Question about Car Audio & Video
I own a 2001 Dodge Stratus RT coupe. The stereo does not work in it. We traced the problem to the amp. We rewired the speakers together bypassing the amp and the stereo worked, but after awhile, the stereo stopped working again. Any suggestions?
Now replace the factory radio with any after market one, run the speaker wires to the location of factory amp and connect wires to all speakers.
Posted on Apr 02, 2009
2001 Stratus Coupe. new battery and starter. engine wont crank when i turn the key. also no dash lights
You need to clean all the batt. and starter solenoid connections.
make sure they are tight
make sure to clean batt neg wire at body connection
check your fuse link to starter from battery,
a 6 inch section of thinner wire designed to burn out to protect starter. this is why you can jump starter you bypass the blown fuse link.
mike
Mar 25, 2016 | Eastern 2001 Dodge Stratus - Coupe, 2.4L...
How do I bypass a factory amp in a 2014 dodge charger se? I am having trouble hooking up my 5 channel amp which leads me to believe that there maybe a factory amp installed on my car.
Doubtful, trace wires from speakers using test light, does new amp have coaxial connectors? you may have incompatible model, probably need to match amp with new head unit, worst case you can rewire speakers directly to amp, use new wires, leave old wires in place just cut ends and put tape over.
Nov 11, 2014 | 2014 Dodge Charger
Radio wiring
if you are going to install an aftermarket stereo then you can go to your local walmart or look online for a wiring adapter that matches your year make and model hen simply match the wires of the new harness to the wires of the new stereo and plug it in. if you are doing something else ill need more details.
Dec 22, 2013 | 2004 Dodge Stratus - Coupe, without rear...
2001 dodge stratus charging problem. not alternator or battery and car jerks when driving
You need to get the DTC connector back to
the way it was designed & then resolve any code
related issues & continue on
Do you not have a good repair shop to go to
Very few people coming here work on a car
If you have to ask- usually that is the case
Mar 09, 2013 | 2001 Dodge Stratus
2001 dodge stratus coup raido wire diagram
i split the diagram in two just prtin and paste. and please leve 4 thumbs up thanks
May 07, 2011 | Dodge Stratus Cars & Trucks
How to remove factory radio from an 02 dodge stratus rt
If its a 2001+ Stratus Coupe first you need to remove the 2 bolts on the left and right sides of the lower middle dash assembly, these are at the very bottom of the assembly close to the center consuel (were your gearshift knob is. Once you remove those the assembly around your stero will come off. After that its just a matter of unbolting the stereo, sliding it out and removing the wireing harness in the back.
hope this helps
Nov 28, 2010 | 2001 Dodge Stratus
Dodge radio starts then shuts off
Hi Davis,
I had the same problem with Dodge Grand Caravan as well. I have a 2001 GCV and these radios go out all the time, plus each speaker has separate amps which some speaker will stop working. You will need a new stereo, however the dealership will charge you over $350 for the same replacement. I chose to go to BestBuy and buy a new Stereo for around $100 which has iPod connections which is a plus.
Next problem!!! Since each speaker has its own amp, in order to get the new stereo to work, I had to install a relay by tapping into the passenger side kicker panel master amp power supply to bypass the chip. Best Buy guy will know what to do. I suggest install the stereo yourself with a kit and go back to install an amp bypass relay switch. Hope that helps.
Stock Stereos **** and Dodge make is difficult to go aftermarket.....Good Luck
Apr 05, 2009 | 2001 Dodge Grand Caravan
I am trying to install new stereo in 2003 spyder eclipse
IF YOU GO TO WALMART AND BUY THE WIRING HOOK UP KIT THATS MADE JUST FOR YOUR TYPE OF CAR U SHOULD NOT HAVE ANY PROBLEMS.. YOU CAN DO THE AMP BYPASS, OR YOU CAN INSTALL YOU NEW DECK AND REWIRE THE SPEAKERS DIRECTLY TO THE NEW DECK.. HOPE I WAS A HELP GOOD LUCK KEITH..
Mar 11, 2009 | 2003 Mitsubishi Eclipse Spyder
Car Audio & Video Logo
119 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
