Question about Mitsubishi VS-45607 45" Rear Projection Television
Mitsubishi tv front panel not working
I can no longer turn tv on, change channels, change volumns. front panel is no longer working. the remote is the only thing that works. i cannot change input to watch a movie thru my dvd player. help. thanks, rene
  • 927 Answers
Good Day; This model is equipped with a keyboard lock feature. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds. Or you may bad control board. Good Luck, big IRISH.
Posted on Sep 26, 2008
How do I turn up volumn on the wd-65735 model without remote. it only goes up to 63 and my remote is broken so I need intructions on how to do it manually.
open mitsubishi front door see volumn control push button use +/- if you need new remote part no: Manufacturer Mitsubishi Part Number 290P123010 Description REMOTE
Dec 06, 2009 | Mitsubishi WD-65735 Television
ILO LCD Color HDTV does not change channels / volumn...just turns on/off
The symptoms your TV is experiencing is due to a power supply that is not longer providing the 5 volts properly to the circuitry.
It seems to be a common failure on these TV sets.
Apr 29, 2008 | iLO 3200 32 in. LCD Television
It's unlikely that a setting you changed in the user menu would have locked out both the remote and the panel.
It sounds to me like the micro has gone bad. One other option, is a stuck or damaged button assembly. Corrosion on the button board can lock the micro.
Nov 22, 2007 | iLO 3200 32 in. LCD Television
The remote operates all the units except for the TV's vol, channe
There are 2 possibilities: either you have a stuck front panel button, or the remote sensor is bad.
You can eliminate the button issue by removing the front speaker grill and access panel and disconnecting the button assy wiring harness.
There is a plug/socket connection there that you can easily disconnect. If after disconnecting the control panel, you still have no remote, its the sensor. Its located behind the screen assy mounted behind the CRTs. You will have to remove the screen assy to get to this.
If you're not up for this, a service company will charge you $300 or so to replace the sensor for you.
Feb 17, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WS-65611 tv channels cannot stop scrolling
Check to make sure the channel down button is not stuck. If it is not the button is probably defective. Mits has had a lot of problems with the buttons.
Jan 21, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Device stuck on bottom right icon. cannot change.
Good Day, hcolern2b;
Sound like your TV's front panel button assembly is bad, replace or disconnect and use remote only.
Good Luck, big IRISH.............PS disconnect from front by removing speaker grill and small black panel, follow wire harness.real close by.
Sep 07, 2008 | Mitsubishi WS-65809 65" Rear Projection...
This particular model of tv has a problem with the control board. This is a common problem with this unit. You can find control boards on EBay, or through a local technician. Please refer to our online technician list for a professional near you.
Good luck :)
Jun 10, 2008 | iLO 3200 32 in. LCD Television
Channels changing
What happens when you "hide" the remote from the TV so that the TV can't "see" it?...accordianman
Feb 29, 2008 | Apex Digital GT2015DV 20 in. TV/DVD Combo
Tv turns on manually, but auto flips through channels and you can't use remote
Found this in another forum ( and it fixed my remote problem:
"'s possible that one of the front panel buttons is "stuck" or shorted, and this could cause the TV to ignore commands from the front panel or remote. But this should also cause the Power command to be ignored, too. You might try pulling off the front panel and disconnecting the front panel buttons and then see if the remote works."
Oct 19, 2007 | Mitsubishi WS-65511 65" Rear Projection...
Front controls mixed up & remote doesn't work
the channel down button is stuck on, you need to replace this switch internaly to the set.
Nov 14, 2006 | Sony KV-36FS100 36" TV
Mitsubishi VS-45607 45" Rear Projection Television Logo
190 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
