Is the p3001 bridageable?
The Punch P3001 is a 2 ohm stable monoblock amplifier. It therefore has only 1 channel. Not bridgeable.
Below are the specs off the rockford site.
Punch P3001 - 300 watt mono amplifier
150x1 @ 4 ohms, 300x1 @ 2 ohms, 12dB/oct HP/AP/LP crossover variable 40-400Hz, RCA inputs, RCA pass thrus, cast aluminum heatsink, military spec PCB, and remote Punch Bass EQ with 0-18dB @ 45Hz. H 2.4" x W 11" x L 11.7"
If you are using your amplifier at a 4 ohm impedance then you will only have 150 Watt delivered to your woofer or woofers. If you are running your amplifier at a 2 Ohm load you will be recieving 300 Watt to them. This however will also draw more current to deliver this power.
If you are certain that you can deliver the correct current to the amplifier and you are running a 4 Ohm configuartion. Then consult a Rockford delaer for a sub upgrade.
