My Canon Power Shot A1100 IS Digital Camera when I hook it to the computer using the provided USB cord the camera screen says Communication Error. I have downloaded pictures before and not had any troubles.
Have you considered NOT connecting your camera to your computer? The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use ZoomBrowser or any other photo cataloging program.Have you considered NOT connecting your camera to your computer? The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
You can't post conmments that contain an email address.
Googling to solve the same problem with a Power Shot G12, I found a manual under ManualOwl -- on p.194 it says:
"Communication error: images could not be transferred to the computer or printed due to the large amount of images (aprox. 1000) stored on the memory card. Use a commercially available USB card reader to transfer the images. Insert the memory into the printer's card slot to print."
This worked for me. Hope it does the same for you.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Consider NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
It is recommended if there are more than 1000 images on the memory card, that you use a card reader to acquire the images, or to delete images off of the memory so that there are less than 1000 images to download from the memory card.
Try NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Canon ZoomBrowser or any other photo cataloging program.
hi there you need to upgrade the firmware of the camera. Other wise you can do one this. Just remove the memory card from the camera and connect it in memory card reader. Then connect the card reader with PC for transferring the image.
Also let me know when you connect the USB cable between Camera to PC with out install the camera software, what you seen?
There is no DIY fix for this problem, and attempting a fix is likely to worsen the problem and cause the camera to shut down. Sorry, but your situation calls for professional repair.
I had the same problem. My problem was that there were more than 1,000 images stored on the memory card. Once I deleted some of the images from the camera memory card, I was able to download pictures again.
