Question about Car Audio & Video
I need a wiring diagram for an Infinity MR472958
I got this stereo from my brother in law but i didn't have the wiring harness or the pin layout of the plug on the back. i'm trying to put this in another car so a pin layout of the blug on the back would be helpful. thanks.
  • Anonymous Apr 27, 2009
    coneccion electrica
  • Daniel Shea May 11, 2010
    Is this unit from a Mitsubishi? If so you can go to a salvage yard and pull the plugs for the radio out of a junker. But once you do that, you are going to find that the unit is locked, and you will have to get the unlock code from Mitsubishi or the owner if he has it. Good luck.
    Leadispenser
  • 132 Answers
SOURCE: wire harness diagram
www.scosche.com will give you the cars wires, u may want to just by a harness adapter, cutting wires=bad
Don
Posted on Jan 02, 2008
SOURCE: Need a Nak CD-45Z wiring harness, or diagram
Rob, I had the exact same problem, I kept searching on line and came upon Alex in Australia, he deals in Nakamichi products, and has the part (plug/wiring harness). He charges $55 for the part and $30 for express shipping.
Here's his email: aminassian@optusnet.com.au
I have also found a site with the Manual: http://www.nakremotes.com/default.htm
Click on "Model List" and look for your model, in the manual there's the wire color code for the pinout. I also have the pinout by wire color, no room to include, will send in another response.
TOP
[ 1 2 3 4 5 6 7 ] Looking @ pins in socket
[ 8 9 10 11 12 13 14 ] Naka CD45-Z deck
Note: The above diagram is done from the perspective of looking directly on to the connector pins. If you are having trouble figuring out which way is which, just use the ground wire, which is always black, as a reference for making sure you are doing the pins correctly.
Posted on Jan 26, 2009
etirbynnor
  • 655 Answers
SOURCE: Need wiring harness color coded diagram for pioneer dehp6800mp.
Hello randscates,
Here's a link to the manual. The wiring color code for the supplied harness is on page 78. The diagram is rotated 90 degrees clockwise. I recommend that you download the PDF and print out the page you need.
Hope this helps.
Posted on May 16, 2009
  • 436 Answers
SOURCE: i dont have a wiring diagram for the 16 pin plug
red -Acc power
yellow -12 memory power
black -ground
blue -amplifier remote
blue/white -power antenna
SPEAKERS
white left front +
white/black left front -
grey right front +
grey/black right front -
green left rear +
green/black left rear
purple right rear +
purple/black right rear -
Posted on Aug 25, 2009
pctech1
  • 1940 Answers
SOURCE: hooking up a kenwood mp235
Blue/White - Power Control/Motor Antenna Control Wire
Brown - TEL Mute Wire
Blue - ANT. Cont. (Not Used)
White/Black - Front Left Speaker -
White - Front Left Speaker +
Gray/Black - Front Right Speaker -
Gray - Front Right Speaker +
Green/Black - Rear Left Speaker -
Green - Rear Left Speaker +
Purple/Black - Rear Right Speaker -
Purple - Rear Right Speaker +
Red - Ignition Wire (Switched +)
Yellow - Battery Wire (Continuous +)
Black - Ground Wire -
Here is a copy of the User Manual:
http://www.masterspas.com/manuals_av/Kenwood_KDC-MP2035.pdf
Posted on Jul 23, 2010
Testimonial: "Thanks."
I need to find out ? where that I might find an electrical wiring harness or what ever they call it and mounting bracket for 1999 Plymouth Voyager Mini Van.
http://www.installer.com/cars/by_car.php?carid=4627
you will need the universal wiring harness for the make and model of stereo as well
check with supplier
https://www.crutchfield.com/p_120701817/Metra-70-1817-Receiver-Wiring-Harness.html
this site has a checker link to check if it is the right part
It has with infinity or without infinity - Which I do not know what this option is but you might know
this is the car wiring harness model number to search on 70-1817 but you will need the wiring harness adapter for the actual car stereo make and model number as well !
Mar 30, 2017 | Car Audio & Video
Need to know how to fix the windows in the stereo in my 1996 Lincoln Continental.all the fuses are fine, I don't know what to do next
None of the windows work ? You say fuses are good , which fuses ? Did you pull them all out an look at them ? Did you check for power - battery voltage at the window switches ? There is a driver door module involved !
