Question about Pioneer AVIC-D3 Car DVD Player
Navigation my navigation system won't let me set an address.
  • djace1200 Aug 27, 2008
    A friend of mine removed the (East) Navi Disc while the truck was running to play his cd,when I put the Navi Disc back in it did not and has not allowed me to enter any address since: (street name) for my home state NY,but will allow other state adresses to be entered.I tried restoring fac set & hit the reset,no good.How can I reprogram the disc to allow NY info again?
  • 3 Answers
Try to reset the region meaning make sure the nav sys is set for ny state area.
Posted on Sep 18, 2008
How do I find my xbox 360s mac address
Hey there,
You can find your xbox's Mac address by going to the Dashboard, navigating to the 'settings' tab, go into 'settings', down to Network Settings, click on your active network and click "configure network", go into "additional settings", down and click on "Advanced Settings". There you will find your Xbox's Mac Address!
Dashboard>System Settings>Network Settings>'Chosen Router'>Configure Network>Additional Settings>Advanced Settings'
Oct 04, 2014 | Microsoft Xbox 360 Console
My DVD100 Navi gives me incorrect information about the position of the GPS location on the map. How can I change this? I changed the menu HOME for my address, but he can not give me that location as my...
I am glad to HELP YOU!
To get rid of the other FAVORITE WAYPOINTS all you have to do is to go in SETTINGS, then in FAVORITES and to DELETE the previous input addresses.
To have your address displayed go outside under the clear sky and let your device acquire as many satellites as possible; when it's done input your own address and save it as POI/FAVORITES.
GOOD LUCK!
# Windows Tips
Apr 24, 2011 | GPS
Trying to get xbox live but it states 'MAC' address, what is MAC address please?
A mac address is a unique code which identifies a piece of hardware. Sounds like your router is set up to only allow access to hardware that it has a mac address for, known as 'MAC address filtering'.
You could turn it off via your router's setup page, but it is there to provide an extra level of security, so it's best to leave it on.
You can find your xbox mac address by following these instructions
1. Navigate to the System area of the Xbox Dashboard.
2. Select 'Network Settings'.
3. Select 'Edit Settings'.
4. Select 'Additional Settings'.
5. Select 'Advanced Settings.'
The MAC address will be displayed toward the bottom of this page where it says 'Wired MAC Address'.
Feb 05, 2011 | Microsoft Computers & Internet
How can i conect to the internet with my sony psp
1 First, let's take a look at your router setup. In order to do this, you need to open a new, empty browser window on your PC, and you need to enter the IP address of the router itself. Generally, this should look like this: link You should preferably use Internet Explorer to do this. If this address does not direct you to your router, your router may have a different address. In order to get this, you should first attempt to run the set-up program on your router's disk. You may be asked for a password before you are able to directly access the router. Commonly, the username and password are: admin/password. However, if you do not know your username and password for the router, you may need to reset the router physically. Click here to go to Router Troubleshooting below to do this.
Have you connected to your router?
Yes, I have connected to my router - proceed to step 2 below.
No, I have not yet connected to my router - proceed to Router Troubleshooting below.
2 Now that you are connected to your router, let's examine some of your settings. Navigate within your router's settings dialog and locate "Wireless Settings" (or similarly titled).
3 Verify that you have been assigned an SSID.
4 Verify that your region is correct.
5 Verify that you are on channel 11. (This may be different. If so, make sure your PSP is on the same channel as well.)
6 Verify that "Enable Wireless Access Point" is enabled.
7 Verify that "Allow Broadcast of Name (SSID)" is enabled
8 Under "Security Encryption (WEP)", set authentication type as "Open System". Set Encryption Strength as "Disable" . (If you enable encryption, see the next step.) Otherwise, continue to step 10. If you experience problems, you need to reduce your encryption to 64 bit.
9 Under "Security Encryption (WEP) Key", select "generate". Make note of the generated key. Be sure to click on "Apply" or "Finish".
10 Click on "Wireless Card Access List" if available. You may be prompted again for your password.
11 Be sure that "Turn On Access Control" is disabled.
12 Is your PSP listed here? If not, then do the following: On your PSP, navigate to "System Settings" Then navigate to "System Information". Make note of your MAC address.
13 In "Wireless Card Access List" select "Add". You can figure this out by yourself, can't you? If not, then enter your PSP's MAC address as you've noted it. Be sure to hit "Apply" or "Finish" when you are done.
14 Under WAN settings, verify that "Connect Automatically, as Required" is enabled.
15 Under"LAN TCP/IP Settings" make note of all of the information included. You may need this later. You may not, but it's a good idea to take note of it now.
16 Under "Router Status" make note of all the relevant information included here as well. You may or may not need it.
PSP Setup
1 Turn your PSP on if you haven't already.
2 Ensure that your WLAN switch is turned on.
3 Perform a factory reset. In order to do this, select "Settings", then select "Restore Default Settings". You will not lose any information or data by performing this step. However, you may need to reset your wallpapers. Set your name, date, time, etc.
