Question about Sony Cyber-shot DSC-S600 Digital Camera
Camera refuses to switch on
Switch on camera in stored photos mode, everything is fine.
Switch to camera or video mode and the screen says "Turn power off and on again". Tried this - same problem
New batteries - same problem
Initialized again via MENU - same problem.
Any other ideas, please
  • 1 more comment
  • cyber-girl Aug 27, 2008
    Last resort !
    Going to strip it down- see if anythings broken or not.
    Getting in really deep now ! Stripped camera down and there are no obvious problems but inside the cover is a sticker warning about replacing the 3 fuses with like for like. I can't see any on the pcb - does anyone know where they might be located or what circuits they protect ?
    Fixed it!!!!!!!!!!!!!
    Small cog on shutter motor had somehow disengaged with teeth on shutter mechanism causing it to jam.
    Not too difficult just a bit fiddly. Total of 6 screws ( 4 external and 2 internal ).
    Thanks to everyone for their help !!!!!!!!!!!!!
    Master:
  • 848 Answers
Lens mechanism not working properly so only it gives error, so camera says turn the power on. try to tap the lens while power up......
Posted on Aug 24, 2008
Picture display freezes and can't none of features work
PLEASE see the test and fix it. God bless you
1. Camera won't record photos. Make sure you've selected a photography mode with your camera, rather than a playback mode or a video mode. If your camera's battery power is low, the camera might not be able to record photos.
Additionally, if your camera's internal memory area or your Memory card is full, the camera won't record any more photos.
With some cameras, the internal software only allows a certain number of photos to be recorded on a single memory card because of how the software numbers each photo. Once the camera hits its limit, it won't save any more photos. (This problem is more likely to occur when an older camera is paired with a new, large memory card.)
The battery is the root of most common digital camera issues. Though battery life has been extended as battery and digital camera technologies evolve, no battery lasts forever. When your batteries begin to run out, sometimes your camera responds in wacky ways that may not seem connected. The flash may not come on, the autofocus won't engage as quickly as it did before or the LCD screen will power off intermittently. All of your camera's responsiveness is linked to its battery strength. Change batteries and try to recreate a problem; odds are you won't be able to. It's a good idea to carry a backup battery for cameras that use lithium-ion cells or a pack of spares for cameras that use AA. Watch your battery icon for a general idea of
Nov 09, 2013 | Nikon COOLPIX S9300
Cant take photos with my Kodak ZD710
check eye settting or its a fungus inside lens black screen is due to virus
Jun 18, 2009 | Kodak ZD710 Digital Camera
Mode dial on my Kodak DX6490 camera is hard to turn!
dissmantle the back case (watch for 1 hidden screw under rubber covers), lift plate on back of lcd screen, remove screw on back of dial, clean where it sits on both sides (most probably from a liquid spill...tea, coffee...) , apply some lube with a cottonbud ore a bit of tisue and rebuild.
hope this helps
stewart
Apr 04, 2009 | Kodak EasyShare DX6490 Digital Camera
Does not chnage back from from Photo mode to Video Mode
If you have been using this camera for a long time, most likely the function switch ( the one you turn to change from photo to video mode) contacts are worn out. you have to take this one to a repair shop to change the function switch.
Regards,
Luwangula
Oct 30, 2008 | Panasonic NV-GS180EF-S Mini DV Digital...
CAMERA TURNS OFF WHEN IN PICTURE OR VIDEO MODE
Does the camera turn off or does the screen go black? if the screen goes black but the power lamp stays green then the screen is just turned off (power save mode), If it’s just the screen to turn on the LCD. There are 3 buttons just to the right of the screen, press the center button.
May 20, 2008 | Sony Cyber-Shot DSC-P52 Digital Camera
Camera freezes when changed from Auto > Scene
Nikon Coolpix s3 powers on OK when switch is on auto mode, but when switched to "Scene" mode cannot shoot, switch back to auto mode / movie mode, or turn off. If power is turn on when switch is in "Movie" mode, everything is OK. Help!
dr rajeev jain
drrjain3@rediffmail.com
Apr 15, 2008 | Nikon Coolpix S3 Digital Camera
Switches off whenever I try put it into photo mode
This is the lens motor not responding Nothing for you to do there any repair is likely to be expensive Contact Panasonic for further advise a New camera perhaps
Aug 02, 2007 | Panasonic Lumix DMC-LZ2 Digital Camera
Record button doesn't function
You may want to check the record lockout safety switch located on the tape. This button can get moved by accident and the camera will refuse to record on that tape. Also, be sure the camera is in "video" mode, not "photo" mode. Some of Canons camcorders have a digital still camera mode which stops the camcorder from functioning because the photos are being recorded to a memory card and not your tape, please check this swithc as well. Good luck. Joe Weibel customelectronics.org
Feb 26, 2007 | Canon Elura 65 Mini DV Digital Camcorder
How do I use the memory stick?
Recording Still images To The Memory Stick M.REC mode (Memory RECORD mode) 1. Set the mode switch to MEMORY CARD. 2. Set the power switch to CAMERA. 3. Press the PHOTO button. The still image is recorded to the Memory Card. To View photos on the Memory Card M.PLAY mode (Memory PLAYBACK mode) 1. Set the mode switch to MEMORY CARD. 2. Set the power switch to PLAYER. The last recorded image appears. If there are no recorded images on the Memory Card, NO STORED PHOTO! or NO STORED MPEG4! will display on the screen. 3. Using the (FWD) and (REV) buttons, search for the desired still image. * To view the next image : press the (FWD) button. * To view the previous image : press the (REV) button. * Pressing (FWD) when you are on the last image will take you to the first image and pressing (REV) when you are on the first image will take you to the last image. * Keep pressing (FWD) or (REV) to search for an image quickly.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Sony Cyber-shot DSC-S600 Digital Camera Logo
79 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
