Question about Olympus Camedia D-425 / C-170 Digital Camera
Telephoto images What options do I have for telephoto images?
    Master:
  • 852 Answers
The D-425 camera has a 4x “seamless” digital zoom. Press the Zoom button with the “T” on it, which also has the magnifying glass icon next to it and a zoom indicator will be displayed in the upper right corner of the LCD. The “W” represents a wider area of view as you zoom out, and the “T” represents Telephoto as you are zooming in closer to the subject. images taken in the digital zoom may appear “noisy” or “grainy”, which is normal when using the digital zoom
Posted on Aug 31, 2005
SOURCE:
What size lens do i need for this camera?
You just need any Minolta AF mount lens. Sony Alpha lenses also physically fit as Sony inherited the Minolta lens mount when they bought the company, but as they are a later development not all will be electronically compatible.
The size of the lens depends upon the focal length of the lens and you choose that according to how wide a field of view you desire. Typical lenses are 28 and 35mm wide angles, 50mm "standard" (approximately the same perspective of how the human eyeball sees images), 70 to 90mm short telephoto lenses (a narrower perspective and very good for portraits) and higher numbers are narrower perspective telephoto lenses for viewing increasingly distant objects. In practice, the available lenses will be incorporated into zoom lenses which incorporate a seamless range of focal lengths within one single model. The word "zoom" reflects the fact that you can seamlessly change from say 28mm wide angle through to 80mm short telephoto and every single setting between them
Any zoom which starts at less than 50mm and finishes in the short telephoto range is called a standard zoom and is the lens that most autofocus cameras were supplied with. The next most common size will be something like a 70-200mm which is a telephoto zoom (or tele zoom) and takes you from a portrait lens to a genuine 5x magnification telephoto. You may also find so-called "super zooms" which do the whole job on one, for example 28-200mm. but the more jobs a single lens tries to do, the bigger and bulkier it becomes and the image quality deteriorates due to poorer contrast and greater image distortion at each end of the zoom range.
This is not an exhaustive answer, as there are entire books on the subject, but hopefully it's been of help to you.
Please take a moment to rate my answer or to add a comment if my answer has left you with unanswered questions which need to be resolved before you can rate my reply.
Feb 18, 2011 | Minolta Maxxum 400si 35mm SLR Camera
Optical / Digital Zoom
Press the "T" for telephoto and get closer to the subject. Optical telephoto zoom is like using a telescope to get closer to the subject before taking the picture. With optical Telephoto zoom you can maintain the full resolution and quality. After you have used all of the optical Telephoto range, the camera will continue to enhance the image with Digital Zoom. This enhances the image inside the camera by reducing the resolution and expanding fewer pixels to fill the same image space. Use the "W" Wide-angle button to back-up away from the subject or get a bigger area into your picture. You can even ZOOM IN on a picture in the playback mode for a better look at the details. Touch the Magnifying Glass Icon. Use the Arrow Keys to move around the display area.
Sep 11, 2005 | Toshiba Sora PDR-T20 Digital Camera
Press the "T" for telephoto and get closer to the subject. Optical telephoto zoom is like using a telescope to get closer to the subject before taking the picture. With optical Telephoto zoom you can maintain the full resolution and quality. After you have used all of the optical Telephoto range, the camera will continue to enhance the image with Digital Zoom. This enhances the image inside the camera by reducing the resolution and expanding fewer pixels to fill the same image space. Use the "W" Wide-angle button to back-up away from the subject or get a bigger area into your picture. You can even ZOOM IN on a picture in the playback mode for a better look at the details. Turn the Mode Dial to Playback, then press the "T". Use the Enter button to move around the display area. Press the middle of the ENTER KEY to see your images in thumbnail view and / or scroll through several images at one time to find a specific / special image quickly.
Sep 11, 2005 | Toshiba PDR-3330 Digital Camera
Sep 11, 2005 | Toshiba PDR-3300 Digital Camera
Options for telephoto zoom
The Stylus Verve has a 2x optical zoom and a 4x digital zoom, which gives you a total zoom of 8x seamless zoom. Use the shooting mode menu to activate the digital zoom feature.
Sep 01, 2005 | Olympus Stylus Verve / ?-mini Digital...
Telephoto images
The D-630 has a 3x optical zoom and a 4x seamless digital zoom. In order to use the digital zoom, press the OK/MENU button on the back of the camera. Press the right arrow key to access the Mode Menu. The first setting under the CAMERA tab is DIGITAL ZOOM. Press the right arrow key to highlight this setting and then press again to select ON. Press the OK/MENU button to set the DIGITAL ZOOM to remain ON. When you press the zoom button with the T on it, a zoom indicator will display on the right side of the LCD. The W represents a wider area of view as you zoom out, and the T represents telephoto as you zoom closer to the subject. When the zoom indicator is in the red zone, you are using the digital portion of the zoom. images taken in the digital zoom will appear “noisy” or “grainy” which is normal when using the DIGITAL ZOOM.
Sep 01, 2005 | Olympus D-630 Zoom Digital Camera
Telephoto images
The D-595 Zoom camera has a 3x optical zoom coupled with a 4x “seamless” digital zoom to deliver a total 12x zooming feature. Press the Zoom button and a zoom indicator will be displayed in the upper right corner of the LCD – the area in white represents the Optical Zoom range and the red area represents the range of the Digital Zoom. The W represents a wider area of view as you zoom out, and the T represents Telephoto as you are zooming in closer to the subject.
Sep 01, 2005 | Olympus D-595 Zoom Digital Camera
Telephoto images
The D-545 Zoom camera has a 3x optical zoom coupled with a 4x “seamless” digital zoom to deliver a total 12x zooming feature. Press the Zoom button and a zoom indicator will be displayed in the upper right corner of the LCD – the area in white represents the Optical Zoom range and the red area represents the range of the Digital Zoom. The W represents a wider area of view as you zoom out, and the T represents Telephoto as you are zooming in closer to the subject.
Aug 31, 2005 | Olympus D-545 Zoom Digital Camera
Options for more telephoto zoom
The D-535 Zoom camera has a 4x digital zoom in addition to the 3x optical zoom, which gives you a total of 12x zoom overall. Press the Zoom button and a zoom indicator will be displayed in the upper right corner of the LCD – the area in white represents the Optical Zoom range and the red area represents the range of the Digital Zoom. The W represents a wider area of view as you zoom out, and the T represents Telephoto as you are zooming in closer to the subject.
Aug 31, 2005 | Olympus D-535 Zoom / C370 Zoom Digital...
Telephoto images
The D-435 has a 4x seamless digital zoom. Press the zoom button with the T on it and a zoom indicator will be displayed in the upper right corner of the LCD. The W represents a wider area of view as you zoom out, and the T represents telephoto as you zoom closer to the subject. images taken in the digital zoom may appear “noisy” or “grainy,” which is normal when using the digital zoom
Aug 31, 2005 | Olympus Camedia D-435 Digital Camera
Olympus Camedia D-425 / C-170 Digital Camera Logo
69 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
