Goodman CKL42AR42 Air Conditioner Logo
Posted on Jul 02, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a GMN 100 the fan squeaks when air conditioning. What maintenance should I perform?
Anonymous
Level 3:
  • Goodman Master 43,501 Answers
  • Posted on Jul 02, 2011
Anonymous
Goodman Master
Level 3:
Answers
43501
Questions
0
Helped
10844194
Points
101584
You can try to get some light motor oil around the shaft and see if it will work into the bearing... usually the top bearing is the one to go bad...
Sometimes there will be an oil cup , but not on most motors anymore...
if the oil does not work then the motor will have to be replaced..
Air Conditioning it is not cooling but the Fan keep working is it the control box
Air conditioning units in vehicles require regular maintenance to provide continued good service. Your unit may require a "recharge" Most garages will provide this service for about £40/50.
What services does Kia Sportage 2008 with 90000 need?
Here is recommended maintenance up to 10 1/2 yrs. If you follow through list, you should be able to tell by elimination what you may need. Here is the link - also list pasted below, here:
http://www.kia-forums.com/2g-2006-2010-rio-rio5/35574-maintenance-schedule.html
SUGGESTED Maintenance Schedule:
Months Kilometres Maintenance Type
4 months 6 000 km Maintenance #1
8 months 16 000 km Maintenance #2
12 months 24 000 km Maintenance #1
16 months 32 000 km Maintenance #3
20 months 40 000 km Maintenance #1
24 months 48 000 km Maintenance #2
28 months 56 000 km Maintenance #1
32 months 64 000 km Maintenance #3
36 months 72 000 km Maintenance #1
40 months 80 000 km Maintenance #2
44 months 88 000 km Maintenance #1
48 months 96 000 km Maintenance #3
52 months 104 000 km Maintenance #1
56 months 112 000 km Maintenance #2
60 months 120 000 km Maintenance #1
64 months 128 000 km Maintenance #3
68 months 136 000 km Maintenance #1
72 months 144 000 km Maintenance #2
76 months 152 000 km Maintenance #1
80 months 160 000 km Maintenance #3
84 months 168 000 km Maintenance #1
88 months 176 000 km Maintenance #2
92 months 184 000 km Maintenance #1
96 months 192 000 km Maintenance #3
100 months 200 000 km Maintenance #1
104 months 208 000 km Maintenance #2
108 months 216 000 km Maintenance #1
112 months 224 000 km Maintenance #3
116 months 232 000 km Maintenance #1
120 months 240 000 km Maintenance #2
124 months 248 000 km Maintenance #1
128 months 256 000 km Maintenance #3
MAINTENANCE #1
MAINTENANCE #1 INCLUDES:
Replace engine oil and filter
Check fluid levels (pwr. strg., brake/clutch, coolant, washer)
Check tire condition and pressure (including spare)
Check exterior & interior lights for proper operation
Check windshield washer/wiper function
Check horn function
Check handbrake function/freeplay
Lubricate all latches, hinges and locks
* = if equipped
See "Model-Specific Maintenance"
MAINTENANCE #2
MAINTENANCE #2 INCLUDES:
Check horn function
Check engine coolant specific gravity
Check engine air filter; knock out dirt/bugs, replace as req'd
Remove wheels and brake drums, check pad/shoe thickness; inspect calipers, cylinders and shoes for proper function, leaks or damage; adjust rear brakes as required.
Rotate tires
Visually check underbody fasteners for condition & integrity
Check brake/clutch pedal freeplay
Check steering wheel components for proper operation
Check CV boots/tie rods/ball joint boots (visual inspection)
Check all seat belts and anchor integrity
Check exhaust sys. for leaks, mountings, brackets; heat shield
Check transfer case oil level & condition, fill as required
Check front & rear differential fluid, fill as required*
Check man. transaxle oil level & condition, fill as required*
Check auto transaxle fluid level & condition, fill as required*
Lubricate driveshaft u-joints (early Sportage only)
Road test vehicle
* = if equipped
MAINTENANCE #3
MAINTENANCE #3 INCLUDES:
Check horn function
Check coolant specific gravity
Inspect, deglaze, clean, adjust & lubricate brake components
Rotate tires
Check transfer case oil level & condition, fill as required*
Check idle speed
Inspect power steering lines & hoses (visual)
Check A/C compressor operation and performance*
Check brake line fittings, bleeder screws, booster for damage, looseness, leaks
Road test vehicle
* = if equipped
KIA MODEL-SPECIFIC MAINTENANCE
In addition to the KIA Basic Scheduled Maintenance, certain KIA Models will require the following maintenance services:
ALL MODELS
(Every 36,000 km or 18 months)
Manual transaxle service (except Sportage)
Automatic transaxle service (except Magentis)
Check drive belt condition & tension
Inspect front ball joints
ALL MODELS
(Every 48,000 km or 24 months)
Replace engine coolant
Replace engine air filter
Inspect fuel lines & connections
Inspect ignition wires
Replace spark plugs (except Platinum)
ALL MODELS
(Every 60,000 km or 30 months)
Replace brake/clutch fluid
Inspect EVAP canister & vapour lines
ALL MODELS
(Every 72,000 km or 36 months)
Replace fuel filter
Inspect PVC system/hoses for integrity
ALL MODELS
(Every 96,000 km or 48 months)
Replace spark plugs (Platinum)
ALL MODELS
(Every 102,000 km)
Replace timing belt
SPECTRA
(Every 12,000 km or 6 months)
Replace HVAC air quality filter (if equipped)
MAGENTIS
SPORTAGE
Transfer case, differential & manual transaxle service
Transfer case & differential service (auto. trans. model)
SORENTO
2answers
To clean the filters
Instructions on how to clean the filters are in any air conditioners user guide, a scheduled maintenance section. Just choose the necessary one according to your air conditioner make and model, download it and find the needed information Air conditioner hvac user manuals
Central air conditioning unit
you must do the maintenance . Call to the tech for to make the maintenance required. to due the activity of work.
