Question about Logitech Z-340 Computer Speakers
Need wires for z-340
Ok so i have this system (z-340)
but i bought it used and i only got the subwoofer, so i was wondering how can i connect it to my comp, it only has the power cable
plz help
  • taylor7359 Sep 17, 2008
    I bought it used as well. It was just the sub and was $2!
  • Anonymous May 17, 2009
    I have the acs640 sub with out anything else. I believe I have a working power supply arrangement, however, the other connector which would probably have a power switch/volume is not working for me. If anyone had a pinout on this model it would be greatly appreciated.
  • 3 Answers
I just got one too. I guess I'll tear it apart and post the pinout. Also have a set of Altec Lansing satalites (ACS340) with the same connector (hmmmm, Z-340 -- ACS340... probably the same thing they just changed some pins)
I let you know!
Posted on Nov 16, 2008
I have an Altec Lansing 340 speaker system that is not working.
There could be a defect in the connector. Check both sides for continuity.
Jan 03, 2015 | Altec Lansing Audio Players & Recorders
Why is rear stock subwoofer not working?
I need to have more info about how you installed it, did you use rca wires from the radio to the amp.? Make sure the sub setting on radio is turned on. Make sure rca wire are in the input connection and not output, also check you connection from radio that they're in rite place. I really need more info about the map of your wireing
May 10, 2014 | 1998 Ford Expedition
Can not get subwoofer z-340 to work with i3 laptop. Speakers work, but not subwoofer
Ensure it is connected according to the manual and plugged into a wall outlet for power. The small speakers might work just being plugged into the computer but the subwoofer requires a much higher voltage to run.
Sep 28, 2013 | Logitech Z-340 Computer Speakers
Amplifier turns on but not the subwoofer?
Hello thedj3214,
You can find the color codes for a 1999 Buick Regal here. There is no dedicated amp remote wire. Neither is there a power antenna wire.
You could use the 12V "switched lead (yellow) from the radio or any switched 12V lead directly from the vehicle fuse box. I'd wire it through a dash mounted toggle switch so as to be able to turn the amp on and off manually.
The Sony 2150GSX is a 2-channel amp with the speaker terminals on either side. You do not want to ground the subwoofer itself, only the ground terminal should be connected to bare metal on the vehicle chassis or body as close to the amp as possible. The ground wire does not need to be run to the negative battery terminal.
A ground on one of the speaker leads will probably cause the amp not to power up. A ground on a speaker wire usually activates the amps protection circuit, causing it to not operate until the fault is corrected.
Hope this helps.
Jul 28, 2009 | Sony XM-2150GSX Car Audio Amplifier
Subwoofer blows internal fuse when receiver is turned on
Has it ever worked?
Try this - connect one pair of its speaker wires at a time and test it. Watch the polarity.
• Make sure all cube speaker arrays are connected to the proper terminals according to their
position in your room.
• Check to be sure all wires are connected to your surround receiver with the proper polarity
(+ to + and – to – wires). Incorrect wiring can result in a total loss of module output.
• Correct any wiring problems before you plug in your receiver and turn it on.
Dec 12, 2008 | Bose Acoustimass 16 Speaker
Sub and amp problem
You should get power even without the RCA cable.
I believe you should take time and check your connection.
please use the right cable for your sub. you need the right cable
to boost the sub. Check radio shark or Sam Ask for better sub cable.The better one don't come with your system.
Good luck
Jul 24, 2008 | JBL PB10 Subwoofer
DCM SUBWOOFER PROBLEM.
telll sterio use sub out and remix on in settings menu on steiro ok also does it have speaker wires in and out use them off fornts ch from sterio then back up throw sub to fronts set cross over on 100 or so
Jan 29, 2008 | DCM KX-6 Speaker
Sub installation
You would be better served to go to a local shop and get the correct fittings to fit the connections, and use those to connect your subs. Just running the wire tips will result in loosed connections and plenty of headaches..
Jan 04, 2008 | Rockford Fosgate Punch Stage P110 S4 Car...
Logitech Z-340 Computer Speakers Logo
1,344 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
