Question about Zenith L15V26D 15 in. HDTV-Ready LCD Television
Can not get tv stations above chanel 13
I suddenly can not get channels above 13-----my other TVs work fine-----what should I do
Switch To CAtV, You have setting on Antenna
Posted on Dec 01, 2008
Emerson tv 32 in --the channel 7.1 ABC only has picture without sound.
Check the Chanel 7 broadcast signal on the other tv have sound,could caused by the tv broadcasting signal from the tv station itself.Check if ur tv have a function known as S.A.P. make sure it is off,could effected no tv audio problems,because the tv station in ur city or town don't broadcast in that signal frequencies.
Feb 24, 2013 | Emerson Televison & Video
Cant change channels with remote or side of tv - sound works fine . stuck on espn - no other channels work (i quess being stuck on espn is fine but this is an office tv for thr girls while they are eating...
Your TV is most likely locked to that station because it doesn't have any other channels programmed in.
In the menu for the TV, run a channel scan. This will take probably 30-45 minutes for most TVs and will program the available channels into the TV so that they become available.
Mar 15, 2011 | Vizio VO47L 47 in. LCD TV
I have an electron TV that is set for 13 chanels, I want to reset it so I can use chanel up and down to the 60 chanels I have.
Try going to the SET UP option on your tv's MENU.
Look for the CHANNEL SET UP option.
Make sure the CABLE option is turned ON.
Let me know if that works.
Good luck.
Jan 20, 2011 | Televison & Video
My TV Sharp 26 SB1 LCD PBS channel breaks up
Do any other OTA channels break up on this TV? Look through your setup options menu for a TV reset (memory or restore default or a similar command) . Do the reset and exit the menus (save the action on most TVs); then return and rescan the OTA channels.
On a different brand of TV this worked. The channel had broken up for several weeks; the reset was used when the channel finally became totally corrupted (no video on one sub-channel, no audio on the other).
Some tuners need a stronger signal to be stable; you may need an amplifier on your antenna.
I hope one of these ideas helps.
May 01, 2010 | Sharp Televison & Video
Chanells 50 and Up "Erased" how to Undo that
one is to go to menu and auto search the channels. but if your state is now digital programming then you need a convertor box to get local stations.
Feb 23, 2010 | RCA E13309 13-Inch Diagonal XL-100 Color...
No sound on four channels while all other channels sound is fine.
You most likely have the SAP1.gif mode activated. Look for a button on your remote or an item in the on-screen menus of your television1.gif called MTS or SAP. You want to set this to "Main" "Normal" or "Stereo" (or even "Mono") mode to hear the regular television sound.
If it is in SAP (Secondary Audio Program) mode, as I believe yours is, you may hear no sound or a different audio program. Often this is a translation to another language, such as Spanish, and other times (notably with PBS stations) it is an unrelated audio (often music) feed. On some stations there may be no sound at all with the audio mode set to SAP.
Feb 14, 2008 | Sharp Aquos LC-13SH3U 13 in. EDTV-Ready...
Chanel will not go up or down.
George, your tv`s tuning system is set to "air", (roof top antenna) you need to go into your menu and change it to "cable", then do "autoprogram" again and it will add the channels above 13. You really should order the original remote for yourself, you can probably get one here; www.partstore.com Good Luck and Happy Holidays
Dec 04, 2007 | Toshiba 20AF41 20" TV
Tv channels
Probably, at first you searched the programs in automatic way. And there were only 20 channels at that time. So, you only have 20 channels. You should try to search channel 21, 22, 23, etc, manually. If you can't set 21 on your program, then your tv set has only 20 programs.
Nov 11, 2007 | Samsung CXJ1352 13 in. TV/VCR Combo
Zenith wont tune channels
You must get a proper replacement remote control, once you can access the menu and find you cannot store above 13, place another post and i will help you further.
Oct 11, 2007 | Sony FD Trinitron WEGA KV-21CL10 21" TV
I have the 13 inch and...
If you get channels 2 to 13 nice and clear but the rest are snowy, it means that the TV is set to the broadcast channels, which means that for the channels above 13 it is tuning in the old-fashioned UHF channels. If the TV is set to the cable mode then it tunes in cable channels above 13. To do this, enter the menu and navigate to the tuner settings, set the tuner to standard cable and then do the autoprogram, and the tuner's memory will be set for your cable system.
Aug 03, 2007 | Emerson EWC1903 19 in. TV/VCR Combo
Zenith L15V26D 15 in. HDTV-Ready LCD Television Logo
105 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
