Question about Sony Mavica MVC-CD400 Digital Camera
Disk Error I am encountering a disk error when I try to finalize the disk. This has happened several times now. I don't want to lose these pictures
    Problem Solver:
  • 4 Answers
I don't know a direct "solution," but you should be able to USB your images from the unfinalized CD to your pc.
Posted on Nov 06, 2008
Laptop C partition low disk space
1st run disk cleanup. Then compress you C-drive this will compress all your file freeing up space. Then download CCleaner and run that. Finally, run disk defrag. But you should also erase stuff you do not need.
Nov 27, 2014 | Computers & Internet
How can I fix Cyclic Redundancy Check on external drive?
This problem is caused by bad sectors on HDD. refer to http://www.goodlucksoft.com for more information
Feb 20, 2013 | Computers & Internet
System 90b error
Run the Check Disk Utility
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.If check disk fails to fix it, then you will need to reinstall your operating system. Do a Repair Install so that you don't lose your data.
Apr 20, 2012 | HP Computers & Internet
Brand new ASUS - won't install windows dialog box says : computer restarted unexpectely or encountered an unexpected error" any suggestions?
It could be several things, if you are just starting the computer for the first time, it may have encountered an error on the installation media.
Are you using a DVD or CD for the installation? Try cleaning it and retry.
If this is the first time you have attempted it, retry.
If still fails use the emergency disk that comes with all asus machines.
Dec 25, 2010 | ASUS m6n Notebook
Dvd does not show what was recorded from my sony camcorder error message C13:02 flashing
This is Disc Access Error, Disk Access Error, Check disc error, Check disk, C error unreadable, disc error code 13, disk error code c1302, c:13:O2 DISC ERROR, Disc Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised, Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not correct disk, the disk in drive is not formatted do you want to format it now.
Nov 15, 2009 | Motorcycles
Disk says not enough space on disk to finilize?
Each time you execute finalization, the disc remaining space will decrease by approximately 13 MB. If you don’t have enough room, it won’t allow you to finalize the disc.
To finalize this disc, you have to delete some pictures to make enough space. But don’t worry, before you delete those pictures, you can save them to your computer.
Find out the CDs came with your camera, refer your manual page 51 - 61 to install ‘PIXELA PTP Manager’ , connect your camera and computer with USB cable, and copy some pictures to your computer, then delete the pictures on camera side. If still not enough room, copy more and delete more. make it enough to do the finalization.
Apr 07, 2009 | Sony Mavica MVC-CD250 Digital Camera
Dmr-es15 "can't read"
after I record a show then I push stop, it writes it to disc and gets up to 96percent and then fails.
Oct 10, 2008 | Panasonic DMRES15 DVD Recorder
Format Error code C:13:01
this camera is a gem! try finalizing the disc using nero burning software or any alternative. but dont try this on the disc that has your important pictures for safety reasons.
Jul 18, 2008 | Sony Mavica MVC-FD200 Digital Camera
Emerson DVd with Video Cassette Recorder EWR20V5
Try using 8x and lower DVDs and -R ones; try cleaning with CD cleaning disk and then try recording a few min again. If that doesn't help try unplugging and waiting about 30min then put in disk that was previously recorded and go to last item and play it to end (if 2hr long skip to last skip and then play until it finishes) - now try just recording a few min using the manual DVD record button and see if error comes up again - usually this unplugging somehow resets everything. Hope this helps ya'll.
Oct 25, 2006 | Emerson EWR20V4 DVD Recorder/VCR
If you can find software to read UDF (universal disk format) you may be able to recover your pix. Whatever you do -- DO NOT reinitialize or finalize the disk. Your existing pix will certainly be lost if you do.
Sep 25, 2006 | Sony Mavica MVC-CD500 Digital Camera
Sony Mavica MVC-CD400 Digital Camera Logo
Top Sony Cameras Experts
Larry Spears
Larry Spears
Are you a Sony Camera Expert? Answer questions, earn points and help others
