Question about Insignia IS-LCDTV32 32 in. Television
Insigna TV Hey, seems like you managed to solve a problem that everyone has with this 32 in TV. I wondered where you got the capacitors from. Can you let me know. And while you were in the set, is the power supply a seperate unit from the mother board, can it be changed altogether? Thanks in advance for your response.
  • Goldenone67 Nov 17, 2008
    TV comes on and after 3 seconds the picture goes blank. The sound remains. If I shut the TV off and turn it on .. it will stay on for three seconds again, and black out. I have had A Local repair shop replace inveror Board, but after a month, the problem came back. Please advise... Golden
HI
I have a Insigna IS- TVHD30. It come on and have a perfect sound but I can't get a picture. Its about three years old. I went to sleep watching Tv. and when I woke up the t.V. was on, but wasn't showing a picture anymore. I decided to throw it away last week, and plugged it up and it came right for 2 days, it was perfect. Now it has went out a again. Can some help!!!
Posted on Nov 17, 2008
My 32 inch insigna need stand
Go to Best Buy electronics store for this.
Nov 25, 2016 | Televison & Video
LG 42 inch when switched stays black then flickers and after warmed up seems to be ok,whats the problem?
the problem is in SMPS , the power filter capacitor may be difective or punctured
replace it . I am sure the problem will be solved
Alexander
Apr 09, 2011 | LG LCD325000 32 in. HDTV-Ready LCD TV...
TV Turns on picture comes on for 30 seconds then picture goes off and sound stays on. Even after leaving tv on the sound stays but the picture does not come back on. Its a westinghouse SK-32H540S
This is not the fix for this TV. I guarantee that none of the capacitors exhibit the common bulging characteristics of a faulty capacitor. The common answers to everyone's questions are to replace the capacitors. Most likely the culprit is the inverter board.
Feb 26, 2010 | Westinghouse SK-32H540S 32 in. LCD TV
Toshiba 32 RegzaNo picture, but hear sound
The most i have seen an inverter board go for on a 32 inch tv is about 300$ and that was shipped from japan, not having the actual part number off the board makes it difficult to lookup. I usually charge about 100$ to do this type of replacement. so they do seem a bit overpriced, considering it also may just be a bad capacitor or 2 causing the board to fail, they run about 5$ each. If you have another repair shop in the area i would call them and shop around. If everyone seems to have the same amount of price in mind, it may be just time to get a new tv, with the release of the LED HD tv's the prices for lcd are dropping drasticaly , you should be able to get a much larger one for the same price as you paid for that one .
Sep 25, 2009 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Toshiba TV will not turn on
Try to have the TV unplugged over night. If that does not solve it you may have to have the TV power supply circuit inspected for leaking capacitors, loose solders or may be a bad IC.
Aug 29, 2009 | Toshiba 32A33 32" TV
32 in insigna not a full screen hooked to dish
did you try format button on dish remote? Also shoul have picture format or size on tv remote.
Aug 06, 2009 | Insignia IS-LCDTV32 32 in. Television
Red color appear on my Insigna TV
This most likely a problem with the back lights and inverters circuits.The back lights may be receiving low voltages from the inverter circuit causing the led's not to function correctly. This needs to be tested by someone who can check the inverter circuits for correct voltage levels and the backlights for proper functioning.This usually has to be done in a service center.Try this website for Help and possible repair. LCDParts.net. Technical support telephone number is : 1-877-870-0581 or 1-415-682-8635 Hrs 9am to 5pm P.S.T. This site has lots of information on these type of problems. Hope this helps you with your problem.
Mar 07, 2009 | Insignia 37" LCD Flat-Panel HDTV
Will not turn on, red light as off, when I push power the red light goes off but
Look for 2 pico fuses in the secondary section of the power supply. I'm sure one of them is blown, that is why the 24 volts are missing.
I will let you know the locations later when I get home.
Good Luck.
Jan 10, 2009 | Insignia 32" 720p Flat-Panel LCD HDTV
G1 Android T-mobile battery dying ???
hey, buy another battery, bye
Dec 27, 2008 | HTC G1
Problems with Soyo DYLT032C 32 in. LCD Television. The TV will not turn on, I have un-plugged it and plugged it back in, in hopes it would re-set the tv. Do you have any suggestions?
Long story short:
Had the same problem with my Soyo.
Thought it was the power supply board problem that everyone else was reporting.
ordered one.  Plugged it in.  Did not work.
Inspected the Main/Logic board and found what looked like a black button that could be depressed.  It is located to the right of main processor on the board.  You can't really miss it.
With the TV plugged in, I pressed the suspect button.  The TV made a buzzing/clicking noise for a few moments and the stuck blue illuminated power button faded away.
Curious by this, I pressed the power button and low and behold the TV comes to life!
Looks like I found a "reset" button which seems to have fixed my problem.
Thanks Soyo for not bothering to mention that such a button exists.
I hope the rest of you have the same good luck.  In the event you are still in need of a power supply board, email me.  I have a spare now it seems.  ;)
Dec 10, 2008 | Soyo DYLT032C 32 in. LCD Television
Insignia IS-LCDTV32 32 in. Television Logo
166 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
