Driver for lexmark Z22 printer. I have disc which I used to install driver on a deminsons 6-7 years ago. M E software. Will that disc work with the new vista software.
Vista sucks
Posted on Sep 09, 2008
  • 6,487 Answers
This printer that you have is not compatible with Vista that's why the setup Cd is not working and there's also no software upgrade that Lexmark created so it will work with Vista , This is the complete list lexmark printer that is compatible with Vista,6959,204816596_924205346_924205387_en,00.html
Hope that helps...............
Posted on Aug 24, 2008
Yes it will work because vista has an Evan higher bit rating at 64bits it can have any windows program installed on it as long as it has over 512mb of ram and enough storage for the program .
Posted on Dec 17, 2008
After upgrading to window 7, 2 printers, Lexmark z22 & hp deskjet 1120c will not allow print request out of the quew even tho the printers are listed as compatible by window 7
Not compatible or not working well with windows 7?
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:)) julyallan01_52.jpg
Oct 11, 2010 | Lexmark JetPrinter Z22 Color InkJet
How do I install Lexmark Z22 onto my Windows XP Pro computer?
Download the driver from the lexmark website located here.
After you download it then go into the add printer wizard and install the driver from there.
Sep 22, 2010 | Lexmark JetPrinter Z22 Color InkJet
I have installed a lexmark z22 printer but it
Try the following check-lists
1.Initially ensure correct drivers are installed in the operating system you are using .This can be checked by seeing in the device manager or in the control panel-->printers and drivers option.
If drivers are correctly installed you will the printer symbol in printer options with the name of the printer.
Right click the printer and give test page as print
If the print is not working check whether the power cables and connecting cables are good.
Check the indicators in the printer does it shows any warning.if you have manual of printer you can verify from it
Mar 10, 2010 | Lexmark C533DN InkJet Printer
I want to install lexmark z22 without cd. how can
You could try going to and see if tey have any way of doing it on line otherwise you may have to purchase a disc from them. Most printers you can get updates and drivers (sometimes) on line otherwise you need the actual disc to install the printers on your computer.
Nov 12, 2009 | Lexmark JetPrinter Z22 Color InkJet
Lexmark all in one printer don't install on vista. is there a patch
You may want to see if the Printer is actually compatible with Windows Vista first before you try anything else.
If your Printer is Listed Below, then unfortunately it will not run on your system unless you format the machine and downgrade to Windows XP. (Or obviously you can wait until the device is supported, but to be honest that could be months, years).
  • Lexmark Z11, Z12, Z22 & Z32, Z31, Z42, Z51, Z52 - work with pre-installed drivers
  • Lexmark Color Jet 3200, 5700 - work with pre-installed drivers
  • Lexmark X5400, X4200, X1200, Z645, Z840, Z730, X2400, X3400, P350, X7300, X8300, X9300
  • Lexmark X1100, Z500 & Z600 (combined), P4300, X3300, X2300, X7100, Z810, Z700, X5200, P6300, P910, P6200, X6100, X5100, X2200
  • Lexmark 1100, 1200, 2400, 3400, 4200, 5400 Series, Lexmark X7350, X8350, X9350, P350, Lexmark 640 Series, Lexmark 730 Series, Lexmark Z845[4]
Dec 04, 2008 | Laplink Software PCmover for PC
Add Printer
The Z22 does not appear on Lexmarks vista compatability list and so there is no specific vista driver.
There is a driver for Windows XP which you could try
Select Z22 as printer model and search
then choose windows XP from the list of operating systems
Nov 23, 2008 | Office Equipment & Supplies
How can i download the CD software.
Here is the download page from Lexmark (click here).
Unplug printer USB from computer.
Chose OS version and download the driver.
After downloading run installer file, this will start printer setup wizard.
Connect printer back when required from setup wizard.
Don't forget to rate the solution.
Aug 28, 2008 | Lexmark X4270 All-In-One InkJet Printer
Lexmark x1270 all in one printer will not install
windows xp home edition has problems running a lexmark, the xp pro dont its a windows problem do you have xp if so when it says needs install dont use the disk let the set up wizard take you to a site to down load the drivers i had to do the same with my X1150 all in one.
Dec 20, 2007 | Lexmark X1270 All-In-One InkJet Printer
The spooler service can be started following these directions.
Go to start
Go to run
In the open box type: <cmd> without <>
When the command prompt opens
type: net start spooler <Enter>
This should say that the spooler has started successfully.
Jess01: A driver is basically a communication device between your print device, which is your hardware "meaning can touch it" and printer software that is the language that your print device and computer can read. Your USB cable let's the computer know that your printer is connected. The software is needed so the printer has the language to be able to print what you tell it to.
If you have windows 2000 or xp.
Go to this website.
Scroll down the page 'til you find Lexmark Z22 Color Jet Printer
To the right you will see "download"
Click the link.
Scroll to the bottom you should see "Please enter verification code"
Type the code in and click "download"
Click save.
The software should then be downloaded to your computer.
Go to the location you saved the printer drivers.
There should be a setup file.
Click on that.
The printer should then be recognized and you should be prompted that the printer is going to print a test page.
Nov 05, 2007 | Lexmark JetPrinter Z22 Color InkJet
Lexmark z25
Use the Vista pre-installed Lexmark Z22-32 ColorJet printer driver. If that does not work, use the Lexmark Z12 ColorJet printer driver, listed below the previous driver.
Aug 19, 2007 | Lexmark JetPrinter Z25 InkJet Color...
Open Questions:
Computers & Internet Logo
900 people viewed this question
David Payne
David Payne
