Question about LG Studioworks 563N 15" CRT Monitor
Repair over heating of FBT tr. abd burnt out
Ya if u live in india and if u dont have warrenty just go to nearest computer repair shop the main ic of 1500UF is gone and it will cost u only 500rs depending on damage it has done in side
Posted on Apr 01, 2009
my LG Studioworks 563N (White) 15" Monitor suddenly get burnt with some TUPP sound.
And it is not working.
Just I want to check for repair.
if possible I want to get it repaired.
If anybody have the repairing service centers in india ( Bengalore or Hyderabad), Please let me know the details.
Thanks,
varma.net25@gmail.com
Posted on Oct 06, 2008
  • LG Master
  • 5,568 Answers
Good luck finding a replacement FBT; support for CRT monitors is fading fast.
That transformer is probably not the only thing that failed, the horizontal output transistor that drives it is likely bad too.
If you want to repair it, I also recommend you check any bipolar capacitor in that section as it may also have failed.
Posted on Aug 24, 2008
My heat will only come on when the cord that gets plugged for the winter is plugged in. Abd when it is on i am unable to control the fan from the inside. I can also see that the wiring for the fan has been...
the cord that gets plugged in for the winter just works the block heater and warms the engine coolant to make winter starting easier. if you can not control blower motor fan speed then you probably have a bad blower resister or blower motor, that will need to be replaced. if the fan has been wired to the block heater wiring(plug)then it has to be disconnected and put back to original. the block heater works on household voltage120 volts) and the blower motor works on 12 volts. the blower motor may be burnt out due to the excess voltage supplied to it. check fuses as it may have burnt a fuse. depending on the damage caused you may have to take it to a repair shop to have things fixed properly.
Nov 29, 2013 | Cars & Trucks
FBT partnumber help
Try to download the service manual to this set by internet. It has all details.
May 26, 2013 | Televison & Video
Monitor was working only power and i found TR j6820l horizental burnt and mosfet 19n20c burnt and when i changed them the high tension is trying to work but it failling coz larg amper drawn and...
The resistance is heating up as there is very large current flowing through it. Hence the feed of the resistance circuit must be checked as there is a SHORT in this circuit.
A test with a multimeter will confirm the shorted component, de-solder and check with the resistance connected back to confirm the fault. Check the +B voltage to be steady before the components are put into the board..
Jan 05, 2011 | NEC-Mitsubishi Nec Display Solutions...
Sir, my onida 20xs ctv make high boost transister 2499 has burnt
MOST OF THE 2499 TR IS DUPLICATE .SO YOU USE ONLY OLD TR.WHICVH IS TAKEN FROM OLD CTV BOARD. OTHERWISE YOU CAN USE 25INCH CTV H OUTPUT TR.
Aug 03, 2010 | Televison & Video
How to make sure the FBT is working properly & check the same?
This is quite a good speculation, if the : Chopper" transistor frequently "Blows" then Indeed it may be the FBT. You need a FBT Tester, basically a high voltage source, that tests if the FBT is breaking down under load. You can sort of test with a multi meter and a small AC power source, (I often use a 230VAC - 115VAC Wall transformer) put source on the right pins and see whats what on the other pins.I think, that it will not hurt, to replace it "On Spec" as it were. However, check, For Bad caps, and Ripple on the DC supply, make sure if a MOSFET, that there isn't too much drive.. sometimes the resistor breaks down. If a NPN then check any Collector resistors/capacitors. Also check,it isn't being "Overdriven" by too much base current too. but look, get a Service manual, it will tell you everything you need to know to service.
http://www.retrevo.com/support/Sony-KV-32FS120-TVs-manual/id/274ci670/t/2/
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000062178.pdf
http://www.nodevice.com/manual/sonymans/manual3534pdf/get5050.html
http://911manuals.com/product_info.php/products_id/188559
Service manual above above that user & operations manuals.
http://www.givemefile.net/smanuals/tv/sony/file/45228.html Above may be a FREE link for a service manual
Apr 17, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sparks coming from FBT
If the sparks are coming from the flyback transformer then it needs to be replaced. You would need to be able to use a meter to determine if more damage has been done or not. Let me know If you can use a meter and i will give you some stuff to check. If you take this to a repair shop you can bet on $400-$600 for repair.
Tim Nolan
Sep 25, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Just a click when plugged in and steady red lite??no flashing or pic or sound
If you are a qualified technician then you can try removing the flyback transformer FBT and have it check thru a flyback checker from any electronic repair shop. You will be able to confirm whether you have a problem in the high voltage section. Which would likely is the case. If FBT is OK look for a shortgae in the horizontal section specially the horizontal output transistor. good luck
Oct 15, 2007 | Sony KP-61V85 61" Rear Projection...
No Power on Sony TV
Be sure to use an ORIGINAL Sony transistor and be sure to resolder the pins of the small horizontal driver transformer and all parts connected to and around it, and your set should be fine.
Aug 17, 2007 | Sony FD Trinitron WEGA KV-20FS120 20" TV
LG Studioworks 563N 15" CRT Monitor Logo
107 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
