Question about Sony Cyber-shot DSC-S600 Digital Camera
"Turn power off and on again" screen when switching on in cam or vid mode
Got to SETUP1, reinitialized but still have same problem. Any other ideas,please?
  • 435 Answers
I replied to your original post. Please check that thread. Please let me know if you need any assistance.
Posted on Aug 24, 2008
Not used my vid cam for a long time but when played back some tapes played great. The following day I tried playback on the tapes & they all showed a blue screen. No images What am I doing wrong?
not sure on this one but it might be the heads in your vid cam may need cleaning.
or the tapes are not running straight on the heads or the rollers in side.
if the vid cam has been in a cold place it can cause this fault as the heads may have a bit of damp.
try putting a tape in and run it fast forword in play mode and see if starts to clear the playhead.if it does keep doing it until you see a clear picture.
this could also be a head misalignment fault if it is you will have to take it to some one to have a look at.
if any of the above does not work then you will have to take to some one to look at it.
Nov 27, 2016 | JVC GR Video Cameras
I am getting a E:61:00 error on my Sony T5.
amitchhab276:
From the user manual for your DSC-T5 (click here), that error message means:
E:61:xx E:91:xx
A camera malfunction has occurred. Initialize the camera (page 52), then turn the power on again.
From page 52: After you have cycled-power, you need to go to the Setup1 screen and select "Initialize" and choose "OK" with the up arrow and then press the circle button. Again press the up arrow and circle to select "OK" to reset the camera to default. settings.
Make sure that the power is not disconnected during reset!
Feb 16, 2011 | Sony Cyber-Shot DSC-T5 Digital Camera
My Sony Cybershot DSC-N2 touchscreen will not work.
if the initialize and calibration settings cannot be accessed if the touch screen is not responding, try to power reset the camera: turn cam off, remove the battery, make sure the cam is not connected to an optional ac adaptor, set mode switch to play, press and hold down the power button for a minute, let go and turn cam mode back to off, reinsert battery and turn cam on. if touch screen is still not working, unit may require service. hope this helps. thanks:)
Aug 25, 2010 | Sony Cyber-shot DSC-N2 Digital Camera
The screen turns off after a long period of use and wont turn back on until having been unplugged for an extended period of time. Do you think this is an overheating malfunction (although it does not...
ferraric, You're halfway there! Now all you need to do is find the "THERMALLY INTERMITTANT" and "COLD/FROSTED LOOKING" solder joint on the power supply (switch-mode-power-supply) printed circuit board. Check all the larger and more weighty components first, including power transistors. I'm sure that the web has some pic's of what they look like! The cause of them going BAD is what is known as Thermal cycling! Hot to cold, Hot to cold. You may need a magnifying glass or an inspection microscope to view your printed circuit board! Visit YOUTUBE for disassembly vids and you better have a digital cam to document the teardown BEFORE removing plugs from board-mounted connectors. Good luck! louie12fix or aka 12fix louie
Nov 09, 2009 | Samsung SyncMaster 940MW 19" LCD Monitor
ACCESS???
1. Please make sure that you're using a fully charged battery.
2. Please try Initializing the Camera. To initialize the Camera.
First, press the Menu button on the Camera to display the Menu items.
Then, select the SETUP option under the Menu.
Then, select the SETUP1 under the SETUP.
Then, select the Initialize under the SETUP1 option to Initialize the Camera.
If the issue still persists, then try Power Resetting the Camera.
First, turn OFF the Camera.
Then, remove the battery pack from the Camera.
Then, press and hold the Power switch for 30 seconds.
Then, reinsert the battery pack into the Camera and turn ON the Camera.
If the issue still persists after performing the steps provided above service of the Camera is required.
Jun 17, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
Black screen
Turn the power off and on again message is displayed when the Lens mechanism is stuck or when there is an internal malfunction. To resolve the issue, try turning off and on the power for few times. If the issue persists, try power resetting the Camera.
To power reset the Camera, remove the battery from the Camera. Press and hold the power button of the Camera for 30 seconds. Remain the Camera without power for 60 seconds and reinsert the battery to check the operation.
You can also try Initializing the Camera by selecting the INITIALIZE option from the SETUP1 Menu of the Camera.
If the issue persists, service may be required.
Thanks for using FixYa
Nov 24, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
MODE SELECTION PROBLEM
Try menu-> setup->setup1, initialize, ok- this resets calendar and time as well. It brought mine back to correct mode selection.  Also make sure your battery is fully charged.
Jul 21, 2008 | Sony Cyber-shot DSC-W100 Digital Camera
Sony DSC-W55 problems...Says Access and then restart..
Just kick it few times on the left side of the camera and the problem will be gone. Same thing happened to me and it worked.
Jan 02, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Problems on paper jam (just after the selftest)mode switches blinking
You may have to reset the printer. I believe these are the directions to follow:
Re-initialize the HP All-in-One Force the HP All-in-One to reinitialize by following the steps below:
  1. Turn the unit off by pressing the ON button.
  2. Disconnect the power cord.
  3. Wait five seconds, then reconnect the power cord.
  4. If necessary, turn the unit back on and try reading the photo card again.
  5. If the unit fails to read the card again, reset the All-in-One. Repeat Steps 1 – 4, but before plugging the unit back in, press and hold the # and 6 keys on the HP All-in-One numeric keypad. Continue to hold these keys down for a few seconds after plugging the unit back in to reset it. Once the All-in-One reestablishes communication with the computer, reset the language and country/region.
Oct 25, 2007 | HP PSC 2210 All-In-One InkJet Printer
Cybershot DSC W50 Flash Doesn't Work
have you tried resetting the camera? i had this same problem and i just went to menu>setup>setup1>initalize>OK
and it went away completely.
Oct 14, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Cyber-shot DSC-S600 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
