I'm not too familiar with the later model bikes but if I were getting a clicking noise under the seat and the bike was not starting, I'd investigate the source of the noise. It's possible that it is a starter relay that engages the solenoid that is an integral part of the starter. Look at the starter from the right hand side of your bike. You'll see a single small wire that connects to the end of the starter just above the end plate of the solenoid. Disconnect this wire and connect a test light or volt meter to the wire. Turn on your ignition switch and press the start button. You should hear the click under the seat and see voltage at the end of that wire. If not, replace the relay, a plastic cube about an inch in dimension.
Good Luck
Steve
2012 street bob, when i go over any uneven surface bike makes a thud noice starting from the front suspension. sound is felt under the seat
