Question about Kenmore 63942 Dryer
Location of thermistor installation instructions for thermistor and sensor
Hi;
The dryer has heat but always turns off before clothes are dry using the moisture setting. I replaced the sensor (electrode) but that did not solve the problem. I have purchased a thermistor, but I am not sure of where this is located even when looking at the sears diagram.
I was hoping some one could tell me how to get at the thermistor and also confirm with me that on the electrode there is only one wire connected even though there are two electrodes which don't appear to connect to each other.
Any help is appreciated,
thanks
  • Anonymous Sep 04, 2008
    find thermastate
  • flores297 Sep 08, 2008
    Our Kenmore 80 series (Heavy Duty, Large Capacity) keeps turning off.
    We set the timer on 80 & it always seems to shut off on the 70. When you immediately look inside, I see that the coils are on with a orange/cherry red color so the heat is still working. I'm wondering if there is an automatic turn-off sensor if that coil is getting too hot, or is it something with the timer?
  • 943 Answers
Hi thanks for the question i think your problem is with the venting make sure the vent is clear to the outside check that thanks the appliance doc
Posted on Sep 25, 2008
Dryer works OK on timed dry but doesn't dry the clothes in Auto dry.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum 9 this is why in some cases the dryer will operate at lower cycles like gentle or low heat but not at higher settings?)
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :
http://www.ehow.com/info_12203962_check-dryer-thermistor.
GOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE
How to Check Dryer Thermistor eHow
Jan 07, 2016 | Dryers
Gas dryer does not dry in "timed Dry" setting
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Mar 06, 2015 | Whirlpool LGB6300 Gas Dryer
Dryer does not always fail to heat throughout entire drying time on timer.
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Oct 17, 2014 | Dryers
My danby dryer keeps shutting off and turning on and the clothes take forever to dry
GOD IS STILL GOOD !!!!
Sep 09, 2014 | Danby DCD5505W Electric Dryer
Why does bosch condensor sensor dryer not heat
Sep 09, 2014 | Bosch 422202 Clothes Dryer Moisture Sensor...
Why do the Automatic cycles on my Whirlpool Duet Electric Dryer not always work?
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE
Jul 30, 2014 | Whirlpool Dryers
My dryer works fine...heats tumbles the timer just doesnt advance once it starts therefore the dryer wont turn off on its own
Jul 11, 2014 | Whirlpool LEB6200 Electric Dryer
What do i need to replace if dryer sensor stops cycle before clothes are dry
Jun 21, 2014 | Kenmore 63942 Dryer
Drier takes several run times to dry clothes
Hello.
When your dryer heats yet gives very poor drying results its usually always poor air flow that's causing it to take forever to dry the clothing.
To check to see why it has poor airflow the first thing to check is for a blocked or restricted vent tube from the back of the dryer all the way to where it exits the house. Also in some case lint is built up in the blower wheel/lint filter housing and that housing would need to taken apart and clean all the lint from it.
GENE
Oct 13, 2011 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Electric Dryer - heat but not drying
you have thermistor failure/ located inside machine reason for premature heat
Oct 07, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 63942 Dryer Logo
269 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Richard Roth
Richard Roth
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
