Question about Singer 6038 Mechanical Sewing Machine
Bobbin problems I was sewing with no problems. Moved on to next piece and now the bottom threads are loose, bunch up and clog the bobbin. The needle seems to be hitting the bobbin incorrectly causing the needle to hit and stop. I have removed the plate and cleaned the bobbin areas and feed dogs, but it hasn't helped. The manual has been no help and you cannot tell anything from the manual pictures. I have the same problem. Machine was working fine and then all of a sudden the needle seems like it's hitting the bobbin in the wrong place or something. If it doesn't get bunched up, then there is absolutely no tension in the thread.
  • 3 more comments
  • dmoveup Sep 09, 2008
    I own a Singer 6038 and I am having the exact same problem. I'm at a standstill on some projects I need to finish and cannot get past this problem. I too have cleaned everything, checked everything, manual is of basically no use. My top stitches are lovely but the bottom stitching is wretched and bunched so badly I didn't know I had so much thread! Please, what to do??? Should I replace the bobbin case? Diane
  • michelleq Oct 13, 2008
    I know exactly what you mean, this is so irritating! The top stitch is beautiful while the bottom is bunched up. Sometimes re-threading helps, but most recently nothing is helping...
  • Tanchkie Feb 20, 2009
    I have the exact same problem. I have tried everything I can think of and still I have a tangled loose mess of thread on the bottome side of the fabric!! Nothing seems to correct this and I am beyond frustrated! My Mom's old 1962 Singer still works better than this and has never had a glitch!! Why don't new products last like the old ones!?
  • dmoveup May 11, 2010
    Here are some examples of this looping problem I'm having. Diane
  • Rob Ristin May 11, 2010
    What machine?
    -R
    Novelist:
  • 97 Answers
Any time you have looping on the bottom, it is almost always related to the upper tension and not anything in the bobbin area.
A good way to troubleshoot this is to turn the machine off, blow out the upper tension disk assemblies with canned air, (the machine needs to be off because most canned air uses butane as a propellant. Butane + electricity = bad;) replace your needle, and rethread your machine. Once you've threaded it to the point where you're about to put the thread through the needle, "floss" the thread forward and backward to ensure that the thread seats correctly into the tension assemblies.
Set your tension to around 4.5 for most applications, and drop your presser foot. Give the thread a gentle tug to see if the tensions have engaged the thread, then thread the needle.
If doing this does not address the problem, you probably need to have your tensions professionally calibrated. This is also true if the needle is in fact hitting something in the bobbin area. This is usually caused by the machine's timing being out of alignment, which is not something that can be fixed at home.
Good luck,
-R
Posted on Sep 10, 2008
I had the bunching up problem too.... I didn't have the thread properly position through the tension plates. I had it around the outer white dial; which i found out by trial and error is not where the thread was supposed to go.
Posted on Oct 29, 2009
Be sure you are using a Class 66 bobbin for this Singer machine. Using another style bobbin can cause tension problems and thread looping/bunching.
Posted on May 24, 2009
5 Suggested Answers
RickE1
  • 202 Answers
SOURCE: Thread is bunching underneath fabric
Needle in correct? Be sure your bobbin is not in upside down and turning the wrong way. Possibly the hook that the bobbicase fits in/on has been hit by a needle and caused a burr that is catching the thread as it comes around. The burr would have to be polished off or hook replaced. The machine could be slightly out of time also.
Posted on Feb 11, 2009
  • 155 Answers
SOURCE: Singer 6217C Bobbin Thread bunching
please check out this link
http://sewvacdoctor.com/cate.asp?categoryID=6#1082
goodluck
 thanks.
Posted on Oct 26, 2008
  • 1116 Answers
SOURCE: I have a WHITE 3300 EMBROIDERY MACHINE and the
Refer to your machine for cleaning the bobbin area.
You will need to clean this area often as lint and thread snips can build up can cause the bobbin feed to malfunction.
If this continues after you have cleaned the machine, the timing may need to be adjusted by a sewing machine tech.
Posted on Mar 18, 2010
  • 149 Answers
SOURCE: top thread - not bobbin thread - bunches up under
this is a top thread tension problem . make shure thread is between tension plates and spring is contacting the plate if the tension number is high
Posted on Apr 13, 2010
My Janome 8050 bobbin case is jumping out of place. The thread is wrapping around the bobbin case and getting stuck, bunching up, and shutting down my sewing progress. It ties the needle up.
check for the retainer action of the bobbin case to see in there is a part broken off that holds the bobbin in the case or carrier
from what you describe , with the thread bunching up etc, I suspect that the needle thread tension is too loose and causing the problems
if so then the bunching and problems can be from the bunched thread pushing the bobbin out of position
take it in for a service and if necessary , repair
Dec 20, 2016 | Janome Sewing Machines
Why does bobbin thread keep snagging?
increase the needle thread tension up a bit as it is too loose to pull the bobbin thread up properly
keep adjusting until both threads are at the middle of the materials being sewn
Mar 25, 2016 | White Sewing 1418 Mechanical Sewing...