  • Power Windows Completely Inoperative
  • Supply open or shorted.
  • Ground open.
  • Window regulator control switch inoperative.
  • Circuits open or shorted.
  • Window regulator electric drive inoperative.
  • Driver door module.
  • PERFORM driver door module self test. Service DTCs. If no DTCs are retrieved, GO to Pinpoint Test C .
If you don't know electrical circuit testing suggest you take to a AES certified repair shop ! If you plan to do this anyway your going to need a wiring diagram , wiring harness layout , volt ohm meter !
Basic Electricity for Service Techs Ohm law Current Flow Opens Shorts
Jun 14, 2015 | 1996 Lincoln Continental
F5TF-19B132-BA Ford Radio Pin out
The stereo pin layout can be obtained from the car dealership, also a repair manual should have the stereo wiring harness layout in it , the stereo harness adapter for installing non oem stereo, found at the local auto parts store will come with the wiring layout, wires are color coded too, sometimes the stereo harness or stereo harness adapter will have small writing on the wires itself, showing you what that wire is for, and where it should connect.
Basically it comes down to, obtaining the stereo wiring layout, read the description on the wires, and properly connect them together, then solder the wires or crimp them, I like to solder mine with soldering wire for electronics, and put shrink tubes to protect the wires, put the shrink tubes on the wires before soldering together, and ensure the shrink tube is the proper size awg wire gauge.
You will also need, aftermarket face adapter kit and antenna adapter, if installing aftermarket stereo.
Hope this helps and enjoy the stereo :)
Apr 11, 2015 | 1999 Ford Taurus
Wiring diagram for bose 28060
Infiniti QX56 Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Yellow
Car Radio Accessory Switched 12v+ Wire: Purple
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Red/Blue
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Green/White
Car Stereo Amp Trigger Wire: Green/White
Car Stereo Amplifier Location: To the right of the steering column behind the BCM.
Left Front Speaker Positive Wire (+): Blue/White
Left Front Speaker Negative Wire (-): Blue/Red
Right Front Speaker Positive Wire (+): White/Black
Right Front Speaker Negative Wire (-): Blue/Black
Left Rear Speaker Positive Wire (+): Gray
Left Rear Speaker Negative Wire (-): Black/Yellow
Right Rear Speaker Positive Wire (+): Orange/Blue
Right Rear Speaker Negative Wire (-): Red/Blue
Jul 08, 2012 | Cars & Trucks
04 toyoya camry radio wireing harness pin
Hi there:
According with the diagram on 2004 Toyota Camry Car Radio Wiring Diagram...
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Pink/Blue
Car Stereo Amplifier Location: Located to the right of the glovebox behind the passenger side of the dash.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Left Front Tweeter: Powered by the same wires as the left front speaker.
Right Front Speaker Positive Wire (+): Light Green
Right Front Tweeter: Powered by the same wires as the right front speaker.
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Tehy could be harnesses 15 or 20 pins, try to look your right replacement in this links:
- 2004 Toyota Camry Stereo Wiring Harness
- 1990-2013 Toyota Camry Auxiliary Car Audio Input Adapter Kit
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jun 06, 2012 | Toyota Camry Solara Cars & Trucks
Car-stereo wiring diagram TOYOTA Tarago 1986
any local car stereo shop can sell you an adapter harness for $10-$15. This is a much cleaner and better way to go than cutting your factory harness.
Mar 14, 2010 | Car Audio & Video
Where to get the wiring diagram for the alpine ktp-445 power pak amp. want to cut the plug off so I can wire to a different reciever/player
the wiring diagram is the same as your stereo , check for your actual stereo manual use the same pins layout.
Jan 16, 2010 | Car Audio & Video
Need wiring diagram 94 jeep with infinity sys and amp
http://www.jeepforum.com/forum/showthread.php?t=507916
has the wire harness information for the amp. very hard to find great photos. the radio should have the sticker on the back telling you what the wires are designated for.
Apr 25, 2009 | Car Audio & Video
Car Audio & Video Logo
182 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
