Question about True GDM-26 Refrigerator
Replacing a temp control valve on a true GDM 26 commercial refridgerator
I have a True Model GDM 26, and I need to replace the temperature control valve. The plate with the control knob is on the upper right had side, and it looks like it has only two bolts and two screws. on the plate it says remove plate on evaporator top side. I don't know what this means. Can't I just remove the plate with the control knob and replace it, or is there another plate on the top somewhere that has to be removed? i would appreciate an answer to this question.
Thanks,
Rocco
  • Anonymous Mar 22, 2014
    what do the letters on the digital control mean
    Novelist:
  • 112 Answers
Unplug the unit & remove the plate holding the thermostat. The capillary for the thermostat will go into a very small tube that runs into the evaporator coil. You will probably not be able to see the tube but will have to feel for it and get a good orientation for where it is located before you pull the capillary out. Try to measure the amount of capillary in the tube as you pull it out so you know how far you have to push the new one in and put some kind of tape or mark on the new capillary before you try to push it in. you might have to soap up the capillary to get it to slide easier.
Posted on Jul 07, 2009
Yes just remove the plate & pull the wires out with temp control line
Posted on Sep 13, 2008
Ajust temp on true gdm 26 f
Hello Tam;
My name is Peter. I am a retired field service refrigeration technician.
The following manual link has the instructions for adjusting your unit temperature.
http://www.truemfg.com/assets/InstallationManuals.../GDM/gdm_english.pdf
Jan 24, 2015 | True Refrigerators
Hello Tam;
The following manual link has the instructions to adjust your temperature. You may also have a bad fan or thermostat.
How do i chage the temperature on a true cooler gdm 49 florial cooler
True GDM-12 Refrigerator... Repair Questions - Fixya
www.fixya.com/support/p22955-true_gdm_12_refrigerator_commercial
Recent True GDM-12 Refrigerator Commercial questions, problems & answers. ...Where is the temp control on the older (14 yrs or so) on GMD-12? True ..
Aug 16, 2014 | True GDM-12 Refrigerator Commercial
I have a True GDM-26, that I determined had a bad temp control. I ordered a new control from a company the referenced the part number by unit model number. I did not take the original control to match. ...
the temperature control you need is a part# 800386. the one you got(800393) is a temperature control for a 230 volt cooler not 115 volt. it is a 230 volt control
Aug 06, 2011 | True GDM-26 Refrigerator
We have a GDM-26 commerical coke machine. Only
If any of your drinks are freezing you need to adjust your temp setting. The suggested setting is 5. changing the temp setting basically tells the refrigerator to stop cooling when the temp hits a low degree, and to start cooling when it hits a high degree. This keeps your drinks not to hot, not too cold, but just right. If this doesn't work I would change the cold control altogether, it might've went bad. If you have a few minutes, locate the condensor fan (bottom) and make sure it is periodically turning on and off like it should.
Jun 08, 2009 | True GDM-12 Refrigerator Commercial
GDM-26 humidity very high
assuming fridge is at correct temp, i suspect fault is with your humidity detector. the humidity inside a fridge is a lot less than the outside air
Oct 09, 2008 | True GDM-26 Refrigerator
True GDM-26 Refrigerator Logo
836 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