4 Power down your PSP. Wait 10 seconds, then power it on.
5 Navigate to "Network Settings".
6 Select "Infrastructure Mode"
7 Select "New Connection" Name this connection as you deem appropriate.
8 Navigate to "WLAN Settings" Select "Scan".
9 Your router should now be listed. If it is, proceed to step 10. If it is not, and you followed all of the steps so far, then something is wrong with your PSP, or the settings, or a combination of both. See Router Troubleshooting and PSP Troubleshooting below.
10 Navigate to "WLAN Security Setting". If you did not select encryption in ROUTER SET-UP, step 8, then leave the option as "None"
11 If you selected encryption in ROUTER SET-UP, step 9, then select the appropriate WEP, or WPA..
12 Navigate to "Address Settings". Select "Easy"
13 Navigate to "Setting List". Verify that your settings are correct.
14 Navigate to the next screen and press X to save your settings. You should get a message that says "Save Completed. Test Connection". Press X.
15 You should get two quick display messages. The first should say "connecting to access point." The next should say "obtaining IP address".
Yes! If you got these messages, and are now able to connect to the internet then congratulations! Now, go use your PSP to do the same thing you can do on your PC now, only smaller and slightly slower.
Dec 04, 2010 | Computers & Internet
I cannot get the printer on my network. What settings must I use with DHCP to automatically pull the IP address and be identified on the network? HP 5100 dtn
On the control panel, navigate to the Configuration menu and within it, to the EIO menu. Navigate to CFG NETWORK and select YES. Navigate to TCP/IP and select ON. Navigate to CFG TCP/IP and select YES. Navigate to BOOTP and select NO. Navigate to DHCP and if you want automatic IP addressing, select YES. If you select NO for DHCP, you will be able to manually set the TCP/IP parameters, including IP address, subnet mask and default gateway.
Nov 05, 2010 | HP LaserJet 5100dtn Printer
I want to change password for wifi network
Open up an Internet browser window on your computer system. To gain access to the default settings, type in the default IP address of the wireless router in your Internet browser's address bar and press enter. You must refer to the wireless router's documentation or navigate to the manufacturer's website for the correct IP address.
Type the default user name and password in the security dialog box that appears, then press Enter on your keyboard. Because different router manufacturers use different default user names and passwords, refer back to your router's documentation or support webpage for the correct information.
Navigate through the router administration pages to find the wireless router's administrator password settings. Change the default user name and password to a unique set so that possible unauthorized access to your router settings will not take place. Make sure to hit "Save Settings" to complete the change.
Set up your wireless security settings by navigating to the proper administration settings page. By default, wireless routers do not come with a password for connectivity access. Choose the appropriate wireless security level you need and type in a unique user name and password. Save these new settings and log out of the router's administration setup.
5
Write down the user names and passwords for both network access and the administration setup page. Keep these user names and passwords in a safe place.
Thanks.
Have a great day.
Oct 14, 2010 | Computers & Internet
Display language settings - AVIC-DRV22 Pioneer system
go into the settings or options menu in the navagation screen and hit languages then hit english...u may have to google the words language and settings in japaneese to compare
Jun 06, 2009 | Pioneer AVICN4 In-Dash GPS Navigation...
I need to open my Nat for Xbox live. Please Help!
Configuring Your Dell™ TrueMobile™ 2300 Router for Gaming
Follow below steps to set up the router for gaming:
  1. Select the system or systems to be used as game systems.
  2. Locate the MAC address. For Windows 2000 and XP
    1. Click Start -> Run.
    2. Type cmd, and click OK.
    3. On the command prompt, type ipconfig /all
    4. Write down the MAC (Physical) address of your computer to configure for gaming.
  3. Open the web browser, and type http://my.router (or http://192.168.2.1)
  4. Click the Advanced Settings tab.
  5. Click the DHCP Server Settings tab on the left navigation bar.
  6. Click Add button in IP Address Reservation,
    1. Enter the MAC address of the system you wish to use for gaming in MAC Address field.
    2. Enter an IP address for the system (select a number between 101 and 254)
  7. Click Submit.
  8. Click the Port Forwarding Settings tab on the left navigation bar.
    1. To set a single computer for gaming, check the Enable DMZ Host box.
    2. Enter the IP address of the system at DMZ IP Address field.
    3. Click Submit.
      note.gif NOTE: Only a single computer can be set for DMZ service. To set multiple computers for gaming, please post your query again
  9. Reboot the client system. The client system will use the newly assigned IP and will not have any TCP/IP ports blocked by the firewall feature of the router.
May 18, 2009 | Dell TrueMobile 2300 Router (000001)
Pioneer AVIC-D3 Car DVD Player Logo
109 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
