Question about Mitsubishi VS-50605 50" Rear Projection Television
Not turn on i do not have 24v. Was watching TV for three hours when I was finished the set would not turn off from either remote or front panel. Unplugged unit and left overnight. When I plugged the unit back in the next morning heard a ckick, when I pressed the power button on the front panel - nothing. No power light even. Unplugged unit again heard another faint click. I tried this several times always with the same result. Bought this unit in Dec. 1999, never had a problem with it before.
  • captain_mars Aug 24, 2008
    VS 50605 tv dosn't turn off or on for no particular reason
  • 927 Answers
Good Day,
The most common problem with this Model is the Caps on the Main Board, but to make sure pull the codes. Follow this procedure:
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB. Good Luck, big IRISH.
Posted on Aug 30, 2008
How do I set my TV channel to 3 without the remote?
Hi John,
If channel 3 is skipping by the unit when pressing the channel button key at the front panel, it might be accidentally deleted on the channel selection. If you don't have a remote control, there's no way to add it on the selection. All you have to do is to re-scan the channel by entering to Set-up Menu. Press the Menu button key repeatedly at the front panel to show the "On Screen Menu". Select " EZ Program" to automatically finds and store the channels available at your area. Once the scan is finished, you can now watch all the channels available including channel 3.
Please let me know if you need further assistance.
Kind Regards,
Jdvillanueva
Nov 24, 2011 | Zenith C27A25 27" TV
Emerson LC320EM82S Unit works ok with manual buttons at top of set but Emerson remote and after market remotes wont work at all
Hello
The remote sensor inside the front panel of your TV is faulty. This is a three terminal device, can be located just behind the infrared window at the front panel of your TV. You have to open your TV, and unscrew out the front panel circuit board to access it.
Sep 05, 2011 | Emerson LC320EM8 32 in. LCD TV
Can't get it to auto tune
Hello
To set the TV to autotune do the following.
1 Press "Power Button" to turn on the TV. The Initial Setup screen appears
2 Press CH UP button on the remote control or on the TV front panel to start Auto Program, or press CH DOWN button to Exit.
When you start autoprogramme, wait until it is finished; otherwise it will skip over channels that are available. If it happens so, perform autoprogram again by turning on the power button.
The initial set up screen appears each time you turn on TV until you perform auto program.
To perform Auto Program again
1 Press "Menu" button.
2 Press"=>"to highlight Channel Menu.
3 Press "Down arrow button" to highlight Cable. Press "+" button to select.
4 Press "Up Arrow button" or 'Down arrow button"to highlight On or Off according to how you connected your TV. Press "+" to select.
5 Press "Down arrow button" to highlight Auto Program. Press [+] to search for channels
6 After Auto Program finishes press "Menu button" to exit.
To reset the TV to factory settings
1 Turn the TV on.
2 Hold down [Reset key] on the remote control.
3 Press and release the POWER button on the TV front panel. The TV will turn itself off,
then back on.
4 Release [Reset] key.
Ok.
Jan 20, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Remote sensor does not work. Have tried three different remotes
Your problem can be from any of these: Main Board, IR Sensor or Remote. Watch the youtube video attached to diagnose it correctly.
Feb 02, 2010 | Hyundai ImageQuest HQL320WR 32 in....
1.you have to hit the power button multiple times to turn off tv 2.when watching a channel the tv starts scrolling through the channel set up. It eventually stops but then you can't use the remote and have...
Sounds like a tact switch problem at the front of the set. The switches are just behind the front panel buttons. Don't replace just one. Replace them all. They are not expensive and will avoid trouble later. If one switch is getting stuck internally, nothing else will work including the remote.
Oct 15, 2009 | RCA Televison & Video
Reset hour meter for replaced lamp
push and hold the PIP (same as play) button in the remote control
push and hold the menu button on the front panel of the tv.
Do both actions simultaneously. Of course you have to be close to the tv to do this: pointing with the remote at the sensor AND holding the menu button of the tv panel.
Do this for some seconds and the screen is going to tell you the timer was reset sucesfull and ask you to push exit in the remote control to finish
Apr 08, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Can't figure out how to turn on cable on Sony Trinitron TV
Setting Up the TV
After you have finished connecting your TV, you can use Auto Program to set up your
channels. During Auto Program, the TV will automatically search for available channels and
program receivable channels.
(Make sure CABLE is connected on coaxial and you are not using any other connections such as cable box, hdtv or satellite antenna)
1 Press to turn on the TV. The Initial Setup screen appears.
2 Press on the remote control or on the TV front panel to start Auto Program, or press
to exit.
Press .
2 Press g to highlight Channel Menu.
3 Press f to highlight Cable. Press to select.
4 Press F or f to highlight On or Off according to how you connected your TV. Press to
select.
5 Press f to highlight Auto Program. Press to search for channels.
6 After Auto Program finishes, press to exit.
Turn the TV on.
2 Hold down on the remote control.
then back on.
4 Release .
✍ When you start Auto Program wait until it is finished; otherwise it will skip over channels that are
available. Perform Auto Program again to program receivable channels.
✍ The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
Initial Setup
Auto Program [CH+]
[CH–]
First please connect
cable/antenna
Exit
Jan 17, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
My PLTV 3250 keeps switching from tv to dtv on its own!
I had the same problem and called the company. They suggested this solution and to my amazement... it worked! Turn off the TV manually (don't use the remote). Unplud the TV from power supply. Wait 1/2 hour. Then replug and turn it on manually. It should take care of it by resetting to factory settings. You will have to redo any color, hue, brightness, etc adjustments. Sherri
Dec 07, 2006 | Protron PLTV-32 Television
Mitsubishi VS-50605 50" Rear Projection Television Logo
60 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