Bobbin thread bunching up on bottom side od material while sewinginto a mess, while top thread fine. HOW DO I fix this, please.
Hi, this is a lack of lower tension. Check to make sure your bobbin is seated correctly and that you have used the correct thread path. Check the tension by drawing some thread from the bobbin with your hand, if it reels off too easily, the tension hook for the bobbin is too loose, tighten it down a tiny bit with a small screw driver and try again. If the bobbin tension is normal, than the problem may be your upper tension, if it is too tight it can cause your bobbin to snarl. If a tension adjustment does not fix the problem, you may need to seek a specialist.
Oct 06, 2015 | Singer Sewing Machines
Thread is bunching up in bottom.
It sounds like you have no tension on the bottom bobbin reel. Did you check your tension on the bobbin reel. The tension must be right on both sides. When pulling on the cotton when the reel is in its bobbin case you need to feel a little resistance. Adjust the tiny srew on the bobbin case to tighten the reel to avoid it to turn in the casing.
Jan 11, 2014 | Brother PE770 Computerized Sewing Machine
The bottom thread bunches up
try changing to needle
check the top thread tension--try 3 or 4
clean under the needle plate for lint or loose threads also in bobbin area
make sure bobbin is in correctly
Aug 04, 2011 | Necchi 3620 Quilter Mechanical Sewing...
The thread on the bottom bunches up all down at the bottom than bunches up
Usually problems like this are caused by improper bobbin winding and installation, incorrect tension, the wrong needle for project, or simply not grasping the threads and gently pulling them backwards when you start a seam.
1. Make sure you are threading the machine correctly.
2. Check your tension.
3. Check the bobbin, make sure it's wound properly and that you don't have the bobbin in upside down.
4. Check for bits of fluff and thread in the bobbin race area.
5. Change your needle, they wear out, get bent, dull... etc. You should have several different types on hand at all times.
6. Grasp both the threads gently and pull slightly backwards when you begin a seam. this will assure that your bobbin thread doesn't get all bunched up under the fabric.
7. Always test tension, needles etc., on a scrap piece of fabric before you begin sewing your project.
:o) Smile... sewing is fun... remember?
Mar 04, 2011 | Singer 3116 Simple
When sowing the thread bunches up in a ball. The inner rotary make noise, how to correct problem?
first change the needle
clean under the needle plate where the feed dogs are for lint
also clean the bobbin area for lint or loose threads
rethread the machine-top thread & bobbin
some time the top thread can come off some thread take up levers--that should be watched when sewing
check to make sure the bobbin is always wound correctly--and incorrect wound bobbin can cause sewing problems
Nov 17, 2010 | White Sewing W3300 Computerized Sewing...
The thread is loose on the bobbin end when sewing...the top is fine, but the bottom is so loose and bunches up into a mess.
Make certain the bobbin is inserted correctly into the bobbin case. If it is, be certain the bobbin is wound tight. A bad wind will cause the loose threads you mentioned. If both of those options are all right, check your upper tension. Generally, it should be set at 3. Also, make sure the needle is inserted correctly...the groove on the face of the needle should be facing the front of the machine (it is actually a thread guide). And last, has the bobbin case been removed and cleaned? If not, this could lead to "messy bobbin threads." I hope one of these suggestions is THE one for your problem. Good luck!
Nov 14, 2010 | Bernina Sewing Machines
When i am sewing the thread from the bobbin keep bunching up in the bottom of the material
you might check your needle-roll on flat surface to see if it roll correctly
there are 3 types of bad needles-bent,,blunt,damaged
on some sewing machine the thread can come off the thread take up lever
check the bobbin area for lint or loose threads
Sep 22, 2010 | Brother LS-2125 Mechanical Sewing Machine
Sewing a bunch of thread from the bottom, this stops the machine from actually sewing
Yes, it does. There are a couple of reasons the bobbin thread could be bunching up on the underside of the fabric. It could simply be that the machine needs cleaning. Take the bobbin assembly out, brush all the old lint out as best you can, reoil the machine once it's all clean, and make sure there aren't any little bits of thread caught in the bobbin assembly. Rethread the machine (carefully) and change the needle. This solves the problem usually--especially if the machine was sewing along fine and the problem develops suddenly. '
The other thing to check is your tension. It could be that the top tension is too loose. But different color thread in the top and in the bobbin, stitch a few inches (be sure to held the top and bobbin thread ends behind your needle as you start to stitch) and check. WIth the pressure foot down, adjust the tension, and stitch again. Keep stitching, checking, and adjusting until you see little if any bobbin thread on the top or top thread on the bobbin.
Another thing to reminder: use the appropriate thread and needle for the fabric you're sewing.
Let me know if this works, ok?
Robbie
Jan 31, 2010 | Elna Sewing Machines
Singer 6038 Mechanical Sewing Machine Logo
1,088 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
