Question about Technics SL-1210 Turntable
I have a technics slbd25 automatic turntable and it doesnt work any more how do i figure out if the belt if off or if the motor is shot
  • MYCROW Dec 16, 2008
    Turntable turns very slowly. I have lubricated parts as intidicated. a VOM to the motor connections hardly registers. Is the motor shot?
  • 515 Answers
You have to be more specific as to what is wrong? Does it power up? Does the platter rotate?
- OPTiC
Digital Analog Therapy
The Turntable Experts
www.repairnyc.com
Posted on Sep 13, 2008
I HAVE A TECHNICS TURNTABLE SL-QD35 THAT IS DIRECT DRIVE AUTOMATIC THAT IS SPINNING TO FAST.
i got my turntables repaired by these guys www.technmics1210repair.co.uk
i did they made my setup work like new so im going to spread the word.
give them a shot
Apr 03, 2010 | Technics SL-1200MK2 Turntable
Technics 1210 mk2 motor problem
Depends on if it's a belt drive turntable or direct drive.
If a belt one, there will either be a speed adjuster on the top of the motor, or one on a PC Board. And yes apart from setting the speed, it as straightforward as taking the old one out and wiring the new one in.
The direct drive, will also have to be adjusted for speed too.
Feb 22, 2010 | Panasonic Technics SL-1210MK2 Turntable
Where can I purchase a new rubber belt to drive my Servo Automatic turntable SL-B210 Ths is not an electronic belt
Here is a link for Technics Turntable replacement belts...just scroll way down the page for your SL-B210 belt listing $10.00. Hopes this helps.
http://www.turntablebasics.com/belts/technics.html
Oct 28, 2009 | Technics SL-1210 Turntable
Ion turntable
1) Remove the platter - just lift up
2) Underneath the platter, you'll see a small lip section
3) Wrap the belt around this lip
4) Put platter back on turntable
5) Rotate platter until you see the motor shaft through the holes on the platter - a brass round looking piece
6) Pinch the belt around the motor shaft.
7) That's it.
- OPTiC
MasterTech
Turntable Parts : Turntable Repairs
May 09, 2009 | Technics SL-1200MK2 Turntable
Changing the belt on a Technics SL-3 (Linear tracking) turntable
Instructions on installation of your drive belt - this also applies to other brands as well - however this belt is only for the Technics models listed above:
  1. Remove the turntable platter off from the turntable
  2. Remove the old/damage belt
  3. Wrap the new belt underneath the turntable platter - you will see a small lip on the bottom of the platter. Wrap the belt around this lip.
  4. Put the platter back on the turntable
  5. The turntable platter will have small holes, rotate the platter until you see the motor, and the motor shaft.
  6. Pinch the belt, so that it wraps around the motor shaft
  7. Turn on and enjoy!
- OPTiC
Technics Drive Belts
Technics Repair Videos
Technics DJ Repair
Technics Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Mar 26, 2009 | Technics Audio Players & Recorders
Turntable wont spin
If everything seems ok with the power , there is usally a small microswitch that sends power to the motor when the tone arm is moved to the start of the record.
The switch might be bad or the lever that actuates it (connected to the tone arm) might be sticking. You may have to take the bottom cover off or remove the platter to see it.
Also make sure the belt is looped over the motor shaft. If the motor runs but the belt still doesnt turn, belt might be bad.
Mar 10, 2009 | Technics SL-BD22 Turntable
Technics SL-B2 Frequency Generator Servo Automatic Turntable will not play
hello
You need a belt.. Lift up the record support..(platter) Underneath you will see a metal post.. Belt goes around that and the bottom of the plate.(there is a rim) . If the belt is there, motor might be bad..
Oct 09, 2008 | Technics SL-1210 Turntable
How do i put my belt back on a technics dc servo automatic turntable system SL-B210 i havnt used it for a while so when i got it out to use the belt was lose uder the thing the disc gose on
Remove the platter, then take the belt, and wrap it to the bottom lip of the platter. You'll see an inner lip underneath the platter... this is where the belt goes.
Next, put the platter back on, and you'll see 2 holes on alternate sides of the platter. Rotate the platter until the brass shaft of the motor is exposed - usually @ the 11 o'clock position. Pinch the belt and pull it out, to wrap around the shaft.
That's it.
- OPTiC
DJ PRO AUDIO
www.djproaudio.com
www.repairnyc.com
Jul 21, 2008 | Technics SL-1210 Turntable
How do I replace the belt on a mt-6410 turntable
Just lift the platter off the turntable, and you'll see where the belt goes. You'll see a metal spindle/motor - this is where the belt wraps around. Then you will have to wrap around your turntable platter. This is a little tricky, but you should be able to figure it out.
- DJ PRO LAB
www.DJPROLAB.com
Apr 22, 2008 | Technics SL-1200MK2 Turntable
Technics SL-1210 Turntable Logo
135 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
