Question about Casio Boss Business Organizer
Casio boss 5300 questions
Help!!!
can not see anything on the screen unless I turn the unit away from me on an angle. Will not take any input or bring up any info. Where can I get another owners manual? Took out dead batteries after 5 years, all at once and replaced all at once. Sorry. Reset. Nothing is happening!!!
What is this thing worth?
Thanks for your help.
Love,
Susan
Would like to download my SF5300B to my PC. Do you have any connection to do this task, or any other cable to use to download.
Thank you.
My e-mail is gyorgy@bellsouth.net
Posted on May 21, 2009
If you can see something when you turn it at an angle I would suggest turning the contrast dial to see if visibility improves. As far as a copy of the manual, I found one here:
http://servicemanuals.electronica.ro/manuals/casio/SF-5100_SF-5300.pdf
Good luck.
Posted on Oct 08, 2008
Hi i have a boss dvd in dash 996b in a 2002 nissan altima....always worked good ..i wired the pink wire to the fram to ground out ...always worked...i open dvd to watch movie and display shows NO VIDEO...
have you tried a different video input such as a video input behind the radio. have you made sure that you are playing dvd and not video in. or the boss unit could be broken.
May 05, 2011 | BOSS AUDIO SYSTEMS Car Audio & Video
When i turn it on it always appear f(X)= and on the sop the letter R and the word Math and i don't know how to chage it back to the normal one
The R at the top of screen reminds you that angle unit is in Radians. The MATH says that the Input/Output mode is MathIO. In this IO mode, fractions are stacked (2levels) as in textbooks.. The R setting should not bother you unless you are doing trigonometry problems (in which case set the appropriate angle unit). The MathIO allows you to do exact calculations with fractions and radicals. Beside you can always convert fractions ad radicals to decimals.
As to the f(x)=, I believe you have changed the computational setting from COMP (usual) to TABLE. In table mode you supply a function and the calculator generates a table of values.
To recover the normal mode COMP, press MODE and select COMP (should be the choice 0:COMP).
Oct 08, 2010 | Casio fx-300ES Calculator
I need to change the date on casio cash register SE-5300 that has been set wrong
I Suppose that is Casio SE-S300 Model :
To change Date,
1. Key turn to PGM
2. Press [1] [Subtotal]
3. Input today's date, eg : 8 March 2010
Press [1] [0] [0] [3] [0] [8]
4. Press [X/Date/Time]
5. Key turn back to REG
6. O.K.
Feb 28, 2010 | Casio Boss Business Organizer
Trying to obtain a manual for the SF-5300.
On the back battery cover there is a reset button,just push it w/a toothpick or pencil point. It will reset you B.O.S.S. so you can re-enter info. I've had mine since '00 e-me @ icabod39@att.net if I can help or confuse you more. Good luck! P.S. I'm not assotiated with casio.
Jul 13, 2009 | Casio Boss Business Organizer
Problem with Casio FX 260 Calculator
Read the screen capture about the MODES of this calculators. DEG,RAD, and GRAD remind the user that the angle units in trigonometric function calculations and coordinate conversions are in degrees, radians or grads. They have nothing to do with the other calculations you are doing.
You can only remove DEG by changing the angle unit to RADians or GRADs. In so doing, the new unit indicator (RAD, GRAD) will be displayed instead. There is no point worrying about the angle unit indicator unless you are performing coordinate conversions or calculating trigonometric functions or the inverse trigonometric functions.
MODE 9 cancels the FIX display format: decimal are displayed with a fixed number of decimal places (set by the user). After this key sequence the decimal display format reverts to NORM(al).
Dec 03, 2008 | Casio FX-260 Calculator
Casio BOSS 5300
I would suggest doing a "Reset". You will loose all your data, but at least you will be able to use it. You do a Reset by removing the bottom case, turning on the BOSS, them pressing the Reset button located inside.
Jul 21, 2008 | Casio Boss Business Organizer
Casio BOSS SF-5300
Once the DATA ERROR DISPLAY appears,You will not be able to INPUT or EDIT DATA, though you will be able to recall Data after pressing CLEAR to clear the error message.**YOU WILL
WANT TO SAVE ALL YOUR DATA OR WRITE EVERYTHING DOWN AT THIS POINT, BECAUSE THE ONLY WAY TO GET
THIS DEVICE BACK TO NORMAL OPERATION IS TO PRES RESET IN THE BACK -IF YOU PRESS RESET YOU WILL LOSE ALL INFORMATION PERMANENTLY.
In order to return the memory to normal (allowing further input and editing of data), you must perform the RESET OPERATION to clear the memory of all data-Make sure you have backed up or taken a hardcopy of this information before Resetting or it will be gone and there is nothing you can do to get it back.Once you have RESET you can re-input the data you have written down.
WHAT CAUSES THE ERROR MESSAGE?Interruption of battery power.Severe electrostatic charge,impact,change in temperature
or humidity.Hardware Problem.
Recommendations:Replace batteries every 2 years, regardless of use.Use only CR2032 Lithium batteries.Replace all batteries-Never mix old ones with new ones!
Caution: All data stored is lost if you remove more than 1 battery at a time. The following Info is per the instruction manual-WHICH ALSO SAYS :Be sure you keep a separate copy of all important data that you store in the SF-5100/SF-5300.Hope this helps.
May 28, 2008 | Casio Boss Business Organizer
316 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
