Question about Dryers
Recently bought a used dryer, which works fine, however, the outside (cabinet) of the dryer gets extremely hot to the touch. Is this normal, I don't remember this happening with my other dryers.
  • Ian Greenland May 11, 2010
    what brand and model
The dryer that gets very hot on the outer cabinet is a GE, it was manufactured in 2002. I hope this helps, Thanks
Posted on Sep 03, 2008
Bought an upright Frigidaire Freezer on Craigslist and the inside gets cold and works like a champ but the outside side panels get very hot- is this normal or is there a short?
If there is a short circuit, the circuit breaker protection in your house wiring would trip (Open the electrical circuit path).
It is normal for the condenser, which is on the outside of the appliance to be hot because it is transfering the heat from inside the freezer cabinet to the ambient air outside the cabinet. Make sure that you give the appliance enough space all around the hot condenser so that it can transfer its heat to the surrounding air efficiently.
P.S. Some freezer designs integrate the condenser coils into the metal cabinet, thus the hot side panels.
Aug 28, 2011 | Frigidaire 14 cu. ft. / 396 liter Upright...
Dryer is extremly hot to the touch, condensation on cabinets and walls in the laundry room it gets so hot in there when dryer is running
Usually when an electric dryer overheats it's because of a defective cycling thermostat or a clogged vent system. Clean any lint from the internal and external ductwork, and/or replace the cycling thermostat. What is your model number?
Nov 28, 2010 | Electrolux Dryers
Just bought a new HE5 dryer three days ago and used it for the first time---the sides of the HE5 dryer are extremely hot (could burn hand), is that normal and what could be the cause?
check the vent line,could be clogged with lint if you never cleaned it,you should clean out your dryer every year by taking off and cleaning out the duct that the lint filter slides into,vac out the inside of dryer and clean out the vent line,if it's a long run from the wall to the outside vent hood blow it out with a leaf blower,go outside and make sure the air is blowing out with force,all a dryer does is move air and if something is blocking the air flow the dryer will get hot,you'll start blowing thermostats or the thermal fuse because they are safety switches so if the dryer does run to hot they pop and shut down the dryer so hopefully you don't have a fire or damage the dryer
Jan 10, 2010 | Kenmore HE5 Electric Dryer
Kenmore dryer surface gets extremely hot when
Classic of a clogged vent to the outside, Air out back of dryer should be same outside. Dryer will get hot and take to long to dry clothes with a clogged vent. Pls leave a FIXYA rating.
Aug 24, 2009 | Kenmore 63942 Dryer
We just bought this dryer and after drying a load I touched the top of the dryer and it was incredibly hot? is this normal?
Check your vent it may be stopped up this will cause the top to get overly hot and the bearing to squeak
May 31, 2009 | Frigidaire GLER341A Electric Dryer
My dryer PYE4557AYW,gets to hot! When U touch below the door??
it sounds as though the heater protection thermostat is stuck closed and wont regulate the heating
May 02, 2009 | Maytag PYE2300AY Electric Dryer
Very hot to touch on top
Sounds like you have a clogged vent hose or clogged duct work leading to the outside of the home. Make sure you have no obstructions in the exhaust system including a functioning flap on the outside wall cap.
Jan 03, 2009 | Frigidaire GLER341A Electric Dryer
Dryer too hot
You will want to make sure the lint screen and vent are free and clear.
If the dryer is blowing out the vent outside the house as it should, then you have a thermostat problem.
If the operating thermostat does not open properly then the element will cycle by the hi-limit thermostat which will cause the dryer to heat more than normal.
Nov 24, 2007 | GE DWSR405EBWW Electric Dryer
Dryers Logo
173 people viewed this question
Top Dryers Experts
