Question about Refrigerators
Servis fridge freezer m7065 blue eco light on front not working fridge seems to be dead but when thermostat is turned to number 1 upwards fridge works but poor cooling hardly cold inside and freezer slow to freeze
  • 639 Answers
SOURCE: Hotpoint FFA90N fridge freezing everything
Peace Friend,
ngfam1 At your service!
it sounds like the thermostat and it is not easy to do if you have never done this before, it's better left to a professional!
What type fridge,model and age?
If not only a trained tech can make the electronic diagnoses.
Like we used to be able to fix my own cars, but not today they need diagnostic equipment!
Below I referred you to a great service nation wide!
If none of these tasks remedy the problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
How old is the washer?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm1
Posted on Sep 04, 2008
  • 473 Answers
SOURCE: Fridge too cold
There is a damper motor that is behind the vent where you feel the cold air coming out in the fridge section.  That damper should open and close after making temp. adjustments.  See if you can look in the vent and see if it is wide open.  Set your freezer on the coldest setting and check this vent again an hour or so later.  If it is still wide open then that damper motor is bad.  Let me know if you find something different or have any questions.
Posted on Oct 10, 2007
SOURCE: Fridge of Fridge/Freezer keeps freezing contents.
all the food going to ice temperture at 2
Posted on Nov 25, 2007
  • 29 Answers
SOURCE: Our beko frost free fridge
the thermostat in the fridge is turning off your compressor before the freezer has completed its job.this is because it doesnt care about the freezer temperature only the temperature where its located in this case the fridge,try completely defrosting the fridge and restarting it
Posted on Aug 13, 2008
  • 750 Answers
SOURCE: Candy CPCA250 GB Freezer feezing but fridge not cold
Hello jonnyclewlow
You said, you recently had a problem with my Candy fridge freezer (it defrosted overnight and wasnt cooling at all) and a repair shop diagnosed a thermostat problem. I have replaced the thermostat, Now the freezer freezes without any problems but the fridge does not go cold at all.
Also the compressor is running constantly
This is my first thought
Fresh Food temperature is
too warm. Freezer
temperature is satisfactory.
1. Fresh Food control is set too
2. Set fresh food control to a colder setting. Allow 24
hours for temperature to stabilize.
3.Then see if you do not have your freezer articles packed full up to the top, or covering the cold air vents usually found in the rear of the freezer compartment.
The fridge and the freezer share the cold air so the air must not be restricted from travel form the freezer to the fridge and back!
This would also cause the compressor to run none stop trying to cool the fridge!
So check your air vents in the freezer.
I'll bet you did not know they were there !
Most of us never notice!
Hope this works for you.
Please let me know that one of these solutions worked for you!
or if you have any questions.
Thank You, huuum
Please remember to leave a rating!
Posted on Oct 14, 2008
Servis Fridge Freezer Model # M7973B-I/1 light flashing
Likely problem is the temperature setting control is failing.
Apr 04, 2012 | Refrigerators
Have a servis fridge freezer and it kept over freezing no matter what setting, ice would keep forming on back of fridge, and the motor never seems to go off. so i replaced the thermostat yesterday but...
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
Mar 30, 2011 | Refrigerators
Frosting up of the freezer. The fridge seems not to turn off
adjust the thermostat setting if digital type thermostat adjust it by pressing upward if your thermostat analog type rotate it counter clockwise then observe operation of thermostat. or replace thermostat maybe it is already damage.
Feb 12, 2011 | GE Refrigerators
Servis fridage freezer red triangle exclamation light flashing. please advise.
i have a servis fridge/freezer m7065 3x/w1.
the fridge light constanly flashes and partly defrosts,then it becomes working again and vice versa.?
Oct 02, 2010 | Refrigerators
Fridge freezer isnt cold as normal
I have a Servis Fridge Freezer but the fridge is not as cold as it should be I think it just seems cool because the Freezer compartment is working
May 24, 2010 | Refrigerators
I have a servis fridg freezer and the fridge is
sounds like the thermostat has packed in, it works as a switch for the compressor (which will be constantly on) if its a conventional model and should be replaced. if its a frost free it will be a control module thats faulty.
never work on a live appliance and get expert advice if you are at all unsure when replacing parts as if not isolated properly you will give yourself a nasty shock.
Jul 22, 2009 | Freezers
servis frostfree fridge freezer not working after 2weeks holiday returned it had completely defrosted fridge & freezer power supply still connected. warning light on. done all the trouble shooting in the srvice manual still want go cold or freeze. light on in the fridge, no water in the rear tray & cleaned the overflow pipe??. Model No M0330-ALU 5yrs old. think it has 2 seperate thermostats, surely they wont both have gone at the same time???????
Mar 30, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Servis Fridge not cold enough
Hi ruthcart1,
I'm Harvey the Master Plumber.
Your problem is: You have a free standing fridge freezer from Servis (silver) and the fridge doesn't seem to be as cold as it should be. The freezer is absolutely fine just the fridge even though you have adjusted the thermometer inside.YouI've had it maybe 3/4 years.
You're still under warranty. Modification now voids the warranty. I would call warranty repair. This should be their headache not yours.
Feel free contact me again!
Please give me a rating here at before you sign off
Thank you,
Harvey your Master Plumber
Sep 10, 2008 | Refrigerators
Temperature control
I have a danby mini fridge and freezer and noticed the same problem. The temperature dial has NO NUMBERS ON IT! it just has a strip that goes from light to dark blue. That's it. I looked in the manual and it doesn't say anywhere which way is makes sense that the darker the blue the colder the temperature but why keep us guessing?
Mar 15, 2008 | Danby 3.6 cu. ft. / 102 liter Chest...
Refrigerators Logo
120 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
