowing into the switch does nothing. Confirms results from voltage
    tests I guess (diagnostic tests thanks to catriver). This means power to motor and none to water inlet I think.
  • jjmerritt340 Jan 18, 2009
    My kenmore 80 series is doing simular stuff. Mine fills and agitates at the same time.The water level switch will shut off when the water gets high enough. The agitation is very fast, faster than normal and faster than heavy duty..agitation is the same too fast speed at all settings. The problem started when Iafter I took the machine apart to clean it. Tub, pump,gear box and all.so what did I mess up?
watugot
  • 290 Answers
SOURCE: whirlpool gold top load washer (7 months old) won't agitate or spin
It sounds like the motor drive coupler has broken. This means the motor is no longer turning the gearcase, but it is turning the pump. It will be repaired under warranty if it is only 7 months old. You should have a full one year warranty on the washer. If not, he can probably fix it, but it will need a new coupler. He can tilt the machine back and see the coupler between the motor and transmission from underneath. I can walk you through replacing it if you want, but I wouldn't recommend it if it is still under warranty. There could possibly be something more major wrong that has caused it to break and some of the factory servicers are real picky about customers working on a machine under warranty. If you need it running tonight, he may be in trouble.
Post back if you need further help or have more questions.
Thanks/mike
Posted on Oct 21, 2007
SOURCE: Washing Machine will not agitate
coupler
Posted on Dec 19, 2007
how to take off agitator
Posted on Feb 10, 2008
SOURCE: Inglis Washing Machine agitator not working right
replaced timer problem solved thanks
Posted on Mar 30, 2008
IFIXALL
  • 868 Answers
SOURCE: Maytag Performa washer dead.
Your door lid has a switch that makes these functions work.First open the lid and look at the right side of it.Does it have a arm on it?If it does follow the direction where it is going to hit and now listn closely while your lifting the door up & down at this contact  can you hear it click?If its not clicking  or the arm is broken  off the lid replace  the lid switch/or the broken lid switch arm.
Posted on May 23, 2008
Whirlpool washer WTW57ESVW agitates right away (doesn't fill first)...any ideas?
My wife had the same problem and it had one other problem where it added water at the end of the spin cycle which left the washed clothes all wet. After doing some research on the internet I narrowed down the problem to two parts, auto-sensing switch or timer control. I called Whirlpool (800-253-1301) and ordered an auto-sensing switch (part# W10292584 which is replacement of W10177795 which is discontinued) and a timer control (part# W10177827) for $26.30 total at 75% off, plus $8.99 Fedex shipping and $2.12 PA sales tax for a grand total of $37.41. The original part costs were $65.62 and $39.60 respectively. I took the control panel off following the video from http://www.youtube.com/watch?v=9QELKlLEZeI and first tried the replacement timer and it made no difference, i.e. it still agitated immediately while filling and it filled at the end of spin cycle but only on the normal wash cycle which is on the top half. The agitation problem exists on all wash cycles except for the handwash option, but the filling problem at the end of spin cycle existed only for the normal wash cycle and not on any of the other 3 wash cycles. Then, I put the old timer back on and tried the replacement auto-sensing switch and that fixed the problem. I should have known that was the problem because when I was ordering the parts on the phone, the woman from Whirlpool told me they had over two thousand of the auto-sensing switches in stock and when I heard that I was thinking to myself "I don't know how many of these washers they sold, but that part must break a lot to keep that many in stock." I don't know how long ago the original auto-sensing parts were initially manufactured, but the Whirlpool parts website says that it's discontinued, so that only leads me to believe the original part wasn't very reliable to begin with. I called several local appliance repair folks and just to diagnose the problem, it was going to cost me anywhere from $75 to $100, so it was more cost effective for me to just buy the parts and tried them myself even though I ended up with a spare part (timer control) I didn't need.
Oct 07, 2010 | Whirlpool Washing Machines
Whirlpool top load washer no low-speed agitation. The unit fills, starts the wash cycle with normal agitation, but after a few minutes it just sits there soaking until the it's time to drain/spin. Drains...
Either the wire going to motor for non working speed is loose or damaged, or motor is bad. It could also possibly be timer not sending power to motor for that speed.
Sep 27, 2017 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a Whirlpool Heavy Duty-Super Capacity Plus, 7cycle/2 speed. Model LSR7200EQO , the agitator stopped working
My whirlpool heavy duty 2 speed 7 cycle washer machine stopped working, It fills up and aggitates for the first cycle then when it should drain and spin it doesnt drain nor spin
Jun 05, 2010 | Whirlpool LSB6200KQ Top Load Washer
The washing machinge is not completing the complete cycle
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Jul 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Stops in the middle of wash cycle
Hi!
If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool AWO3761 stuck mid-cycle
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • Jul 06, 2008 | Whirlpool AWM6100 Front Load Washer
    Agitator not working
    There are several things that can cause your machine to fail to agitate. First of all, you need to ask yourself a few of these questions:
    1. Does the washer fill normally, initiate agitation cycle and just the agitator is not moving? If so, the transmission and motor coupling are likely good and the agitator has probably worn out the dogs that cause it to grip properly. The agitator dogs will need to be replaced and you shouldn't need a new agitator. (rough estimate = $5.00 to $6.00).
    2. Does the washer fill normally, but stops when the agitation cycle is to begin? If so, I would suspect a faulty lid switch. The lid switch will allow the washer to fill, but will not advance the timer beyond that point on some models. (rough estimate = $35.00).
    3. Does the washer fill normally and makes a loud grinding noise when the agitation cycle begins? If so, I would suspect your motor coupling is bad and needs replaced. (rough estimate = $18.00 to $20.00).
    4. Does the washer fail to fill at all? If so, I would suspect a bad fill valve, pressure switch remaining shut off and/or timer. (rough estimate for fill valve = $35.00, timer = abt $100.00).
    These questions are not all inclusive, but these are some of the more common problems I have encountered. If you can provide me with a little more symptom elaboration, I can lead you in the right direction and get a part number and a better price for you. I will need your EXACT model number (located somewhere along the lid opening. Post back with your comments if you need my assistance. A good majority of the problems associated with Whirlpool top loaders can be easily repaired by the average consumer without assitance from a repairman. I hope this information is helpful to you.
    Jan 15, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    Washing Machines Logo
    289 people viewed this question
    Top Washing Machines Experts
