Question about Olympus Camedia D-425 / C-170 Digital Camera
Saved images How do I know if images are being saved to the internal memory or to the optional xD-Picture Card?
    Master:
  • 852 Answers
The internal memory and the xD Picture Card cannot be used at the same time. When the card is inserted the internal memory is disabled. When you want to use the internal memory, remove the xD Picture Card. The LCD display will indicate that images are saved to internal memory by displaying [IN] in the lower right corner of the screen. When using the xD Picture Card the camera’s LCD will display [xD] in the lower right corner of the screen. These indicators are displayed just above the number of available frames.
Posted on Aug 31, 2005
How to save a picture to a memory stick,,
Even if the Memory Stick Duo is inserted in the Camera, the images will not be saved in the Memory Stick Duo until the capacity of the Internal Memory is full. To save the images in the Internal Memory to the Memory Stick Duo, select the EXPORT option from the Viewing Menu of the Camera. Touch the MENU icon when viewing images to select the IMPORT option.
There are two option in the Viewing Menu of the Camera (Export and Import). Export option is to save from Internal Memory to Memory Stick and Import is for saving from Memory Stick to the Internal Memory.
This Camera is having 4GB of Internal Memory, hence the images captured will get saved in the Internal Memory first and then to Memory Stick once the Internal Memory is full.
Thanks for using FixYa
Dec 04, 2010 | Sony Cyber-shot DSC-T2 Digital Camera
How do you access pictures on the internal memory of the Fine Pix F470? I'm not sure if the camera came with a USB cable...is that what is needed to connect the camera and my PC?
It is possible to transfer saved images on the internal memory to xD-Picture Card Page 67 on the manual - see limk below
The user manual is here http://fujifilmusa.com/shared/bin/FinePix_F470_Manual.pdf
It is possible to transfer saved images between the internal memory and an xD-Picture Card. 1Press the “w” button to turn the camera on in Playback mode. 2Press the “MENU/OK” button to display the menu on the LCD monitor. 2 a)Press “a” or “b” to select “û” COPY. b)Press “c”. 4 a)Press “a” or “b” to select “FRAME” or “ALL FRAMES”. b)Press the “MENU/OK” button. ALL FRAMES Copies all the frames (files). FRAME Copies only the selected frame (file). COPY 3 a)Press “a” or “b” to select INTERNAL MEMORY \ CARD or CARD \ INTERNAL MEMORY and confirm the copy source and copy destination. b)Press “c”.
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Apr 05, 2010 | Fuji FinePix F470 Digital Camera
Olympus SP550UZ photos saved on camera memory not card
In the Menu if you go to the option that says Setup and press ok there should be an option that says Backup. This should allow you to copy the images from the internal memory to your xD card.
Nov 28, 2008 | Olympus SP-550 UZ Digital Camera
Move images saved to the internal memory to the optional xD-Picture Card
The images saved to the internal memory can be copied to the xD-Picture Card, but you cannot copy images from the xD-Picture Card to the internal memory.
Aug 31, 2005 | Olympus D-545 Zoom Digital Camera
Saved images to the internal memory or to the optional xD-Picture Card
The internal memory and the xD-Picture Card cannot be used at the same time. When the card is inserted the internal memory is disabled. When you want to use the internal memory, remove the xD Picture Card. The LCD display will indicate that images are saved to internal memory by displaying [IN] in the lower right corner of the screen. When using the xD-Picture Card the camera’s LCD will display [xD] in the lower right corner of the screen. These indicators are displayed just above the number of available frames.
The images saved to the internal memory can be copied to the xD Picture Card, but you cannot copy images from the xD Picture Card to the internal memory. Before you choose to copy the files to the xD card be sure that there is enough room on that card. To copy the images to the xD card make sure the camera is powered on, then and press the menu button. Use the down arrow key to navigate through the menu to the BACK UP feature. Use the right arrow key to enter the Back Up screen and select YES to copy the images to the xD card, or NO if you choose not to coy the image files.
Aug 31, 2005 | Olympus D-535 Zoom / C370 Zoom Digital...
Record images
Quality Mode Resolution 14MB Internal Memory 256MB xD Picture Card 512MB xD Picture Card SHQ 2592 x 1944 3 images 69 images 139 images HQ 2592 x 1944 11 images 204 images 409 images SQ1 1600 x 1200 27 images 515 images 1030 images SQ2 640 x 480 144 images 2663 images 5324 images
Aug 31, 2005 | Olympus Camedia D-435 Digital Camera
Move images to the internal memory to the optional xD-Picture Card?
The images saved to the internal memory can be copied to the memory card, but you cannot copy images from the memory card to the internal memory.
Internal memory or to the optional xD-Picture Card?
The internal memory and xD-Picture Card cannot be used at the same time. When the card is inserted the internal memory is disabled. When you want to use the internal memory you must remove the xD-Picture card. The LCD display indicates the images are being saved to the internal memory by displaying [IN] in the lower right corner of the screen. When using the xD-Picture Card the LCD will display [xD] in the lower right corner. These indicators are displayed just above the number of available frames.
Internal memory
Quality Mode Resolution 14MB Internal Memory 16MB xD-Picture Card 512MB xD-Picture Card SHQ 2288 x 1712 4 images 5 images 178 images HQ 2288 x 1712 14 images 16 images 523 images SQ1 1600 x 1200 27 images 32 images 1030 images SQ2 640 x 480 144 images 165 images 5324 images Storable movie length and resolution (approximate figures). The number of movies saved is based upon the storage capacity of the xD-Picture Card and length of each movie. Quality Mode Resolution 14MB Internal Memory 16MB xD-Picture Card 512MB xD-Picture Card HQ 320 x 240 30 fps movie 20 sec. max movie 24 sec. max movie 12 min. 54 sec. movie SQ 320 x 240 15 fps movie 41 sec. max movie 48 sec. max movie 25 min. 48 sec. movie
Aug 31, 2005 | Olympus Camedia D-425 / C-170 Digital...
Olympus Camedia D-425 / C-170 Digital Camera Logo
114 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
