Question about HP Pavilion dv6000z Notebook
Turned on and screen went blank after posting ; "resuming windows"
The screen went to backlight mode right after I opened it this morning. The only thing visible on the screen is the pointer, it moves across a dark screen, no icons , no start button or any indication of anything occasionally the little busy circle will flash for one second then back to nothing, can't reboot as can't get anything to show up on screen to shut it down????? weird. Its almost like its in ghost mode only the place where the start button is located won't respond when I click there, the little scrool box is the only thing that will display if I hold mouse and drag finger along bar. Haven't a clue, If possible please assisst as is only one I have and NEED it.
    Problem Solver:
  • 4 Answers
Try holding down the power button to shut it down. Then press it again to reboot.
Posted on Sep 27, 2008
My display screen goes on and off
I find sleep mode nothing but trouble, eventually corrupts window files over extended use, go into power options, go to stand by and select never and click apply, next go to hibernate "top right" and click, make sure the check box is clear, if not! remove check and click apply and restart your laptop.
Apr 04, 2012 | Sony VAIO Computers & Internet
Acer 4320 Screen turn blank when it load Windows.
press fn button and with up-arrow increase brightness ,,, in windows open display settings by right clicking on the desktop (intel or nvidia properties ) acer 4320 could have nvidia or intel ... increase the brightness and the contrast or load the default settings ,,, use external monitor if need ...
Mar 07, 2012 | Acer TravelMate 4320 Notebook
No display
The following applies to Acer Laptops...
If the power indicator is lit but nothing appears on the screen - The computer's power management system automatically blanks the screen to save power. Press any key to turn the display on.
If pressing any key does not turn the display back on, check the following....
1. The brightness level might be too low. Press Fn and the right cursor key to increase brightness level
2. Display device might be set to an external monitor. Press Fn and F5 to toggle to the internal display
3. Backlight might be turned off. Press Fn and F6 to turn on the backlight.
4. If the Sleep indicator is lit, the computer is in Sleep mode. Press & release power button to resume.
May 09, 2011 | Acer Aspire One PC Notebook
Power is on but no signal output to the screen
The following applies to Acer Laptops. You did not specify the brand of laptop you had. If your laptop is not Acer, the specific keys mentioned may be different and you should adjust accordingly.
Apr 04, 2011 | Computers & Internet
I accidently hit the sleep button on my keyboard (Viewmate CC2201) and my monitor went blank and I dont know how to get it out of sleep mode. Help !!!!!!!!!!!!!!
Press, but do not hold, the power button one time. the system should start back up and resume windows just as you left it.
GOOD LUCK AND PLS RATE THIS POST!!!!
Nov 16, 2010 | ViewSonic (CC2201) Keyboard
Sound but no vision, black screen
It's either the backlight lamp or backlight inverter is busted due to a power failure or fluctuation. Here's how to determine which is which:
  1. Grab a flashlight.
  2. Turn on the TV.
  3. Shine the flashlight onto the screen.
  4. If you cannot see any display even a faint one, the backlight inverter is dead, else the backlight lamps are busted.
  5. Replace which ever is the culprit.
Sep 25, 2009 | Sony Televison & Video
My acer 4520's screen is blank when i'm turning it on.
There are approx 4 reasons why this might happen:
  1. The backlight has gone (Find a dark place and shine a torch into the screen and see if you can see an image in the background, if you see an image then the backlight has gone) - Needs a new backlight (Engineer to remove and fit) or have a new panel fitted.
  2. The panel has died - Need a new panel
  3. A cable has worked itself loose or is broken
  4. The inverter has gone - Need new inverter
  5. Long shot, the bios has got corrupted - Engineer could re-flash the bios
  6. Long shot, Mainboard onboard graphics has gone - Need new mainboard
My personal opinion is that the backlight or inverter has gone - Either way it needs to be opened up to repair it, consult a service centre and get a quote or repair it yourself if your up for it.
Thanks
Sep 05, 2009 | Acer Aspire 4520-5582 Notebook
Screen is blank
Your backlight finally went out. If doing it yourself, you need to order 2 to 4 backlights along with an inverter. It is good to replace both at the same time. The backlights are like mini floresent tubrs that need to be taken out and replaced by some one who has done it before. The cost will run you about 50.00 if you do it yourself.
Take care
Kevin
Jul 31, 2008 | Philips 32PF5320A 32 in. LCD Television
HP Pavilion dv6000z Notebook Logo
142 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
