Garmin nuvi 200W GPS Receiver Logo
Posted on Aug 24, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Stuck how do i reset my garmin 250w? Idownloaded some pois and now when i turn it on, it just says loading maps. it has been "loading maps" for an hour now help. thanks
Anonymous
Level 3:
  • Master 928 Answers
  • Posted on Aug 24, 2008
Anonymous
Master
Level 3:
Answers
928
Questions
16
Helped
220261
Points
2419
You can reset by pushing on the lower right hand corner while powering it on, it will ask if you would like to clear all user data. select Yes,
If after that the problem still exists update the firmware on your unit. Go to the link and click on unit update
http://www8.garmin.com/support/download.jsp
Garmin nuvi 50lm only shows garmin screen and just a bit of green on the bottom. sometimes it shows the green register bar all the way accross
Garmin nuvi 50LM Boot problem ' POI Factory
www.poi-factory.com > Garmin talk
Aug 11, 2012 - Why won't my nuvi 30, 40, or 50 go past the Garmin logo screen when I turn it on? .... Just wanted to say thanks to Muell9K for the hard reset solution. ... get the Nuvi to start up with the screen that shows the picture of a Garmin ...
Crap... White Screen (nuvi 350)
May 11, 2008
garmin frozen?? (how do I reset?)
May 11, 2008
More results from www.poi-factory.com
How to Reset the Garmin nuvi 30, 40 and 50 with GPS City ...
? 0:51
https://www.youtube.com/watch?v=mujdSP-fM98
Jul 31, 2012 - Uploaded by GPSCity
In this video learn how to RESET the Garmin nuvi 30, 40, and 50GPS back to factory default settings. Back up all ... With the GPS unit off, press the bottom right hand corner of the screen. Turn the unit ... Show more. Show less.
tip
Garmin POI, GPI, GPX, GDB and CSV and how not to be confused
GPX or CSV file can be converted to the proprietary Garmin format GPI format (Garmin Points of Interest) format using the Garmin POI loader v2.54 OR use the one bundled with the Garmin Map Source v6.15.11 at the time of posting if there is also a BMP file of the same filename then this will be added to the Waypoints Symbol.
If you put all your POI that you want to be added to the Garmin POI then place all them in the same folder prior to starting the POI Loader and they will be placed into sub-menus otherwise it will select the single file entries only.
However the Garmin Mapsource can't open this GPI format it is specifically for the SATNAV Device only open GDB, MPS, GPX and LOC files can be opened as standard. There are two ways that I know of that will convert this GPI back into CSV or the POI format if required you might like to open the POI content in the Map Source program.
First this can be done using GPI2GPS it does however cost 15 EUROs or its older brother GPSConvertor for an extra 20 EUROs will convert to all formats for all makes of device including Tom-Tom, Garmin and many others.
Secondly you can convert POI file in CSV format directly to GPX (exchange format) using the excellent GPXtoPOI Convertor v1.1.8 then import directly into the Map Source if you also want to use BMP that has been downloaded in Map Source you can replace the 8 default custom waypoint symbols located on your computer with your own or from the Tescos.ZIP file in this example that contains the CSV and BMP.
You can open these symbols with a graphic editor and use them as templates for creating your own symbols.You can add up to 64 custom waypoint symbols. These symbols must be in .bmp format and must be named numerically from "000.bmp" to "063.bmp." Custom waypoint symbols can be 16 x 16 pixels (small) or 24 x 24 pixels (large) and up to 32-bit color
Also check out my other POI tip HERE for help on how to create your own BMP's for use with your Garmin using Adobe Photoshop
It will also convert any GPX format into CSV format for use with the POI loader using the other button on the menu maybe this program would be best called GPXtoCSV instead to avoid confusion
And this one I saved for last If you want to transfer images from the Garmin use xImage and have your Garmi SATNAV connected.
For a full list of all POI sources then visit the Gamin POI Source another great website full of loads of useful tools is www.freegeographytools.com
If you are unable to use xImage it means that you unit is not compatible for example the Nuvi 250 will not be found and you may see this window
1helpful
How to download a map update for some malls and places
Malls and places are not available on map updates. They are considered Points of Interest (POIs). There are many sites on the web that offer POIs for you to download to your GPS. You just have to find one that offers what you are looking for.
1helpful
Garmin nuvi 250
Testing by FixYa Staff
Please do not rate this post!
We apologize for any inconvenience.
Garmin 250w updates
Not to sure but they do give free POI download and sounds.
3helpful
4answers
Nuvi 360 Stuck on loading maps
Have you reset the unit yet (little pusbutton behind the aerial)
Won't stay on
Have you installed anything lately? Do you have any sd card installed? Usually this is the cause for it to crash. There is a reset on the bottom of the nuvi, when it locks up blank, press the reset button and see what happens...
2helpful
2answers
POI menu with custom POI does not appear anywhere on the C330?
You need to use Garmin POI loader to input custom POI. After loading POI's they will show up in "My Favorite" under "Custom POI"
Map fro Garmin
As far as I know you can only buy maps from Garmin, or a Garmin retailer.  The 660 should have all the maps for North America already loaded in it.
You can purchase Points of Interest (POI) databases from a variety of sources.  Just google POI.  These are not maps but they are adresses for points of interest such as restaurants, special services, and even speed trap cameras.
Top Garmin GPS Experts
vince
Jesse Walters
Jesse Walters
Are you a Garmin GPS Expert? Answer questions, earn points and help others