God bless you
Exhaust system flex pipe repair. Thank You
This system includes air cleaner, intake manifold, exhaust manifold, exhaust muffler, exhaust turbocharger ( for turbocharged diesel engine) , intercooler ( for turbocharged and inter-cooled diesel engine) and connecting pipes.
valve or exhaust arresting device installed after the primary filter to take off the dust from filtering. The resistance of the air cleaner should not be too big, the allowable max. resistance under its stained condition is 3kPa, and that under its stained condition is 5kPa. There is maintenance indicator mounted at the vent port of air cleaner, when red signal is given that means maintenance or replacement should be taken place in time, otherwise the performance and service life will be influenced.
1helpful
30000 MILE CHECK UP , WHAT NEEDS TO BE DONE ?
  • At 40,000 Use this Sheet
MAINTENANCE II
1. CHANGE ENGINE OIL AND FILTER. Reset oil life system. Refer to Engine Oil Life System. An Emission Control Service. 2. VISUALLY CHECK FOR ANY LEAKS OR DAMAGE. A fluid loss in any vehicle system could indicate a problem. Have the system inspected and repaired and the fluid level checked. Add fluid if needed. 3. INSPECT ENGINE AIR CLEANER FILTER. If necessary, replace filter. An Emission Control Service. The U.S. Environmental Protection Agency or the California Air Resources Board has determined that the failure to perform this maintenance item will not nullify the emission warranty or limit recall liability prior to the completion of the vehicle's useful life. We, however, urge that all recommended maintenance services be performed at the indicated intervals and the maintenance be recorded. 4. CHECK TIRE INFLATION PRESSURES AND WEAR. 5. INSPECT BRAKE SYSTEM. Visually inspect brake lines and hoses for proper hook-up, binding, leaks, cracks, chafing, etc. Inspect disc brake pads for wear and rotors for surface condition. Inspect other brake parts, including calipers, parking brake, etc. 6. CHECK ENGINE COOLANT AND WINDSHIELD WASHER FLUID LEVELS AND ADD FLUID AS NEEDED. 7. PERFORM ANY NEEDED ADDITIONAL SERVICES. Refer to Additional Required Services. 8. INSPECT SUSPENSION AND STEERING COMPONENTS. Visually inspect front and rear suspension and steering system for damaged, loose or missing parts or signs of wear. Inspect power steering lines and hoses for proper hook-up, binding, leaks, cracks, chafing, etc. 9. INSPECT ENGINE COOLING SYSTEM. Visually inspect hoses and have them replaced if they are cracked, swollen or deteriorated. Inspect all pipes, fittings and clamps. To help ensure proper operation, a pressure test of the cooling system and pressure cap and cleaning the outside of the radiator and air conditioning condenser is recommended at least once a year. 10. INSPECT WIPER BLADES. Visually inspect wiper blades for wear or cracking. Replace blade inserts that appear worn or damaged or that streak or miss areas of the windshield. 11. INSPECT RESTRAINT SYSTEM COMPONENTS. Make sure the safety belt reminder light and all your belts, buckles, latch plates, retractors and anchorages are working properly. Look for any other loose or damaged safety belt system parts. If you see anything that might keep a safety belt system from doing its job, have it repaired. Have any torn or frayed safety belts replaced. Also look for any opened or broken air bag coverings, and have them repaired or replaced. (The air bag system does not need regular maintenance.) 12. LUBRICATE BODY COMPONENTS. Lubricate all key lock cylinders, hood latch assembly, secondary latch, pivots, spring anchor, release pawl, rear compartment hinges, outer liftgate handle pivot points, rear door detent link, roller mechanism, liftgate handle pivot points, latch bolt, fuel door hinge, cargo door hinge, locks and folding seat hardware. More frequent lubrication may be required when exposed to a corrosive environment. Applying silicone grease on weather-strips with a clean cloth will make them last longer, seal better and not stick or squeak. 13. REPLACE PASSENGER COMPARTMENT AIR FILTER. If you drive regularly under dusty conditions, the filter may require replacement more often.
3helpful
2answers
Air conditioning not working 100%
You may want to have the evaporator (the AC part under the dashboard on the passenger side) cleaned. It needs to be taken out and cleaned. Normally this would solve the issue. Have the freon checked if there is a decrease. You may have it filled up and have the system checked for leaks.
2answers
Blowing hot and cold
The squeaking could be it just regulating the pressure badly but all cars regulate their pressure for the a/c when you turn the car off.
But anyway, you need a condenser fan for the ac for when you idle.
2answers
AIR CONDITIONER WILL NOT COOL WHEN IDLED
Typical problem of R-134 freon. It just doesn't perform well at idle, though hardware changes over the years have improved performance in later models.
However, be sure to cover the bases. Check freon charge with gauge set. Don't guess. Make sure the pressures are correct and that cooling fan is functional and nothing restricting air flow at condenser & radiator. High pressure from car wash wands can fold-over the cooling fins at radiator thus restricting air flow. I suspect all this is good but you should make certain to remove any doubt.
Top Goodman Heating & Cooling Experts
Paul Carew
Mike Cairns
Mike Cairns
Jay Finke
Jay Finke
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
